  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
  • C
    C
    ceech
    And if it is too tall, still, only two capacitors can be installed in horizontal position, or even just one.
    alexsh1A 1 Reply Last reply
    • C ceech
      alexsh1A
      alexsh1A
      alexsh1
      #151
      @ceech How about a flat supercap like this:
      https://www.digikey.co.uk/product-detail/en/vishay-bc-components/MAL219691252E3/4699PHBK-ND/5015883
      There is no need to have two in my view unless you want to raise voltage. One flat to make the board compact may be enough.
      • C
        C
        ceech
        Flat ones are nice. Nice package. High internal resistance, therefore low current. The double cell 15F flat capacitor can only supply 70mA.
          This is great. :+1: Maybe more people will start playing with this stuff if they can buy inexpensive pre-made boards from ceech. The more, the merrier. :)
          • C ceech
            alexsh1A
            alexsh1A
            alexsh1
            @ceech said iThe double cell 15F flat capacitor can only supply 70mA.
            It should be enough if not using nrf24l01+ pa lna or rfm69HW. In this case perhaps, it would be better to have 150mA at least to cover those transmitters?
            I like the size - It is really flat.
            • alexsh1A alexsh1
              @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
              If you start to get choosy, that's when it's time to start making your own boards. It's easier than you might think. Otherwise, you just have to accept that the off-the-shelf stuff will never be exactly what you want.
              It's really too bad there isn't more of a universal PCB format that's easily edited, so you can simply start with a board that's close to what you want and just customize it a bit (the way one might with, say, software). For instance, even just changing LDO's--unless the new LDO has exactly the same land pattern--can necessitate redoing the board. No problem if you're the original designer, but it's a PITA if you aren't.
                #156
                I received the Chinese supercaps today. My "el cheapo" component tester is, I guess, too cheap, because it can't identify them:
                So, if anyone has suggestions for a good capacitor tester, let me know.
                However, I did plug the first one into my solar node after charging it ,and, so far it's not holding it's charge very well at all. I'll try the green one next.
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @NeverDie I just watched this video:
                  https://youtu.be/EKRZEc-4SBo
                  Is this what you have been looking?
                  • alexsh1A alexsh1
                    #158
                    @alexsh1
                    I like Julien's videos, butI'd find something that's faster and more automated to be preferable, as well as something that can measure ESR too.
                      #159
                      Well, so far the green supercap isn't holding its charge any better. I'll leave it in-circuit for two or three days, though, and see if that improves. It's encouraging that the rate of voltage decrease is decreasing. Some supercaps apparently improve their ability to retain charge if they are forced to hold a charge long enough, though I have no idea why that is. For instance, some capacitor leakage test protocols call for holding a capacitor at its rated voltage for 72 hours before running the leakage test.
                      alexsh1A NeverDieN 2 Replies Last reply
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #160
                        @NeverDie you are right - Nick Gammon states exactly the same that overtime leakage "improves". A new cap has to be broken in before leakage is measured.
                        ESR measurement - I have no idea if it is possible to measure it and how. I think right now we are going down deep into the physics in order to do that
                          #161
                          For more normal capacitors (though apparently not for 10F supercaps), the little gizmo I showed in the pictures above does measure and display the ESR. That's one of the main reasons I purchased it. It's probably not hard to measure either. Measure the unloaded voltage. Then measure the voltage under, say, 1 amp of current. The second voltage measurement will be less, and from that you can calculate the ESR. At least, that's how I'm guessing it's done. Except you'd near to do a near instantaneous measurement, because the longer you drain the current, the more the voltage goes down for that reason too, not just ESR.
                            #162
                            Incredibly, I may have to resort to the Julien Ilett method of measuring capacitance. None of the meters or testers I've seen thus far handle supercapacitor capacitance (e.g. 10F). So, thanks for posting the video! Very timely.
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #163
                              @NeverDie the old fashioned way! ;-)
                              Glad we are doing or reading about the same things at the same time.
                              How long does it take for your device to measure ESR? Did you try a normal capacitor, I.e. 100uF?
                              • alexsh1A alexsh1
                                #164
                                Yes. About 5 seconds.
                                [Edit: that includes the time it also takes to measure capacitance. It does both measurements (including part type identification) at the push of the button. ]
                                  Maybe it is just outside of the measurable range of the meter.
                                    Is there a way to do a full disconnect of the solar panel (so as to do an unloaded voltage measurement) without resorting to a relay? I've tried using a PFET, and although it can turn off the current flowing from the solar panel, it still somehow sucks the measured voltage down to about 0.3v above the supercap's voltage. On the other hand, if I physically disconnect the solar panel, then I'm able to then read it's unloaded voltaqe.
                                      I played around with it a bit more, and I found that if I used some external voltage source that was otherwise not part of the circuit to switch the P-FET "off", then it effectively accomplishes a full disconnect.
                                        #168
                                        Found a very good on-point thread which addresses the issue I'm having: https://forum.arduino.cc/index.php?topic=115233.0 So, it may be mosfet related, not just circuit related. If worse comes to worst, I'll order the Hexfet it references that supposedly does achieve a full disconnect the way you'd expect.
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @NeverDie said in How best to find the "best" small solar panel of a particular size?:
                                          I do not disagree with you. I have started looking at Eagle software. Obviously, the idea is that I'm going to start with improving somebody's design first and then designing something myself
