  3. NodeManager
  4. SensorMotion to send both tripped and not tripped
39 Posts 6 Posters 12.4k Views 4 Watching
  • U
    U
    user2684
    I have a couple of AM312 sensors around here and they are working ok without any debounce or trigger time, I guess I've been just lucky :) The only issue I had has been a lot of false positives when placed outside and the light changing (e.g. the sun shines over them) but I think this is somehow expected.
    @mar.conte in your example you are creating a switch object, adjusting its settings but then NOT using it since when yo call register sensor it will create and register a new object :)
    Either you call register sensor and then retrive the object in this way:
    nodeManager.setSleep(SLEEP,60,MINUTES);
    sensor_id = nodeManager.registerSensor(SENSOR_MOTION,3);
    SensorMotion* sensorMotion = ((SensorMotion*)nodeManager.getSensor(sensor_id));
    sensorMotion->setDebounce(50);
    sensorMotion->setTriggerTime(4000);
    Or you create your own sensor, adjust the settings and register it by passing the object's instance but then you also need to setup the interrupt manually so I'd recommend the option just above. In your example (if this is what you are using) you basically have a standard sensor with neither debounce nor triggertime set :)
    • U user2684
      tubby
      @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
      I appreciate the help.
      Ive tried adding your code to my sketch but I get this error.
      Arduino: 1.8.1 (Windows 10), Board: "Arduino Nano, ATmega328"
      In file included from C:\Users\Daniel\Documents\NodeManager_testing_motion\NodeManager_testing_motion.ino:24:0:
      sketch\NodeManager.h:388:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
           char* _description = "";
      sketch\NodeManager.h:400:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
           char * _value_string = "";
      sketch\NodeManager.h:403:33: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
           char * _last_value_string = "";
      C:\Users\Daniel\Documents\NodeManager_testing_motion\NodeManager_testing_motion.ino: In function 'void before()':
      NodeManager_testing_motion:36: error: 'sensor_id' was not declared in this scope
      exit status 1
      'sensor_id' was not declared in this scope..
      Is the error that stops it from compiling, I always get the other errors when compiling but the sensor still works, tested on dht sensor (but this may be the problem)
      I'm guessing i'm missing something in the sketch.
      I'm really sorry for the pathetic questions.
      With this basic sketch:
      NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects.
      NodeManager includes the following main components:
      - Sleep manager: allows managing automatically the complexity behind battery-powered sensors spending most of their time sleeping
      - Power manager: allows powering on your sensors only while the node is awake
      - Battery manager: provides common functionalities to read and report the battery level
      - Remote configuration: allows configuring remotely the node without the need to have physical access to it
      - Built-in personalities: for the most common sensors, provide embedded code so to allow their configuration with a single line
      Documentation available on: https://github.com/mysensors/NodeManager
      // load user settings
      #include "config.h"
      // include supporting libraries
      #ifdef MY_GATEWAY_ESP8266
        #include <ESP8266WiFi.h>
      // load MySensors library
      // load NodeManager library
      #include "NodeManager.h"
      // create a NodeManager instance
      NodeManager nodeManager;
      // before
      void before() {
        Serial.begin(MY_BAUD_RATE);
         * Register below your sensors
        nodeManager.setSleep(SLEEP,1,MINUTES);
         * Register above your sensors
        nodeManager.before();
      // presentation
        nodeManager.presentation();
      // setup
        nodeManager.setup();
      // loop
        nodeManager.loop();
      // receive
        nodeManager.receive(message);
      // receiveTime
        nodeManager.receiveTime(ts);
      I get this node log on serial:
      3 MCO:BGN:BFR
      REG I=1 P=2 P=1 T=16
      NodeManager v1.5
      INT1 M=255
      INT2 M=3
      6 TSM:INIT
      10 TSF:WUR:MS=0
      17 TSM:INIT:TSP OK
      19 TSF:SID:OK,ID=1
      21 TSM:FPAR
      57 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      1125 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      1130 !TSF:MSG:PONG RECV,INACTIVE
      2064 !TSM:FPAR:NO REPLY
      2066 TSM:FPAR
      2102 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2120 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      2125 TSF:MSG:FPAR OK,ID=0,D=1
      3100 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      4110 TSM:FPAR:OK
      4111 TSM:ID
      4112 TSM:ID:OK
      4114 TSM:UPL
      4117 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      6124 TSM:UPL
      6126 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      6458 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      6463 TSF:MSG:PONG RECV,HP=1
      6465 TSM:UPL:OK
      6467 TSM:READY:ID=1,PAR=0,DIS=1
      6471 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      6478 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      6483 !TSF:MSG:PONG RECV,INACTIVE
      6490 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      6497 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
      6505 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      RADIO OK
      8513 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:NodeManager
      8522 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
      PRES I=200, T=23
      8563 !TSF:MSG:SEND,1-1-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
      PRES I=201, T=30
      8605 !TSF:MSG:SEND,1-1-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=NACK:
      BATT V=4.57 P=100
      SEND D=0 I=201 C=0 T=38 S= I=0 F=4.57
      8683 !MCO:SND:NODE NOT REG
      8725 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=2,st=NACK:100
      PRES I=1 T=1
      8767 !TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=3,st=NACK:
      READY
      8773 MCO:REG:REQ
      8811 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
      10818 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=OK:2
      12825 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      13209 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      13214 MCO:PIM:NODE REG=1
      13216 MCO:BGN:STP
      MY I=1 M=1
      13218 MCO:BGN:INIT OK,TSP=1
      SLEEP 60s
      13222 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      13230 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:12
      13236 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      13241 MCO:PIM:NODE REG=1
      13736 MCO:SLP:TPD
      13737 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      13741 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      13748 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:530
      14254 MCO:SLP:TPD
      14255 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      14258 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      14265 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1047
      14772 MCO:SLP:TPD
      14773 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      14776 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      14783 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1565
      15290 MCO:SLP:TPD
      15291 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      15294 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      15337 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:2083
      15843 MCO:SLP:TPD
      15844 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      15847 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      15890 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=1,st=NACK:2636
      16396 MCO:SLP:TPD
      16397 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      16400 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      16443 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=2,st=NACK:3189
      16949 MCO:SLP:TPD
      16950 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      16953 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      16960 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=3,st=OK:3742
      17467 MCO:SLP:TPD
      17468 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      17471 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      17478 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4260
      17985 MCO:SLP:TPD
      17986 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      17989 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      17996 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4778
      18503 MCO:SLP:TPD
      18504 MCO:SLP:WUP=-2
      AWAKE
      BATT V=4.61 P=100
      SEND D=0 I=201 C=0 T=38 S= I=0 F=4.61
      18615 !TSF:MSG:SEND,1-1-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=NACK:4.61
      18658 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=NACK:100
      SLEEP 60s
      18665 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      18707 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=2,st=NACK:5454
      19214 MCO:SLP:TPD
      19215 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      19218 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      19261 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=3,st=NACK:6007
      19767 MCO:SLP:TPD
      19768 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      19771 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
      19814 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=4,st=NACK:6560
      20320 MCO:SLP:TPD
      20321 MCO:SLP:WUP=-2
      AWAKE
      SLEEP 60s
      I know I'm loosing a lot of communication but, I'm just trying to test at the moment.
      Oh and I don't have any sensors connected to this node at the moment, so there is no PIR sending pin high.
      the voltage between ground and pin 2 is 0.28v
      I'm really struggling with this.
      If I run the mysensors example it works as expected.
      any help would be much appreciated
      U 1 Reply Last reply
      • T tubby
        exit status 1
        #include "config.h"
        // before
        void before() {
        // presentation
        // setup
        // loop
          nodeManager.loop();
        // receive
        // receiveTime
        3 MCO:BGN:BFR
        NodeManager v1.5
        INT1 M=255
        INT2 M=3
        6 TSM:INIT
        10 TSF:WUR:MS=0
        17 TSM:INIT:TSP OK
        19 TSF:SID:OK,ID=1
        21 TSM:FPAR
        2066 TSM:FPAR
        4110 TSM:FPAR:OK
        4111 TSM:ID
        4112 TSM:ID:OK
        4114 TSM:UPL
        6124 TSM:UPL
        6465 TSM:UPL:OK
        RADIO OK
        PRES I=200, T=23
        PRES I=201, T=30
        BATT V=4.57 P=100
        PRES I=1 T=1
        READY
        8773 MCO:REG:REQ
        13216 MCO:BGN:STP
        MY I=1 M=1
        SLEEP 60s
        13736 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        14254 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        14772 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        15290 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        15843 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        16396 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        16949 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        17467 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        17985 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        18503 MCO:SLP:TPD
        AWAKE
        BATT V=4.61 P=100
        SLEEP 60s
        19214 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        19767 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        20320 MCO:SLP:TPD
        AWAKE
        SLEEP 60s
        U
        U
        user2684
        @tubby said in NodeManager: plugin for a rapid development of battery-powered sensors:
        sorry my bad, I should have tested the code before pasting it here :-(
        That sensor_id = nodeManager.registerSensor(SENSOR_MOTION,3); should be a int sensor_id = nodeManager.registerSensor(SENSOR_MOTION,3);
        I forgot an int.
        • U user2684
          I forgot an int.
          tubby
          @user2684 thanks mate.
          Ill try that tommorrow.
          Really wish I know how to code, but I just don't know where to start.
          • T
            tubby
            Thanks guys got it running.
            after a lot of stuffing around
            the problem I'm having now is the controller always say that its tipped (Using home assistant)
            It looks to me that the node doesn't send an off trip, only an on.
            here is my node output
            3 MCO:BGN:BFR
            REG I=1 P=3 P=1 T=16
            NodeManager v1.5
            INT1 M=3
            INT2 M=255
            6 TSM:INIT
            10 TSF:WUR:MS=0
            17 TSM:INIT:TSP OK
            19 TSF:SID:OK,ID=1
            21 TSM:FPAR
            2066 TSM:FPAR
            2928 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            2933 TSF:MSG:FPAR OK,ID=0,D=1
            4110 TSM:FPAR:OK
            4111 TSM:ID
            4112 TSM:ID:OK
            4114 TSM:UPL
            4126 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            4131 TSF:MSG:PONG RECV,HP=1
            4134 TSM:UPL:OK
            4135 TSM:READY:ID=1,PAR=0,DIS=1
            4141 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            4147 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            4154 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
            4163 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            4802 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            RADIO OK
            4809 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:NodeManager
            4818 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
            PRES I=200, T=23
            4827 TSF:MSG:SEND,1-1-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
            PRES I=201, T=30
            4835 TSF:MSG:SEND,1-1-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
            BATT V=4.57 P=100
            4912 !MCO:SND:NODE NOT REG
            4920 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:100
            PRES I=1 T=1
            4928 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            READY
            4934 MCO:REG:REQ
            4937 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            4951 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            4956 MCO:PIM:NODE REG=1
            4958 MCO:BGN:STP
            MY I=1 M=1
            4960 MCO:BGN:INIT OK,TSP=1
            SWITCH I=1 P=3 V=1
            SEND D=0 I=1 C=0 T=16 S= I=1 F=0.00
            4966 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            4973 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
            4980 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:21
            5487 MCO:SLP:TPD
            5488 MCO:SLP:WUP=1
            WAKE P=3, M=3
            AWAKE
            SWITCH I=1 P=3 V=1
            SEND D=0 I=1 C=1 T=16 S= I=1 F=0.00
            5493 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            5502 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
            5510 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:551
            6017 MCO:SLP:TPD
            6018 MCO:SLP:WUP=1
            WAKE P=3, M=3
            AWAKE
            SWITCH I=1 P=3 V=1
            6023 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            6032 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
            6039 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1080
            6546 MCO:SLP:TPD
            6547 MCO:SLP:WUP=1
            WAKE P=3, M=3
            AWAKE
            SWITCH I=1 P=3 V=1
            6552 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            6561 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
            6568 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1609
            7076 MCO:SLP:TPD
            7077 MCO:SLP:WUP=1
            WAKE P=3, M=3
            AWAKE
            SWITCH I=1 P=3 V=1
            7083 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            7092 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
            7099 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2140
            7606 MCO:SLP:TPD
            7607 MCO:SLP:WUP=1
            WAKE P=3, M=3
            AWAKE
            SWITCH I=1 P=3 V=1
            7612 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            7621 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
            7628 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2669
            8135 MCO:SLP:TPD
            8136 MCO:SLP:WUP=1
            WAKE P=3, M=3
            AWAKE
            SWITCH I=1 P=3 V=1
            8141 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            8151 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
            8158 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:3199
            8665 MCO:SLP:TPD
            8666 MCO:SLP:WUP=1
            WAKE P=3, M=3
            AWAKE
            SWITCH I=1 P=3 V=1
            8671 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
            SLEEP 60s
            is this correct? Looks to me that the node sends a (1) when tripped but not a (0) when motion stops.
            This makes my controller think that there is constant motion
            • T tubby
              3 MCO:BGN:BFR
              NodeManager v1.5
              INT1 M=3
              INT2 M=255
              6 TSM:INIT
              10 TSF:WUR:MS=0
              17 TSM:INIT:TSP OK
              19 TSF:SID:OK,ID=1
              21 TSM:FPAR
              2066 TSM:FPAR
              4110 TSM:FPAR:OK
              4111 TSM:ID
              4112 TSM:ID:OK
              4114 TSM:UPL
              4134 TSM:UPL:OK
              RADIO OK
              PRES I=200, T=23
              PRES I=201, T=30
              BATT V=4.57 P=100
              PRES I=1 T=1
              READY
              4934 MCO:REG:REQ
              4958 MCO:BGN:STP
              MY I=1 M=1
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              5487 MCO:SLP:TPD
              5488 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              6017 MCO:SLP:TPD
              6018 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              6546 MCO:SLP:TPD
              6547 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              7076 MCO:SLP:TPD
              7077 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              7606 MCO:SLP:TPD
              7607 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              8135 MCO:SLP:TPD
              8136 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              8665 MCO:SLP:TPD
              8666 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SLEEP 60s
              U
              U
              user2684
              @tubby SENSOR_MOTION reacts on RISING only so you will not get the low tripped. Try adding the following:
              sensorMotion->setInitial(LOW);
              sensorMotion->setMode(CHANGE);
              This should send a message on both RISING and FALLING.
              • U user2684
                tubby
                @user2684 I really appreciate the help.
                and now I'm able to use all the extra inbuilt features of the code, now that i know how to add them to the sketch.
                And I hate to be a pain but I cant seem to get this damn motion sensor to work properly.
                I've tried the examples you have given me, I've played around with every possible thing I can think/read.
                But for the life of me cant get it to send a (0) for non tripped.
                I assume the (CHANGE) interrupt option should be sending a msg on a motion detect ie: (1)
                and then when the pin goes low it should send a (0), but it seem that the node has already gone to sleep and the changed state is not being recorded.
                What else could I try?
                • T tubby
                  U
                  U
                  user2684
                  Correct, when mode is set to CHANGE, the node wakes up with both RISING (0 to 1) or FALLING (1 to 0) interrupts and regardless of the value previously sent, the pin's value is read again and a new message sent back to the gw. The only situation I think this would not work is when the node is NOT sleeping since the interrupt is configured only before entering a sleeping cycle. So if you have a 1 and then immediately a 0, the node has not entered the sleep cycle so the interrupt is lost. For how long does the pin stays to 1 after triggering the motion? Thanks
                  T gohanG 2 Replies Last reply
                  • U user2684
                    tubby
                    @user2684 exactly what I thought about the (change) .
                    I have a test rig setup at the moment and I have been pulling the pin high and low manually with a jumper wire.
                    I've held the pin high for up to 30 seconds.
                    The node sends a high value. Than the sleep msg.
                    Up to 30 seconds latter I disconnect the high and connect to low but nothing happens, the node just sleeps either till the amount in the timer or if the pin is pulled high again.
                    I imagine this is the sort of behaviour you would see with a (rising) state
                    • U user2684
                      @user2684 It is an issue I discussed some time ago and a solution was to set a shorter sleep time when the pin was high so it could report the pin low within a reasonable amount of time and then sleep normally.
                        tubby
                        @gohan How would I implement that?
                        I only see options for overall sleep time, none that allow me different sleep time for only when the pin is high.
                        I'm sorry for all these questions, I feel like an idiot, but I'm so close to getting all the sensors that I need on one board. That I would have no hope of configuring without node manager.
                        One hurdle left...
                          one way would be to use the sleep time as a variable that you can change it to 5000 when the pin goes high and back to the original value when pin goes low with a normal IF statement
                          • U
                            U
                            user2684
                            @gohan I may have probably missed this one sorry. Did you just shorten the debounce time? My guess @tubby is that you are sleeping for too long after the tripped message. When you say sensorMotion->setTriggerTime(4000);, the node will do nothing for 4 seconds after the "on" message. If the "off" happens during those 4 seconds, the event will be lost. Try lowering this down a bit or compare it with the time it takes for the signal to be restored to low. Thanks
                            • U
                              U
                              user2684
                              Hi, I finally got a chance to run some more tests but I see the expected behavior even if here looks like different people are experiencing the opposite.
                              This is my sketch:
                              nodeManager.setSleep(SLEEP, 30, MINUTES);
                                int sensorPIR_Id = nodeManager.registerSensor(SENSOR_MOTION,3);
                                SensorMotion* sensorMotion = (SensorMotion*)nodeManager.getSensor(sensorPIR_Id);
                              And those are my logs:
                              WAKE P=3, M=1
                              AWAKE
                              SWITCH I=1 P=3 V=1
                              SLEEP 1800s
                              WAKE P=3, M=1
                              AWAKE
                              SWITCH I=1 P=3 V=0
                              SEND D=0 I=1 C=1 T=16 S= I=0 F=0.00
                              SLEEP 1800s
                              As you can see as motion is detected a 1 is reported (and the board goes to sleep), after a couple of seconds the board wakes up to report the 0.
                              I'm not using debounce or trigger time here which instead may have an impact (both debounce and trigger time puts the board to sleep and if the signal changes during it, the interrupt will be lost).
                              Let me know if I'm doing something different.
                              • Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                In fact, what I experience is something different. Sensor detects movement so wakes, but it still wakes every 3sec until low threshold is sent back from the pir:
                                WAKE P=3, M=3
                                AWAKE
                                ON P=5
                                SWITCH I=1 P=3 V=1
                                OFF P=5
                                SLEEP 60
                                WAKE P=3, M=3
                                AWAKE
                                ON P=5
                                SWITCH I=1 P=3 V=1
                                OFF P=5
                                SLEEP 60
                                WAKE P=3, M=3
                                AWAKE
                                ON P=5
                                SWITCH I=1 P=3 V=1
                                OFF P=5
                                SLEEP 60
                                WAKE P=3, M=3
                                AWAKE
                                ON P=5
                                SWITCH I=1 P=3 V=1
                                OFF P=5
                                SLEEP 60
                                WAKE P=3, M=3
                                AWAKE
                                ON P=5
                                SWITCH I=1 P=3 V=1
                                OFF P=5
                                SLEEP 60
                                WAKE P=3, M=3
                                AWAKE
                                BATT V=3.12 P=73
                                SEND D=0 I=201 C=0 T=38 S= I=0 F=3.12
                                ON P=5
                                SWITCH I=1 P=3 V=0
                                OFF P=5
                                SLEEP 60
                                So I don't know if the "low" is triggering or simply it stops querying when the value is low.
                                • Sergio RiusS Sergio Rius
                                  WAKE P=3, M=3
                                  AWAKE
                                  ON P=5
                                  SWITCH I=1 P=3 V=1
                                  OFF P=5
                                  SLEEP 60
                                  WAKE P=3, M=3
                                  AWAKE
                                  ON P=5
                                  SWITCH I=1 P=3 V=1
                                  OFF P=5
                                  SLEEP 60
                                  WAKE P=3, M=3
                                  AWAKE
                                  ON P=5
                                  SWITCH I=1 P=3 V=1
                                  OFF P=5
                                  SLEEP 60
                                  WAKE P=3, M=3
                                  AWAKE
                                  ON P=5
                                  SWITCH I=1 P=3 V=1
                                  OFF P=5
                                  SLEEP 60
                                  WAKE P=3, M=3
                                  AWAKE
                                  ON P=5
                                  SWITCH I=1 P=3 V=1
                                  OFF P=5
                                  SLEEP 60
                                  WAKE P=3, M=3
                                  AWAKE
                                  BATT V=3.12 P=73
                                  ON P=5
                                  SWITCH I=1 P=3 V=0
                                  OFF P=5
                                  SLEEP 60
                                  U
                                  U
                                  user2684
                                  @Sergio-Rius got it but that's really weird. If we assume when the board wakes up the first time the signal stays HIGH for a while, when goes back to sleep there should not be any interrupt unless the signal continuously moves between LOW and HIGH. I'd try the following: first of all remove the power pin (it should not matter but better removing any background noise) and second, check with a multimeter how the signal really behaves.
                                  PS. Are you using CHANGE or RISING?
                                  • U user2684
                                    Sergio RiusS
                                    Sergio RiusS
                                    Sergio Rius
                                    #22
                                    @user2684
                                    I'm using CHANGE. What do you mean with remove the power pin? Cutting power to the sensor? Pulling the signal cable and testing it with a multimeter?
                                    I have a led wired in parallel that lights when the sensor sends high. I can't see anything strange.
                                      @user2684
                                      U
                                      U
                                      user2684
                                      @Sergio-Rius I meant just registering the pir and not the other sensor (a DHT if remember correctly) and avoid using setPowerPins(). Just to keep it simple and ensure there are no other variables influencing the test for now. Good to know the led is telling you the signal stays high consistently, we need to know now why the board gets the interrupt while it shouldn't :)
                                      • Sergio RiusS
                                        Sergio RiusS
                                        Sergio Rius
                                        #24
                                        Deactivating all the modules and sensors except the PIR, revealed that the node still wasn't detecting the low signal. The sensor is configured with approx. 30sec reset delay.
                                          nodeManager.setSleep(SLEEP, 60, SECONDS);
                                        Here is a sample debug output from nodemanager:
                                        NodeManager v1.5
                                        INT1 M=3
                                        INT2 M=255
                                        RADIO OK
                                        PRES I=200, T=23
                                        PRES I=1 T=1
                                        READY
                                        MY I=3 M=1
                                        SWITCH I=1 P=3 V=0
                                        SEND D=0 I=1 C=0 T=16 S= I=0 F=0.00
                                        SLEEP 60
                                        <= HERE I PUT MY FINGER ON SENSOR
                                        WAKE P=3, M=3
                                        AWAKE
                                        SWITCH I=1 P=3 V=1
                                        SLEEP 60
                                        **HERE LOW CONDITION HAPPENED**
                                        WAKE P=3, M=3
                                        AWAKE
                                        SWITCH I=1 P=3 V=1
                                        SLEEP 60
                                        **Nothing happens until sleep cycle ends**
                                        AWAKE
                                        SWITCH I=1 P=3 V=0
                                        SLEEP 60
                                        AWAKE
                                        SWITCH I=1 P=3 V=0
                                        SLEEP 60
                                        The same hardware, using my custom sketch, just works properly. There's the output. It's configured to sleep 10min between ambient measurements, wake on pir (M:) high and low. The graph at the end of the lines shows time request and reception and multiple measurements with running average.
                                        Initialising...
                                        Update interval: 10 min (600000 ms)
                                        Sampling size: 5 samples
                                        Ready!
                                        ?......!0*1*2*3*4*
                                        [7:13:11:01][M: 0][BAT: 3252mV / 96% ][T:*25.50º / H:*59.84% ]  SLEEP! ?0*!1*2*3*4*
                                        [7:13:13:10][M: 1][BAT: 3261mV / 97% ][T: 25.50º / H:*59.64% ]  SLEEP! ?0*!1*2*3*4*
                                        [7:13:13:28][M: 0][BAT: 3261mV / 97% ][T:*25.54º / H:*59.62% ]  SLEEP! ?0*!1*2*3*4*
                                        [7:13:15:32][M: 1][BAT: 3261mV / 97% ][T:*25.60º / H:*59.40% ]  SLEEP! ?0*!1*2*3*4*
                                        [7:13:15:52][M: 0][BAT: 3261mV / 97% ][T: 25.60º / H:*59.42% ]  SLEEP! ?0*!1*2*3*4*
                                        [7:13:16:41][M: 1][BAT: 3261mV / 97% ][T: 25.60º / H:*59.66% ]  SLEEP! ?0*!1*2*3*4*
                                        [7:13:17:01][M: 0][BAT: 3261mV / 97% ][T: 25.60º / H:*59.64% ]  SLEEP! ?0*!1*2*3*4*
                                        [7:13:28:20][M: 0][BAT: 3261mV / 97% ][T:*25.50º / H:*59.90% ]  SLEEP!
                                        I'm trying to find the NM problem by debugging it but I just can't find anything relevant. Perhaps we should reduce the code to only movement fuctionality... Perhaps some debounce functionality that interferes even being deactivated (thinking aloud)
                                          NodeManager v1.5
                                          INT1 M=3
                                          INT2 M=255
                                          RADIO OK
                                          PRES I=200, T=23
                                          PRES I=1 T=1
                                          READY
                                          MY I=3 M=1
                                          SWITCH I=1 P=3 V=0
                                          SLEEP 60
                                          WAKE P=3, M=3
                                          AWAKE
                                          SWITCH I=1 P=3 V=1
                                          SLEEP 60
                                          WAKE P=3, M=3
                                          AWAKE
                                          SWITCH I=1 P=3 V=1
                                          SLEEP 60
                                          AWAKE
                                          SWITCH I=1 P=3 V=0
                                          SLEEP 60
                                          AWAKE
                                          SWITCH I=1 P=3 V=0
                                          SLEEP 60
                                          Initialising...
                                          Ready!
                                          ?......!0*1*2*3*4*
                                          U
                                          U
                                          user2684
                                          wrote on last edited by user2684
                                          #25
                                          @Sergio-Rius thanks a lot for the debugging so far. The only difference I clearly see is the mode which is reported when waking up. In your case is always 3 (RISING), in mine and with your custom sketch is instead 1 (CHANGE). Would you mind commenting out setMode(RISING) in the constructor of SensorMotion in your NodeManager.cpp?
                                          My concern is that with v1.5 setMode just changing the local variable and not the interrupt's setting which is what is used to wake up when passing it to MySensors' sleep(). The other try would be to see if with https://github.com/mysensors/NodeManager/tree/development the situation changed since that part of the code has been almost completely rewritten.
                                          Sergio RiusS 2 Replies Last reply
