  2. Enclosures / 3D Printing
  3. MySensors weather station
138 Posts 16 Posters 113.3k Views 15 Watching
  • dbemowskD
    dbemowskD
    OK, so I am doing some testing on the new wind direction sensor board I am building. My problem is that the infrared LED that I have, which was scavanged from an old remote, has good IR pointing forward. but when I try to direct it sideways to the IR sensors, I appear to not be getting enough IR light to trigger the sensors. If I shine a flashlight at each of the sensors, they register, but not when O Does anyone know of either a different IR diode, or a way that I can get the existing diode to shine more in a sideways direction? Here is what the board is looking like. I currently only have one set of 4 sensors connected for testing. You can kind of see that the IR LED is lit.
    0_1495063129068_upload-5fcf55ca-db4f-48c5-9d3a-721e5c0b9bb1
    This is the design of the IR rotor that directs the light which gets screwed to the end of the bolt that is the shaft of the wind direction vane. The majority of the IR light gets directed at the end of the bolt.
    0_1495063638749_upload-c72eb7e3-4af9-4742-bffe-20d565d4835b .
    I am up for any suggestions.
    wallyllamaW 2 Replies Last reply
      Something reflective that diffuses light?
      dbemowskD 1 Reply Last reply
      • dbemowskD dbemowsk
        Just got my phototransistors. The ebay auction said that it was for 10 sensors. I got 15..... BONUS. :^)
        wallyllamaW
        wallyllamaW
        wallyllama
        @dbemowsk 15 is metric for 10.*
        • If you received 16, then I could have said you ordered in hex, and this would actually have been funny.
          wallyllamaW
          wallyllamaW
          wallyllama
          wrote on last edited by wallyllama
          #47
          @dbemowsk i have an led flashlight in the shape of a lantern, it has a shape like cone that has been dehydrated, so there is a concave curve from the base to the tip. Sort of like a golf tee but different proportions.0_1495070004870_1495069978157-964853724.jpg
          I guess it it like a regular flashlight reflector inside out
          • wallyllamaW wallyllama
            dbemowskD
            dbemowskD
            @wallyllama That would have been funny. There are 10 types of people in this world, Those that understand binary, and those that don't.
              dbemowskD
              dbemowskD
              @wallyllama My only problem with this is that the hole that the LED fits in is slightly larger than 5mm, so that cone would need to be tiny.
                wallyllamaW
                wallyllamaW
                wallyllama
                #50
                @dbemowsk actually, you only have to illuminate the sensors that your slot faces, a 45° mirror or a reflector opposite the slot should help.
                  dbemowskD
                  dbemowskD
                  @gohan I tried putting a piece of tin foil in the hole, but it must not have been at the right angle.
                    Maybe a steel sphere? A white piece of plastic? Remember that you can use the smartphone camera to see the ir light coming from the led, in case you would like to see the result before assembling it
                      dbemowskD
                      dbemowskD
                      @gohan Yes, I have been using my smart phone camera. I use it all the time at work to test remotes. I have some other things to try later today. I will post my results.
                      • Luc3asL
                        Luc3asL
                        Luc3as
                        Hello all,
                        I'd like to add to this discussion my bit,
                        here is code from my older project of arduino based, battery operated, solar panel charged weather station
                        https://github.com/Luc3as/MySensors-WeatherStation
                        I must finish all documentation, I have PCBs ready and manufactured and tested, and models ready for 3d prints too.
                        I am not measuring wind so I am also interested in nice work above.
                        for now it is still work in progress, here is little teaser of overall look
                        • Luc3asL Luc3as
                          Hello all,
                          dbemowskD
                          dbemowskD
                          @Luc3as Thanks for the contribution. I have been quite busy the past few weeks and haven't had a lot of time to work more on the wind direction sensor. There are still a few issues I am working through with that before I can start jumping into the code for it. I am hoping to get more done this weekend.
                          As for your 3D files, do you have them on thingiverse or somewhere accessible for us to check them out? I am interested in the work you have done.
                            Those are quite a lot of solar panels. Is it that power hungry?
                              dbemowskD
                              dbemowskD
                              @gohan I can't see those small panels delivering that much. Plus, at certain parts of the day a number of the panels will most likely be shaded lowering their output.
                              Luc3asL 1 Reply Last reply
                                Luc3asL
                                Luc3asL
                                Luc3as
                                @dbemowsk yup, actually there are 8 of them, each providing nominal 0,5 volts, so to power up the lipo charger for battery I need at least 4 volts, in direct sunlight I think this will not be problem, but as @dbemowsk says, it will not have ideal position to sun every day and for whole time. but there is big enough reserve at battery , providing power for few days to weeks even without solar panel.
                                and I am also checking voltage on solar panel so if there would be some problem with charging I can set notifications or something from home automation system.
                                gohanG 1 Reply Last reply
                                • G
                                  G
                                  GaryStofer
                                  I did some wind speed and direction sensor boards that I use in my own weather station design. All solid state and high resolution with analog signal readout, voltage for direction, 8 pulse per rev for speed. For inspiration see http://wws.us.to. Gary
                                  • Luc3asL Luc3as
                                    @Luc3as if you put solar panels in series you will get resistance from the shaded ones (at least that is what I saw in some experiments) . It would be better to have a single one pointing south that gathers the most sunlight and that's it
                                      dbemowskD
                                      dbemowskD
                                      @gohan said in MySensors weather station:
                                      That is correct, as far as what I have learned. Large monocrystaline and polycrystaline solar panels like the ones shown below have low to no output for the entire panel when one or more of the cells on a panel is shaded or covered.
                                      0_1495767863204_upload-5b7ebb13-0e24-46c9-9309-63bcf0032e7a
                                      Amorphous solar panels like these have closer to full output with less drop-off in shaded areas, but have a lower overall amperage output than monocrystaline and polycrystaline panels.
                                      0_1495768140607_upload-6ac6d03c-ceb7-4228-ac66-8918a44a6ea5
                                      The cells that @Luc3as has in his pic appear to be monocrystaline cells. Each cell will produce about 0.5 volts, so depending on the batteries you are using and the charging circuit, you could put some of these in series to create a couple banks, and then put the banks in parallel, you may get some usable power to charge a battery.
                                      • G GaryStofer
                                        dbemowskD
                                        dbemowskD
                                        @GaryStofer I was checking out your weather station design. Nice work. Out of curiosity, what did you use for your wind direction sensor?
                                          G
                                          G
                                          GaryStofer
                                          @dbemowsk Initially I uses an AS5030 encoder, but then I switched to the EM-3242 as it's much cheaper and smaller and does the same. My board has an Op-amp inverter to change the sense of angle to voltage so that the magnet can run on the top of the chip rather than on the bottom. Only problem we had with the EM-3242 was that it has no hysteresis which shows up at the 360/0 junction.
                                          12.5k
