  3. SensebenderMicro with two additional DS18b20
6 Posts 2 Posters 1.8k Views 3 Watching
  • HarrySteffH
    HarrySteffH
    HarrySteff
    Dear experts, i have a problem with my sensebender micro with two additional DS18B20 Sensors. Since i upgraded the sketch from Version 1.5 to 2.1.1 the DS18b20 Sensors sends their temperature Values for about one hour or something like that and after this they did not send anymore. But the internal Temperature and Humidity Sensors (from Sensebender) does send the whole time... Can anybody helb me with this strange behavior? Here is my Sketch:
    // Define a static node address, remove if you want auto address assignment
    #define MY_NODE_ID 15
    // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
    #include <OneWire.h>
    #include <SI7021.h>
    #ifndef MY_OTA_FIRMWARE_FEATURE
    #include "drivers/SPIFlash/SPIFlash.cpp"
    #include <EEPROM.h>
    #include <sha204_lib_return_codes.h>
    #include <sha204_library.h>
    #include <RunningAverage.h>
    #define ONE_WIRE_BUS 7 // Pin where dallase sensor is connected
    float lastTemperatureDA[MAX_ATTACHED_DS18B20];
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    // Uncomment the line below, to transmit battery voltage as a normal sensor value
    //#define BATT_SENSOR    199
    #define RELEASE "2.1.1"
    #define AVERAGES 2
    // Child sensor ID's
    #define CHILD_ID_TEMP  3
    #define CHILD_ID_HUM   4
    // How many milli seconds should we wait for OTA?
    #define OTA_WAIT_PERIOD 300
    #define FORCE_TRANSMIT_INTERVAL 30
    // Pin definitions
    #define TEST_PIN       A0
    #define LED_PIN        A2
    #define ATSHA204_PIN   17 // A3
    const int sha204Pin = ATSHA204_PIN;
    SI7021 humiditySensor;
    SPIFlash flash(8, 0x1F65);
    // Sensor messages
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
    // Global settings
    int measureCount = 0;
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    boolean transmission_occured = false;
    float lastTemperatureSB = -100;
    int lastHumidity = -100;
    long lastBattery = -100;
    void before()
      sensors.begin();
     * Setup code
      pinMode(LED_PIN, OUTPUT);
      digitalWrite(LED_PIN, LOW);
      Serial.print(RELEASE);
      Serial.flush();
      // First check if we should boot into test mode
      pinMode(TEST_PIN,INPUT);
      digitalWrite(TEST_PIN, HIGH); // Enable pullup
      if (!digitalRead(TEST_PIN)) testMode();
      // Make sure that ATSHA204 is not floating
      pinMode(ATSHA204_PIN, INPUT);
      digitalWrite(ATSHA204_PIN, HIGH);
      digitalWrite(TEST_PIN,LOW);
      digitalWrite(LED_PIN, HIGH);
      humiditySensor.begin();
      Serial.flush();
      isMetric = getControllerConfig().isMetric;
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      raHum.clear();
      sendTempHumidityMeasurements(false);
      sendBattLevel(false);
    #ifdef MY_OTA_FIRMWARE_FEATURE
      Serial.println("OTA FW update enabled");
    void presentation()  {
      sendSketchInfo("Sensebender Micro", RELEASE);
      present(CHILD_ID_TEMP,S_TEMP);
      present(CHILD_ID_HUM,S_HUM);
    #ifdef BATT_SENSOR
      present(BATT_SENSOR, S_POWER);
         present(i, S_TEMP);
     *  Main loop function
      measureCount ++;
      sendBattery ++;
      bool forceTransmit = false;
        highfreq = false;
      if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
        forceTransmit = true;
        measureCount = 0;
    /*  if (sendBattery > 60)
         sendBattLevel(forceTransmit); // Not needed to send battery info that often
         sendBattery = 0;
      if (transmission_occured) {
          wait(OTA_WAIT_PERIOD);
      //NEW* int16_t conversionTime = millisToWaitForConversion(sensors.getResolution());
      sleep(conversionTime);
        float temperatureDA = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        if (lastTemperatureDA[i] != temperatureDA && temperatureDA != -127.00 && temperatureDA != 85.00) {
        if (temperatureDA != -127.00 && temperatureDA != 85.00) {
        Serial.print("T.DA: ");Serial.println(sensors.getTempCByIndex(i));
          send(msg.setSensor(i).set(temperatureDA,1));
          lastTemperatureDA[i]=temperatureDA;
      sleep(MEASURE_INTERVAL);
     * Sends temperature and humidity from Si7021 sensor
     * Parameters
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperatureSB - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        float temperatureSB = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        Serial.print("T: ");Serial.println(temperatureSB);
        Serial.print("H: ");Serial.println(humidity);
        send(msgTemp.set(temperatureSB,1));
        send(msgHum.set(humidity));
        lastTemperatureSB = temperatureSB;
        lastHumidity = humidity;
        transmission_occured = true;
        if (sendBattery > 60) {
         sendBattLevel(true); // Not needed to send battery info that often
         sendBattery = 0;
     * Parameters
      if (force) lastBattery = -1;
      long vcc = readVcc();
      if (vcc != lastBattery) {
        lastBattery = vcc;
    #ifdef BATT_SENSOR
        float send_voltage = float(vcc)/1000.0f;
        send(msgBatt.set(send_voltage,3));
        // Calculate percentage
        long percent = vcc / 14.0;
        sendBatteryLevel(percent);
    long readVcc() {
     * Verify all peripherals, and signal via the LED if any problems.
    void testMode()
      uint8_t ret_code;
      byte tests = 0;
      digitalWrite(LED_PIN, HIGH); // Turn on LED.
      Serial.println(F(" - TestMode"));
      Serial.println(F("Testing peripherals!"));
      Serial.flush();
      Serial.print(F("-> SI7021 : "));
      Serial.flush();
      if (humiditySensor.begin())
        Serial.println(F("ok!"));
        tests ++;
        Serial.println(F("failed!"));
      Serial.flush();
      Serial.print(F("-> Flash : "));
      Serial.flush();
      if (flash.initialize())
        tests ++;
      Serial.flush();
      Serial.print(F("-> SHA204 : "));
      Serial.flush();
      if (ret_code != SHA204_SUCCESS)
        Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
      Serial.flush();
      if (ret_code == SHA204_SUCCESS)
        ret_code = sha204.getSerialNumber(rx_buffer);
          Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
          Serial.print(F("Ok (serial : "));
          for (int i=0; i<9; i++)
            if (rx_buffer[i] < 0x10)
            Serial.print(rx_buffer[i], HEX);
          Serial.println(")");
          tests ++;
      Serial.flush();
      Serial.println(F("Test finished"));
      if (tests == 3)
        Serial.println(F("Selftest ok!"));
        while (1) // Blink OK pattern!
          delay(200);
          delay(200);
        Serial.println(F("----> Selftest failed!"));
        while (1) // Blink FAILED pattern! Rappidly blinking..
    Thank you very much in advance.
    Steff
    • HarrySteffH
      HarrySteffH
      HarrySteff
      It is so strange... today i did some more tests... connected to serialmonitor... at the beginning all seems running correct but after a Little while i only see squares in my serial monitor output... BUT... again temperature and humidity from internal Sensors of sensebender are transmitted, only the two ds18b20 sensors did Not send anymore... i don't know what i can do now :-( Hope anybody can help me.... thanks again
      • HarrySteffH
        HarrySteffH
        HarrySteff
        I did some more tests, this is what i get in serial monitor:
        15017 TSF:MSG:SEND,15-15-0-0,s=3,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.0
        15026 TSF:MSG:SEND,15-15-0-0,s=4,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:45
        15034 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
        15039 MCO:SLP:TPD
        15041 MCO:SLP:WUP=-1
        15112 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        15117 MCO:SLP:TPD
        15118 MCO:SLP:WUP=-1
        TempDiff :0.01
        HumDiff  :0.00
        15133 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
        15138 MCO:SLP:TPD
        15139 MCO:SLP:WUP=-1
        T.DA: 26.19
        15253 TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.1
        15259 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        15264 MCO:SLP:TPD
        15266 MCO:SLP:WUP=-1
        TempDiff :0.05
        HumDiff  :0.50
        15281 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
        15286 MCO:SLP:TPD
        15288 MCO:SLP:WUP=-1
        15358 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        15364 MCO:SLP:TPD
        15366 MCO:SLP:WUP=-1
        TempDiff :0.02
        HumDiff  :0.50
        15380 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
        15385 MCO:SLP:TPD
        15386 MCO:SLP:WUP=-1
        T.DA: 25.94
        15444 TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.9
        15492 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        15497 MCO:SLP:TPD
        15499 MCO:SLP:WUP=-1
        TempDiff :0.11
        HumDiff  :0.50
        15514 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
        15518 MCO:SLP:TPD
        15520 MCO:SLP:WUP=-1
        15591 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
        15596 MCO:SLP:TPD
        15598 MCO:SLP:WUP=-1
        After this i only get those little squares... and no more data are send... I have no more idea what to do... :-(
        • tbowmoT
          tbowmoT
          tbowmo
          @HarrySteff said in SensebenderMicro with two additional DS18b20:
          Try and remove the following lines from your sketch:
               highfreq = false;
          This switches to a lower frequency after approximately 5 minutes, this messes up the timing, which I normally don't care about with the Si7021 temperature sensor, but the DS1820 needs "precise" timing, to communicate, as it uses bit banging..
          • HarrySteffH
            HarrySteffH
            HarrySteff
            @tbowmo WOW you are my hero... after a couple of test it seems working now... THANK YOU SO MUCH... I will try it now for a longer time THANKS again!
            • HarrySteffH
              HarrySteffH
              HarrySteff
              Again, that was it! @tbowmo Thank you again so much! Everything is running smoothly :-)
