  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
  • A adamp237
    I had this working perfectly on my Arduino Uno. I soldered it up to my Arduino Nano and it seems to work ok, but I'm not getting any data sent. The serial says it's connected OK but never sends any motion 1s or 0s. My MQTT server shows the following: Client mosqsub/3449-raspberryp received PUBLISH (d0, q0, r0, m0, 'mygateway1-out/255/255/3/0/3', ... (0 bytes))
    Any idea what is going on? I've tested the motion sensor separately and that is sending a high value to pin 3 no worries.
    @adamp237
    Enable debug on the node and add some more serial prints in order to see better in detail where the code runs and where not
      siddmon
      where can I find the picture for connecting NRF to arduino uno?
      • S siddmon
        @siddmon to my knowledge, Arduino Uno the same pins as on Arduino Nano, Arduino Pro Mini and all other atmega328-based Arduino boards.
          siddmon
          @mfalkvidd Thanks and yes, they have the same pins, I didn't see Uno in the table so I google it and got incorrect instructions.
          Now that I used the same as nano my node seems work :)
          • S siddmon
            @siddmon great! Thanks for reporting back.
            • nitroburnN
              nitroburnN
              nitroburn
              Little mistake in the text, I don't think dupont cables are made of bread.
              "the antenna need to be single core inside, only one wire, not multi-wire breaded like you can find in common dupont cable (not good for antenna.)"
              should be
              "The antenna need to be single core inside, only one wire, not multi-wire braided like you can find in common dupont cable (not good for antenna)"
              • nitroburnN nitroburn
                should be
                #80
                @nitroburn thanks! I've updated the page.
                nitroburnN 1 Reply Last reply
                  nitroburnN
                  nitroburnN
                  nitroburn
                  @mfalkvidd No problem, did make me a little hungry though.
                    :bread: :bread:
                    • G
                      G
                      Grave
                      Can anyone change the text for "Configuring MySensors for RFM69". When you want to use another pin for cs it´s not this code:
                      // #define RF69_SPI_CS 15 // If using a different CS pin for the SPI bus
                      but this
                      // #define My_RF69_SPI_CS 15 // If using a different CS pin for the SPI bus
                      • G Grave
                        but this
                        @Grave thanks for pointing this out. From looking at the source code, it looks like it should be MY_RFM69_CS_PIN. I have updated the text. Could you check if I got it right?
                        R 1 Reply Last reply
                        • G
                          G
                          Grave
                          Thanks, you are right.
                          • J
                            J
                            joseyapor
                            which one is better RFM69 or NRF24L01+
                              The problem is that nrf24 have many crappy clones that have limited range and it is difficult to find the original ones. Rfm69 is slower but have better wall penetration and modules come in 3 frequencies.
                              • sundberg84S
                                sundberg84S
                                #88
                                Nrf24l01+ also drains less current when sleeping vs RFM69
                                • J joseyapor
                                  @joseyapor neither is better. They are good at different things. See https://forum.mysensors.org/topic/3993/nordic-or-hoperf-radio/2 for an earlier discussion.
                                    R
                                    R
                                    RAD-X
                                    @mfalkvidd said in 💬 Connecting the Radio:
                                    It looks like that MY_RFM69_CS_PIN is used only in develop branch.
                                    Stable brach still using MY_RF69_SPI_CS.
                                    • R RAD-X
                                      #91
                                      @RAD-X both will work in the stable branch. See https://github.com/mysensors/MySensors/blob/28c4f3f19e7026f56fd9bbc61d566f770fd7a9d2/MyConfig.h#L935
                                        R
                                        R
                                        RAD-X
                                        @mfalkvidd
                                        Hmm.... Is not that a reference to the development branch? :-)
                                        I think that right content for stable branch is: https://github.com/mysensors/MySensors/blob/master/MyConfig.h
                                        If you don´t believe it, try to download a stable branch, unpack and search for string "MY_RFM69_CS_PIN".
                                        • R RAD-X
                                          @mfalkvidd
                                          #93
                                          @RAD-X yes, you are correct. Thanks for noticing.
                                          I thought that if I selected the master branch on github and used the search function, the search results would only show hits from the selected branch. But it seems like this is not the case.
                                          Linking to a specific line in a file doesn't work very well, because that line might move by later commits. That's why I select a specific commit to link to. But as you point out, my link points to a commit in the development branch.
                                          The correct link is https://github.com/mysensors/MySensors/blob/8bb3cfb2e14214ae19e8531c989d1e81c9660614/MyConfig.h#L663 and there is indeed no support for MY_RFM69_CS_PIN.
                                          I'll update the documentation again. The documentation is meant to reflect the current stable branch.
                                          EDIT: Found this in the Github documentation:
                                          Only the default branch is considered.
                                          So there is no way to search in the stable branch.
