  2. Announcements
  3. 💬 Motion Sensor
💬 Motion Sensor
63 Posts 30 Posters 34.7k Views 31 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I have never used timers but I looked at the blink without delay sketch from the arduino website. Do I replace the if -statement with a while loop?
    const int ledPin =  LED_BUILTIN;// the number of the LED pin
    // Variables will change :
    int ledState = LOW;             // ledState used to set the LED
    // Generally, you should use "unsigned long" for variables that hold time
    // The value will quickly become too large for an int to store
    unsigned long previousMillis = 0;        // will store last time LED was updated
    // constants won't change :
    const long interval = 1000;           // interval at which to blink (milliseconds)
      // set the digital pin as output:
      pinMode(ledPin, OUTPUT);
      // here is where you'd put code that needs to be running all the time.
      // check to see if it's time to blink the LED; that is, if the
      // difference between the current time and last time you blinked
      // the LED is bigger than the interval at which you want to
      // blink the LED.
      if (currentMillis - previousMillis >= interval) {
        // save the last time you blinked the LED
        // if the LED is off turn it on and vice-versa:
        if (ledState == LOW) {
          ledState = HIGH;
          ledState = LOW;
        // set the LED with the ledState of the variable:
        digitalWrite(ledPin, ledState);
      Just leave it as it is, just put a condition that will trigger the if statement only once the pir sensor got triggered
      • L
        L
        LastSamurai
        I would actually not do this in a node but in the controller (at least if I get what you are trying to do right). I have done that with some scripting in domoticz. I have lights that that are switched on for 5 minutes when motion is detected and shut down 5 minutes after the last motion stopped. Motion sensor and rgbw controller are different mysensor nodes. Much more versatile then hardcoding this in you node's code.
        ben999B 1 Reply Last reply
        • L LastSamurai
          ben999B
          ben999B
          ben999
          @LastSamurai
          Would you do that through "rules" ?
          gohanG 1 Reply Last reply
          • ben999B ben999
            @LastSamurai
            @ben999 yes.
            @LastSamurai I know that hardcoding is less flexible, but at least it can work even if controller is down or disconnected, of course it depends how critical is the actuator.
            • maghacM
              maghacM
              maghac
              So, I notice that the HC-SR501 has a 7133-1 voltage regulator on-board which I guess means that the logic is actually driven with 3.3V and not 5V.
              Is it possible to bypass the regulator and power the sensor directly with the 3.3V I am using to power my nano with?
              maghacM 1 Reply Last reply
              • maghacM maghac
                maghacM
                maghacM
                maghac
                @maghac Aha, guess I should read old posts first :)
                  Just make sure the power source is stable otherwise you will end up with random triggers from pir sensor
                    ben999B
                    ben999B
                    ben999
                    @gohan @maghac
                    From my little experience : when running from 2 AA batteries with sketch as it is I got random triggers continuousely
                    Adding a delay() before entering sleep() sorted things out (something like 3 sec is necessary to get power stable again)
                    Not sure it's the smartest way of doing it, but it works...
                    Any comment on the security side of it? Could my node miss some action during these 3 sec ? Or the interrupt pin would still listen to the PIR sensor pin ?
                      I think it will miss the pir trigger
                        ben999B
                        ben999B
                        ben999
                        @gohan
                        Thank you for your reply
                        Could you please explain a bit further ?
                        Interrupt pin would still read the trigger during delay()?
                        Data would be lost as the sketch is frozen during delay() ?
                        Or data is saved in some buffer, ready to be used as soon as sketch comes back to life ?
                        My view is that it shouldn't matter too much if i miss a trigger after a trigger : the first trigger will wake my node and transmit to gateway. So job done. Alarm goes off.
                        On the other hand, I guess a millis() would be neater ?
                        Thanks a lot for your input
                          I am saying that during delay no code is executed and interrupt only attaches to pin when executing the sleep function, so if motion if triggered during the delay it will not be detected by interrupt; maybe it could detect the CHANGE when pir goes from high to low but it will then report "no motion" and it will not trigger alarm if it set to go off on "motion" only.
                            ben999B
                            ben999B
                            ben999
                            @gohan
                            Thanks a lot
                            Got it now
                            delay() to be avoided then !
                            I will have a look at millis() instead
                              Delay is not bad, depends how you use it. Maybe you could use an if statement to check pin state is low before entering sleep
                              • skywatchS
                                skywatchS
                                skywatch
                                Millis won't work with the SLEEP funtion either. REcently added to the API....
                                • siodS
                                  siodS
                                  siod
                                  Hi, I´ve read this above
                                  "however this sensor requires 5 VDC so you will need to use a step-up regulator if you are running the 3.3V version of the Arduino Pro Mini."
                                  So I am using 3 V, could you propose a fitting step up regulator so I can use this PIR (best from ebay)? Thank you!
                                  still learning...
                                  • siodS siod
                                    maghacM
                                    maghacM
                                    maghac
                                    @siod said in 💬 Motion Sensor:
                                    a
                                    You have a HC-SR501 sensor? I had that same question before and then I realized that the HC-SR501 actually has a 3.3 V regulator and if you bypass it you can run it on 3.3V.
                                      If I wanted to add two PIRs to one sensor-node would this sketch work?
                                       * Version 1.0 - Henrik Ekblad
                                      // Enable debug prints
                                      // #define MY_DEBUG
                                      #define DIGITAL_INPUT_SENSOR_1 2
                                      #define DIGITAL_INPUT_SENSOR_2 3  // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                      #define CHILD_ID_1 1   // Id of the sensor child
                                      #define CHILD_ID_2 2   // Id of the sensor child
                                      // Initialize motion message
                                      MyMessage msg(CHILD_ID_1, V_TRIPPED);
                                          pinMode(DIGITAL_INPUT_SENSOR_1, INPUT);      // sets the motion sensor digital pin as input
                                          pinMode(DIGITAL_INPUT_SENSOR_2, INPUT);      // sets the motion sensor digital pin as input
                                          sendSketchInfo("Motion Sensor_Dual", "1.0");
                                          present(CHILD_ID_1, S_MOTION);
                                          present(CHILD_ID_2, S_MOTION);
                                          // Read digital motion value
                                          bool tripped_1 = digitalRead(DIGITAL_INPUT_SENSOR_1) == HIGH;
                                          bool tripped_2 = digitalRead(DIGITAL_INPUT_SENSOR_2) == HIGH;
                                          Serial.println(tripped_1 || tripped_2);
                                          if(tripped_1){
                                          send(msg.set(tripped_1?"1":"0"));  // Send tripped value to gw
                                          if(tripped_2){
                                          send(msg.set(tripped_2?"1":"0"));  // Send tripped value to gw
                                          sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_1 || DIGITAL_INPUT_SENSOR_1), CHANGE, SLEEP_TIME);
                                      I know PIN 2 is supposed to be connected to the radio but I read somewhere that it is not used.
                                      sellierS
                                      sellierS
                                      sellier
                                      wrote on last edited by gohan
                                      #51
                                      @Cliff-Karlsson
                                      For dual Sensors
                                      one error is present on the line sleep:
                                      it is not : sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_1 || DIGITAL_INPUT_SENSOR_1), CHANGE, SLEEP_TIME);
                                      but : sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_1 )|| digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_2), CHANGE, SLEEP_TIME);
                                        MCF
                                        hi,
                                        i want to ad a motion sensor to my project (3 dimmers on a arduino uno using nrf24).
                                        My first problem is that the 2 and 3 pins are not available (nrf24 and pwm dimmer), so i will take the pin 1 for testing
                                        second is the sleeping time during i can't send any light message to my dimmers...
                                          MCF
                                          this is my code
                                           * Version 1.0 - February 15, 2014 - Bruce Lacey
                                           * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
                                           * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
                                           * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
                                           * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
                                           * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
                                           * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
                                           * to the LED negative terminal and the MOSFET Source pin is connected to ground.
                                           * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
                                           * http://www.mysensors.org/build/dimmer
                                           * LISTE DE POINTS:
                                           * D0  DISPO
                                           * D1  MOTION
                                           * D2  IRQ NRF
                                           * D3  LED1
                                           * D4  DISPO
                                           * D5  LED2
                                           * D6  LED3
                                           * D7  DISPO
                                           * D8  DISPO
                                           * D9  CE NRF
                                           * D10 CSN/CS NRF
                                           * D11 MOSI NRF
                                           * D12 MISO NRF
                                           * D13 SCK NRF
                                           * D14 DISPO
                                          //#define MY_NODE_ID 153
                                          #define SN "BUREAU PARENTS"
                                          #define SV "1.2"
                                          #define noLEDs 3
                                          const int LED_Pin[] = {3, 5, 6};
                                          #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                                          static int currentLevel1 = 0;  // Current dim level...
                                          static int currentLevel2 = 0;  // Current dim level...
                                          static int currentLevel3 = 0;  // Current dim level...
                                          MyMessage dimmer1Msg(1, V_DIMMER);
                                          MyMessage light1Msg(1, V_LIGHT);
                                          MyMessage dimmer2Msg(2, V_DIMMER);
                                          MyMessage light2Msg(2, V_LIGHT);
                                          MyMessage dimmer3Msg(3, V_DIMMER);
                                          MyMessage light3Msg(3, V_LIGHT);
                                          // MOTION SENSOR
                                          uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                                          #define DIGITAL_INPUT_SENSOR 1   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                          #define CHILD_ID 4   // Id of the sensor child
                                           * Dimmable LED initialization method
                                            // LEDS
                                            // Pull the gateway's current dim level - restore light level upon sendor node power-up
                                          for (int sensor=1; sensor<=noLEDs; sensor++){
                                            request( sensor, V_DIMMER );
                                           // MOTION
                                            // Register the LED Dimmable Light with the gateway
                                           present(sensor, S_DIMMER);
                                           wait(2);
                                            // MOTION
                                            present(CHILD_ID, S_MOTION);
                                            sendSketchInfo(SN, SV);
                                           *  Dimmable LED main processing loop
                                              bool tripped = digitalRead(DIGITAL_INPUT_SENSOR)== HIGH;
                                              Serial.println("coucou");
                                              Serial.println(tripped);
                                            if (message.type == V_LIGHT || message.type == V_DIMMER) {
                                              if (message.sensor == 1) {
                                              int requestedLevel1 = atoi( message.data );
                                              requestedLevel1 *= ( message.type == V_LIGHT ? 100 : 1 );
                                              requestedLevel1 = requestedLevel1 > 100 ? 100 : requestedLevel1;
                                              requestedLevel1 = requestedLevel1 < 0   ? 0   : requestedLevel1;
                                               fadeToLevel1( requestedLevel1, message.sensor );
                                              send(light1Msg.set(currentLevel1 > 0 ? 1 : 0));
                                              send(dimmer1Msg.set(currentLevel1) );}
                                             if (message.sensor == 2) {
                                              int requestedLevel2 = atoi( message.data );
                                              requestedLevel2 *= ( message.type == V_LIGHT ? 100 : 1 );
                                              requestedLevel2 = requestedLevel2 > 100 ? 100 : requestedLevel2;
                                              requestedLevel2 = requestedLevel2 < 0   ? 0   : requestedLevel2;
                                              fadeToLevel2( requestedLevel2, message.sensor );
                                              send(light2Msg.set(currentLevel2 > 0 ? 1 : 0));
                                              send(dimmer2Msg.set(currentLevel2) );}
                                              if (message.sensor == 3) {
                                              int requestedLevel3 = atoi( message.data );
                                              requestedLevel3 *= ( message.type == V_LIGHT ? 100 : 1 );
                                              requestedLevel3 = requestedLevel3 > 100 ? 100 : requestedLevel3;
                                              requestedLevel3 = requestedLevel3 < 0   ? 0   : requestedLevel3;
                                               fadeToLevel3( requestedLevel3, message.sensor );
                                              send(light3Msg.set(currentLevel3 > 0 ? 1 : 0));
                                              send(dimmer3Msg.set(currentLevel3) );}
                                           *  This method provides a graceful fade up/down effect
                                          void fadeToLevel1( int toLevel1, int ledid1 ) {
                                            int delta1 = ( toLevel1 - currentLevel1 ) < 0 ? -1 : 1;
                                            while ( currentLevel1 != toLevel1 ) {
                                              currentLevel1 += delta1;
                                              analogWrite(LED_Pin[ledid1-1], (int)(currentLevel1 / 100. * 255) );
                                              wait( FADE_DELAY );
                                          void fadeToLevel2( int toLevel2, int ledid2 ) {
                                            int delta2 = ( toLevel2 - currentLevel2 ) < 0 ? -1 : 1;
                                            while ( currentLevel2 != toLevel2 ) {
                                              currentLevel2 += delta2;
                                              analogWrite(LED_Pin[ledid2-1], (int)(currentLevel2 / 100. * 255) );
                                              wait( FADE_DELAY );
                                          void fadeToLevel3( int toLevel3, int ledid3 ) {
                                            int delta3 = ( toLevel3 - currentLevel3 ) < 0 ? -1 : 1;
                                            while ( currentLevel3 != toLevel3 ) {
                                              currentLevel3 += delta3;
                                              analogWrite(LED_Pin[ledid3-1], (int)(currentLevel3 / 100. * 255) );
                                              wait( FADE_DELAY );
