  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
  • LaMB95L LaMB95
    @mfalkvidd Haha not really a 3.3 output I changed its input voltge to 3.3 hoping it would work.
    But nevertheless I managed to solve the issue.
    It seems to be an error in the Hardware serial.
    Refer: http://forum.arduino.cc/index.php?topic=46458.0
    The code bhagman has posted worked !
    LaMB95L
    LaMB95L
    LaMB95
    @mfalkvidd
    It worked yesterday now I am back to the same problem.
    What a wonder !
    • N
      N
      napo7
      Hi !
      It seems that the FRM69 library set the IRQ pin as optionnal. Can someone confirm that the IRQ pin is mandatory ?
      tekkaT 1 Reply Last reply
      • N napo7
        Hi !
        tekkaT
        tekkaT
        tekka
        @napo7 yes, it is mandatory since the driver is IRQ-dependent
        • N
          N
          napo7
          wrote on last edited by napo7
          #70
          Well, I had a look in RFM69 driver, and it seems that the interrupts handlers are never sets ?
          Am I wrong ?
          Edit : In facts, DIO0 is not used as an Interrupt source in RFM69 driver : it's a pin that informs the library that, either, a packet has been received, or , the frame we try to send has been sent.
          So, the code doesn't use interrupts, but this pin is more a "Data available" pin.
            @napo7
            so, if data available or data sent, this can be an interrupt source for an mcu ;)
            It's enabled in the init there https://github.com/mysensors/MySensors/blob/development/drivers/RFM69/RFM69.cpp#L123
            • N
              N
              napo7
              Yes I noticed it !
              Since it didn't mention IRQ pin, I didn't seen it at first !
              What misleaded me, is that on LowPowerLab forums, some users says that you can absolutely discard this interrupt and poll the radio frequently to ask if a packet is available.
              • A
                adamp237
                I had this working perfectly on my Arduino Uno. I soldered it up to my Arduino Nano and it seems to work ok, but I'm not getting any data sent. The serial says it's connected OK but never sends any motion 1s or 0s. My MQTT server shows the following: Client mosqsub/3449-raspberryp received PUBLISH (d0, q0, r0, m0, 'mygateway1-out/255/255/3/0/3', ... (0 bytes))
                Any idea what is going on? I've tested the motion sensor separately and that is sending a high value to pin 3 no worries.
                gohanG 1 Reply Last reply
                • A adamp237
                  @adamp237
                  Enable debug on the node and add some more serial prints in order to see better in detail where the code runs and where not
                    siddmon
                    where can I find the picture for connecting NRF to arduino uno?
                    • S siddmon
                      @siddmon to my knowledge, Arduino Uno the same pins as on Arduino Nano, Arduino Pro Mini and all other atmega328-based Arduino boards.
                        siddmon
                        @mfalkvidd Thanks and yes, they have the same pins, I didn't see Uno in the table so I google it and got incorrect instructions.
                        Now that I used the same as nano my node seems work :)
                        • S siddmon
                          @siddmon great! Thanks for reporting back.
                          • nitroburnN
                            nitroburnN
                            nitroburn
                            Little mistake in the text, I don't think dupont cables are made of bread.
                            "the antenna need to be single core inside, only one wire, not multi-wire breaded like you can find in common dupont cable (not good for antenna.)"
                            should be
                            "The antenna need to be single core inside, only one wire, not multi-wire braided like you can find in common dupont cable (not good for antenna)"
                            • nitroburnN nitroburn
                              should be
                              #80
                              @nitroburn thanks! I've updated the page.
                              nitroburnN 1 Reply Last reply
                                nitroburnN
                                nitroburnN
                                nitroburn
                                @mfalkvidd No problem, did make me a little hungry though.
                                  :bread: :bread:
                                  • G
                                    G
                                    Grave
                                    Can anyone change the text for "Configuring MySensors for RFM69". When you want to use another pin for cs it´s not this code:
                                    // #define RF69_SPI_CS 15 // If using a different CS pin for the SPI bus
                                    but this
                                    // #define My_RF69_SPI_CS 15 // If using a different CS pin for the SPI bus
                                    • G Grave
                                      but this
                                      @Grave thanks for pointing this out. From looking at the source code, it looks like it should be MY_RFM69_CS_PIN. I have updated the text. Could you check if I got it right?
                                      R 1 Reply Last reply
                                      • G
                                        G
                                        Grave
                                        Thanks, you are right.
                                        • J
                                          J
                                          joseyapor
                                          which one is better RFM69 or NRF24L01+
