  3. if `MY_NODE_ID` is not AUTO
6 Posts 3 Posters 1.9k Views 4 Watching
  • magicwM Offline
    magicwM Offline
    magicw
    if (MY_NODE_ID != AUTO) {
    	// Set static id
           _nc.nodeId = MY_NODE_ID;
    	// Save static id in eeprom
    	hwWriteConfig(EEPROM_NODE_ID_ADDRESS, MY_NODE_ID);
    In the stInitTransition function,if MY_NODE_ID is not AUTO,the code will write eeprom one time.if the node reset because some mistakes,It's to bad for the eeprom.Isn't it?
      What do you mean?
      • hekH Offline
        hekH Offline
        @magicw,
        It will only write to EEPROM if the value differs from the one already stored. So no, this won't affect EEPROM.
        magicwM 1 Reply Last reply
          @magicw,
          magicwM Offline
          magicwM Offline
          magicw
          @hek For example,If i define MY_NODE_ID is 2,When the node reset,,the logic of this code will write the eeprom again(hwWriteConfig(EEPROM_NODE_ID_ADDRESS, MY_NODE_ID);). Isn't it?
          • hekH Offline
            hekH Offline
            hwWriteConfig == eeprom_update_byte
            See doc:
            http://www.nongnu.org/avr-libc/user-manual/group__avr__eeprom.html
            update reads before writing
              See doc:
              magicwM Offline
              magicwM Offline
              magicw
              @magicw ok,thanks!
