  3. Thermostat-Code problem
7 Posts 2 Posters 2.5k Views 2 Watching
  • Bruno CunhaB
    Bruno CunhaB
    Bruno Cunha
    Hi, so im trying to make a a project with the arduino, where i have this:
    -Potenciometer
    -temperature sensor
    -Relay
    So the goal is to read the temperature of something that is heating and turn that off at a certain value that is regulated with the potenciometer.This Is simple , but i want to do something like turn off at 100ºC and only turn that on again at 95ºC. How can you help me? This is the code:
    // Relé ligado ao pino 7
    int porta_rele1 = 7;
    //Relé ligado ao pino 8
    int porta_rele2 = 8;
    float celsius;
    const int porta_sensor1 = A0; // sonda 1 ligada ao pino AO
    const int porta_sensor2 = A2; // sonda 2 ligada ao pino A1
    const int porta_pot1 = A1; // potenciometro 1 ligada ao pino AO
    const int porta_pot2 = A3; // potenciometro 2 ligada ao pino AO
    //Define pinos para o rele como saida
    pinMode(porta_rele1, OUTPUT);
    pinMode(porta_rele2, OUTPUT);
    //Define pinos dos sensores como entrada
    pinMode(porta_pot1, INPUT);
    pinMode(porta_pot2, INPUT);
    pinMode(porta_sensor1, INPUT);
    pinMode(porta_sensor2, INPUT);
    //Estado inicial dos reles - desligados
    digitalWrite(porta_rele1, LOW);
    digitalWrite(porta_rele2, LOW);
    analogReference(INTERNAL);
    Serial.begin(9600);
    Serial.begin(9600);
    pinMode(porta_pot2, OUTPUT);
    pinMode(porta_sensor2, OUTPUT);
    int value1 = analogRead(porta_sensor1); //valor lido na sonda 1
    long celsius1 = value1/9.31;
    int value2 = analogRead(porta_sensor1); //valor lido na sonda 2
    long celsius2 = value2/9.31;
    Serial.print(celsius1);
    Serial.print(celsius2);
    int valueA = analogRead(porta_pot1);
    int valueB = analogRead(porta_pot2);
    long celsiusA = valueA/9.31; // 10 mV por graus C.
    Serial.print(celsiusA);
    long celsiusB = valueB/9.31; // 10 mV por graus C.
    Serial.print(celsiusB);
    if(celsius1 <= celsiusA)
    digitalWrite(porta_sensor1, HIGH); // aquecedor no pino 9
    digitalWrite(porta_sensor1, LOW); // aquecedor no pino 9
    delay(1000);
    • Bruno CunhaB Bruno Cunha
      -Potenciometer
      -temperature sensor
      -Relay
      float celsius;
      Serial.begin(9600);
      Serial.begin(9600);
      delay(1000);
      Big welcome to the MySensors community @Bruno-Cunha !
      I don't understand what valueA and valueB in your sketch is, but I would just add
      #define HYSTERESIS 5 // 5 Degrees hysteresis
      bool heating = false;
      at start of the sketch
      and change
      to
      if(heating)
        if (celsius1 > celsiusA)
          heating = false;
        if (celsius1 <= celsiusA - HYSTERESIS)
          heating = true;
      Edit: Sorry. I messed up. The original code was wrong but I think the updated post should be ok.
      • Bruno CunhaB
        Bruno CunhaB
        Bruno Cunha
        celsius1 is the value read by the sensor anda cesliusA is the value regulated by the potenciometer. One question, what is the purpose of the "#define HYSTERESIS 5"?
          @Bruno-Cunha it sets the hysteresis to 5 degrees
          • mfalkviddM
            I figured out a simpler way. There is no need for the heating variable.
            • Bruno CunhaB
              Bruno CunhaB
              Bruno Cunha
              Yes it worked, i tried something similar before but i did "celsiusA -5" i didnt know i need a variable.I think its solved, thank you very much :)))
                @Bruno-Cunha it is not a variable, and using - 5 would be the same, but using 5 makes it harder to understand and maintain the code. See https://refactoring.com/catalog/replaceMagicNumberWithSymbolicConstant.html for more info on why I prefer using define.
