  3. Vera
  4. Vera Plugin does not start inclusion
vera plugin 1.4
14 Posts 5 Posters 6.9k Views 2 Watching
  • N
    N
    niccodemi
    Can you post screenshot of Mysensors plugin? have you tried with another browser?
    • rvendrameR
      rvendrameR
      rvendrame
      wrote on last edited by rvendrame
      upload-bd9a003f-e470-4b2f-ba31-118373478891
      And I have compiled the sketch via codebender.cc . I assume there is the latest lib version?
      upload-5459b094-72c1-416d-9f8b-854a244805c4
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • N
        N
        niccodemi
        You Nano isn't properly communicating with Vera that's why you don't get Lib version. Are you using any other usb device with vera?
        From my experience using clones for gateway is a hit and miss. After few months I had enough and bought gravitech nano which is connected to vera via powered usb hub. It has been rock steady since I plugged it in.
        • CaptainZapC
          CaptainZapC
          CaptainZap
          What USB chip does your nano have ? FTDI or CH340 ?
          rvendrameR 1 Reply Last reply
          • rvendrameR
            rvendrameR
            rvendrame
            @niccodemi You are right. I did a telnet from vera to 127.0.0.1 3481 (got the address and port from the serproxy log). When I type in telnet, the rx led flashes on nano. but when I short pin3 to gnd, I get a lot of garbage at the telnet (instead the 0;0;3;0;5;1 that I get when the gateway is connected to my PC)
            So the usbserial between vera and gateway is not doing good. I had an USBUIRT connected to the usb port on vera, but I removed it to test the gateway.
            Thanks again
            Alexa / Google Home
            • CaptainZapC CaptainZap
              rvendrameR
              rvendrameR
              rvendrame
              @CaptainZap , CH340. I forced the 'usbserial' driver in /etc/modules.d/60-usb-serial
              I just tried to force ftdi_sio instead usbseral, but I keep getting same garbage on telnet
              upload-f80bb97a-68c1-42a3-8d1a-923116ae7ef5
              Alexa / Google Home
              • rvendrameR
                rvendrameR
                rvendrame
                Update: I swapped the clone-nano by a Uno R3 , and it worked fine once I followed this post http://forum.mysensors.org/topic/265/uno-as-a-serial-gateway-for-vera
                The clone-nano worked well as a wireless sensor (instead a gateway), so at least I can prototype my projects now (despite the Uno is better than the nano for it).
                So it is clear that Vera openwrt linux doesn't offer support for usb-to-serial chip CH340; It should be possible to install a module for it but as it involves cross-compiling of the linux kernel I`m giving up.
                Thank you all anyway!
                Alexa / Google Home
                • CaptainZapC
                  CaptainZapC
                  CaptainZap
                  I had the same issue when using a CH340 nano clone... I had to get an FTDI based one, then worked without issues. Unlike you, I wasn't able to get my genuine Arduino uno to work with the plugin, even if I resolved the serial port detection.
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    @CaptainZap, my Uno R3 worked perfectly after I followed this post: http://forum.mysensors.org/topic/265/uno-as-a-serial-gateway-for-vera
                    Alexa / Google Home
                    • rvendrameR rvendrame
                      One more newbie here!
                      Despite my Vera (UI 1.5) recgonizes my Nano properly (I've set the serial to 115200 and so), start button at the UI doesn't work.
                      I'm able to put the gateway in inclusion mode by shorting pin3 to GND, or by typing '0;0;3;0;5;1' at the IDE serial monitor. The yellow led flashes slowly, while the gree led flashes quick, in sync with the sensor transmit messages.
                      At Vera IU (1.5), when I click on Start, the tx led flashes at nano, but the button itself don't activate (neither the gateway enter in inclusion mode).
                      Here's the gateway debug (in inclusion mode):
                      0;0;3;0;5;1
                      0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:255;255;3;0;3;
                      0;0;3;0;5;0
                      And here's the sensor debug (despite ID 255 is defined, it keeps requesting?)
                      req node id
                      send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
                      sensor started, id 255
                      req node id
                      req node id
                      req node id
                      req node id
                      req node id
                      req node id
                      Any help will be appreciated.
                      Thx
                      rvendrame
                      N
                      N
                      NotYetRated
                      wrote on last edited by NotYetRated
                      @rvendrame I have this issue with my Arduino Pro 5v's, (which I bought from the link in the MySensors store page). The only fix I have found is to manually define to node for those sensors. Annoying, but it works.
