  3. Vera
  4. Vera Plugin does not start inclusion
vera plugin 1.4
14 Posts 5 Posters 6.9k Views 2 Watching
  • N
    N
    niccodemi
    wrote on last edited by niccodemi
    is your Nano authentic or clone?
    • K
      K
      kalle
      wrote on last edited by kalle
      Did you tried to reboot your vera first (disconnecting the power supply) without the gateway and then plug the gateway in and reload the UI, maybe this will help.
      • rvendrameR
        rvendrameR
        rvendrame
        @niccodemi: Clone, but I managed to use the correct usbserial driver. The RX led flashes at Nano when I press 'start' at Vera UI, so definately something is being received there.
        @kalle: Yes, did all sort of combinations of power, plug in/out , refresh etc
        Thank you both
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        • N
          N
          niccodemi
          Can you post screenshot of Mysensors plugin? have you tried with another browser?
          • rvendrameR
            rvendrameR
            rvendrame
            wrote on last edited by rvendrame
            upload-bd9a003f-e470-4b2f-ba31-118373478891
            And I have compiled the sketch via codebender.cc . I assume there is the latest lib version?
            upload-5459b094-72c1-416d-9f8b-854a244805c4
            Alexa / Google Home
            • N
              N
              niccodemi
              You Nano isn't properly communicating with Vera that's why you don't get Lib version. Are you using any other usb device with vera?
              From my experience using clones for gateway is a hit and miss. After few months I had enough and bought gravitech nano which is connected to vera via powered usb hub. It has been rock steady since I plugged it in.
              • CaptainZapC
                CaptainZapC
                CaptainZap
                What USB chip does your nano have ? FTDI or CH340 ?
                rvendrameR 1 Reply Last reply
                • rvendrameR
                  rvendrameR
                  rvendrame
                  @niccodemi You are right. I did a telnet from vera to 127.0.0.1 3481 (got the address and port from the serproxy log). When I type in telnet, the rx led flashes on nano. but when I short pin3 to gnd, I get a lot of garbage at the telnet (instead the 0;0;3;0;5;1 that I get when the gateway is connected to my PC)
                  So the usbserial between vera and gateway is not doing good. I had an USBUIRT connected to the usb port on vera, but I removed it to test the gateway.
                  Thanks again
                  Alexa / Google Home
                  • CaptainZapC CaptainZap
                    rvendrameR
                    rvendrameR
                    rvendrame
                    @CaptainZap , CH340. I forced the 'usbserial' driver in /etc/modules.d/60-usb-serial
                    I just tried to force ftdi_sio instead usbseral, but I keep getting same garbage on telnet
                    upload-f80bb97a-68c1-42a3-8d1a-923116ae7ef5
                    Alexa / Google Home
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      Update: I swapped the clone-nano by a Uno R3 , and it worked fine once I followed this post http://forum.mysensors.org/topic/265/uno-as-a-serial-gateway-for-vera
                      The clone-nano worked well as a wireless sensor (instead a gateway), so at least I can prototype my projects now (despite the Uno is better than the nano for it).
                      So it is clear that Vera openwrt linux doesn't offer support for usb-to-serial chip CH340; It should be possible to install a module for it but as it involves cross-compiling of the linux kernel I`m giving up.
                      Thank you all anyway!
                      Alexa / Google Home
                      • CaptainZapC
                        CaptainZapC
                        CaptainZap
                        I had the same issue when using a CH340 nano clone... I had to get an FTDI based one, then worked without issues. Unlike you, I wasn't able to get my genuine Arduino uno to work with the plugin, even if I resolved the serial port detection.
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          @CaptainZap, my Uno R3 worked perfectly after I followed this post: http://forum.mysensors.org/topic/265/uno-as-a-serial-gateway-for-vera
                          Alexa / Google Home
                          • rvendrameR rvendrame
                            One more newbie here!
                            Despite my Vera (UI 1.5) recgonizes my Nano properly (I've set the serial to 115200 and so), start button at the UI doesn't work.
                            I'm able to put the gateway in inclusion mode by shorting pin3 to GND, or by typing '0;0;3;0;5;1' at the IDE serial monitor. The yellow led flashes slowly, while the gree led flashes quick, in sync with the sensor transmit messages.
                            At Vera IU (1.5), when I click on Start, the tx led flashes at nano, but the button itself don't activate (neither the gateway enter in inclusion mode).
                            Here's the gateway debug (in inclusion mode):
                            0;0;3;0;5;1
                            0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:255;255;3;0;3;
                            0;0;3;0;5;0
                            And here's the sensor debug (despite ID 255 is defined, it keeps requesting?)
                            req node id
                            send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
                            sensor started, id 255
                            req node id
                            req node id
                            req node id
                            req node id
                            req node id
                            req node id
                            Any help will be appreciated.
                            Thx
                            rvendrame
                            N
                            N
                            NotYetRated
                            wrote on last edited by NotYetRated
                            @rvendrame I have this issue with my Arduino Pro 5v's, (which I bought from the link in the MySensors store page). The only fix I have found is to manually define to node for those sensors. Annoying, but it works.
