  3. MySensors SenseBender GW + W5100
4 Posts 2 Posters 1.3k Views 2 Watching
  • J
    J
    JWB
    I am a newbe on this forum so hopefully I won't stumble too many times!
    I have a MYSensors GW with a W5100 Ethernet module that I am trying to bring up.
    I started with operating the GW as a serial GW talking to either MyController.org or Homeassistant Controllers.
    This setup works fine with no issues between the controller and GW or any RF nodes.
    I then migrated the GW to Ethernet using the MYSensors Webserver sketch to checkout the W5100.
    Everything worked fine. No issues. I used nmap to query the W5100 @ 192.168.1.99 and I see that port 80 /tcp is open and the service is http. This is good.
    I then loaded the MYSensors GW sketch and tried running the Homeassistant Controller app.
    The Controller keeps trying to connect to the GW, but, fails. This scenario keeps repeating.
    I then tried the MYController.org app and I see a similar connection failure.
    So at this time both controller apps are unable to talk to the GW via Ethernet.
    I can ping the GW so I know it is there.
    I used nmap and it shows port 5003 is closed, service =filemaker.
    I was expecting port 5003 to be open, not closed!
    I suspect this is why the Controller apps are unable to communicate with the GW.
    I checked the sketch and I see where port 5003 is defined, but, I do not understand why the port is closed.
    I believe at this point the h/w is OK and the issue is with the s/w.
    I am not a s/w expert so I am in need of some help tracking down why the Ethernet is not working.
    I have uploaded the sketch I am using as well as the IDE compiler log.
    My IDE is version 1.8.2.
    0_1497553226117_sketch_jun05a_SenseBender_Gateway_Ethernet.ino
    0_1497553530246_Sketch_jun05a_SB_GW_Ethernet_Compile_Log.txt
    J 1 Reply Last reply
    • J JWB
      J
      J
      JWB
      @JWB said in MySensors SenseBender GW + W5100:
      Here is the serial log from the GW.0_1497554846818_GW Ethernet Serial Log.txt
      • J
        J
        JWB
        I did some further troubleshooting and I believe I figured out why the Ethernet is failing. I was using the following in the sketch and I think I misunderstood what it was used for:
        "// Controller ip address. Enables client mode (default is "server" mode).
        #define MY_CONTROLLER_IP_ADDRESS 192,168,1,68"
        I thought this was used to tell the GW where the Controller was located. However, with this enabled, the Controller cannot talk to the GW. I also see a minor error pop up when this feature is enabled.
        "C:\Users\JB's_Quad_PC\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\libraries\Ethernet\src\utility\socket.cpp:365:6: warning: unused parameter 's' [-Wunused-parameter]
        void flush(SOCKET s)
        I really don't know what this error is or if it is an indication of some other compiler error that is not clearly shown.
        After disabling "MY_CONTROLLER_IP_ADDRESS" I was able to finally make an Ethernet connection between Homeassistant and the GW. YES!
        I used nmap and it also showed port 5003 was open now. YES!
        Time to move on....
        • tbowmoT
          tbowmoT
          tbowmo
          @JWB
          That setting is turning the gateway into a "client" which needs to connect to a server (which is your controller). Without this set it is running as a "server" which accepts incoming connections from other devices on the network (like your controller)
