  3. Analog to digital how ?
5 Posts 2 Posters 1.8k Views 2 Watching
  • R
    R
    Rene046
    Hi there,
    I would like to know what and where i have to look for.
    I reading with my nano 328 port A0, A1, A2 voltage from "3" motion senors
    and get a specific value >700
    if one of those ports gets above this 700
    I would like to send this true mysensors as an normal motion sensor normal true trigger
    but im not using any interrupt
    How do i send this ?
    if (analogRead(A0) >=700)
    send(msgmotion0.set(tripped0?"1":"0"));
    and for the others.
    send(msgmotion1.set(tripped1?"1":"0"));
    send(msgmotion3.set(tripped3?"1":"0"));
    • R
      R
      Rene046
      #define MY_REPEATER_FEATURE
      //#include <SPI.h>
      boolean sensorUpperActive;
      boolean sensorBottomActive;
      boolean PIR00;
      #define MY_NODE_ID 30
      #define CHILD_ID_PIR00 31   // Id of the sensor child
      #define CHILD_ID_PIR01 32   // Id of the sensor child
      #define CHILD_ID_PIR02 33   // Id of the sensor child
        sendSketchInfo("PIR Sensor", "4.0");
        present(CHILD_ID_PIR00, S_MOTION, "PIR Sensor 0");
        present(CHILD_ID_PIR01, S_MOTION, "PIR Sensor 1");
        present(CHILD_ID_PIR02, S_MOTION, "PIR Sensor 2");
      // Initialize motion message
       MyMessage msgPIR00(CHILD_ID_PIR00, V_TRIPPED);
       MyMessage msgPIR01(CHILD_ID_PIR01, V_TRIPPED);
       MyMessage msgPIR02(CHILD_ID_PIR02, V_TRIPPED);
      // the setup routine runs once when you press reset:
        // initialize serial communication at 9600 bits per second:
      //  Serial.begin(9600);
        pinMode(LED_BUILTIN, OUTPUT);
      // the loop routine runs over and over again forever:
       Pir0lezen();
       Pir1lezen();
       Pir2lezen();
       effopneer();
       effneerop();
       Tegelijk();
      //  delay(1000);        // delay in between reads for stability
      void Pir0lezen() {
        int PIR0 = analogRead(A0);
        Serial.println("PIR0----");
        Serial.println(PIR0);
        PIR00 = true;
        // Send status to Domoticz
      void Pir1lezen() {
        int PIR1 = analogRead(A1);
        if (analogRead(A1) >=700) {
        sensorBottomActive = true;
        Serial.println("PIR1----");
        Serial.println(PIR1);
      void Pir2lezen() {
        int PIR2 = analogRead(A2);
        if (analogRead(A2) >=700) {
        sensorUpperActive = true;
        Serial.println("PIR2----");
        Serial.println(PIR2);
      void effopneer() {
        if (sensorBottomActive==true && sensorUpperActive==false){
        // do something
        digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
        delay(100);                       // wait for a second
        digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
        sensorBottomActive = false ;
        Serial.println("PIR1--uit");
      void effneerop() {
        if (sensorBottomActive==false && sensorUpperActive==true){
        delay(500);                       // wait for a second
        sensorUpperActive = false ;
        Serial.println("PIR2--uit");
      void  Tegelijk() {
        if (sensorBottomActive==true && sensorUpperActive==true){
        delay(5000);                       // wait for a second
        Serial.println("PIR1&2--uit");
      • R Rene046
        //#include <SPI.h>
        boolean PIR00;
         Pir0lezen();
         Pir1lezen();
         Pir2lezen();
         effopneer();
         effneerop();
         Tegelijk();
        void Pir0lezen() {
          PIR00 = true;
        void Pir1lezen() {
        void Pir2lezen() {
        void effopneer() {
          // do something
        void effneerop() {
        void  Tegelijk() {
        @Rene046 how about something like this?
        void Pirlezen() {
          bool pir = analogRead(A0)>=700;
          send(msgmotion0.set(pir));
        R 1 Reply Last reply
          void Pirlezen() {
          R
          R
          Rene046
          @mfalkvidd
          Thx
          I already got it running after a long night ...lol
          here is what i have sofar...
          //#include <SPI.h>
          // boolean sensorBottomActive;
          int sensorBottomActive;
          int PIR1new;
          int PIR1old;
          int PIR2new;
          int PIR2old;
          boolean PIR00;
           Pir0lezen();
           Pir1lezen();
           Pir2lezen();
           effopneer();
           effneerop();
           Tegelijk();
          void Pir0lezen() {
            PIR00 = true;
          void Pir1lezen() {
            int PIR1new = analogRead(A1);
            if (PIR1new != PIR1old && PIR1new >=700) {
            sensorBottomActive = true ;
            send (msgPIR01.set(sensorBottomActive?"1":"0"));
            Serial.println(PIR1new);
            PIR1old = PIR1new;
          void Pir2lezen() {
            int PIR2new = analogRead(A2);
            if (PIR2new != PIR2old && PIR2new >=700) {
            sensorUpperActive = true ;
            send (msgPIR02.set(sensorUpperActive?"1":"0"));
            Serial.println(PIR2new);
            PIR2old = PIR2new;
          void effopneer() {
            // do something
            send (msgPIR01.set(sensorBottomActive));
          void effneerop() {
            send (msgPIR02.set(sensorUpperActive));
          void  Tegelijk() {
            send (msgPIR01.set(sensorUpperActive));
          • R
            R
            Rene046
            All working fine sometimes the pir reaction could be a bid faster, and sometimes i get a false reading think i'll have to put the pir signal lines to the ground with an resistor.
            Any advice is welcome, to make thing faster, and less complex.
            else use this with fun......
            #include <Wire.h>        // Wire library t.b.v. I²C
            byte GPIOA  = 0x12;      // GPIOA adres in 16-bit mode, is directe aansturing 1e groep van 8 I/O poorten.
            byte GPIOB  = 0x13;      // GPIOA adres in 16-bit mode, is directe aansturing 1e groep van 8 I/O poorten.
            boolean sensorBovenActive;    // Status of Pir motion sensor 2.
            boolean sensorOnderActive;    // Status of Pir motion sensor 1.
            boolean sensorKelderActive;    // Status of Pir motion sensor 0.
            int PIR0new;      // Pir motion sensor 0 updated value "Kelder".
            int PIR0old;      // Pir motion sensor 0 old value "Kelder".
            int PIR1new;      // Pir motion sensor 1 updated value "sensorOnderActive".
            int PIR1old;      // Pir motion sensor 1 old value "sensorOnderActive".
            int PIR2new;      // Pir motion sensor 2 updated value. "sensorBovenActive"
            int PIR2old;      // Pir motion sensor 2 old value. sensorBovenActive"
            int StairDelay = 250; // Delay for stairs
            int StairOn = 30000; // Delay to keep stair light on
            void presentation(){
              sendSketchInfo("Trap Controller", "4.0");
              present(CHILD_ID_PIR00, S_MOTION, "PIR Sensor Kelder");
              present(CHILD_ID_PIR01, S_MOTION, "PIR Sensor Trap Onder");
              present(CHILD_ID_PIR02, S_MOTION, "PIR Sensor Trap Boven");
             Wire.begin(); // wake up I2C bus
             // set I/O pins to outputs
             Wire.beginTransmission(0x20); // Start adress of mcp23017
             Wire.write(0x00); // IODIRA register
             Wire.write(0x00); // set all of port A to outputs
             Wire.endTransmission();
             Wire.write(0x01); // IODIRB register
             Wire.write(0x00); // set all of port B to outputs
             Pir0lezen();
             Pir1lezen();
             Pir2lezen();
             effneerop();
             effopneer();
             effKelder();
            void Pir0lezen() {
              int PIR0new = analogRead(A0);
              if (PIR0new >=900) {
              sensorKelderActive = true;
              send (msgPIR00.set(sensorKelderActive?"1":"0"));
              Serial.println("PIR0new----");
              Serial.println(PIR0new);
              PIR0old = PIR0new;
              sensorKelderActive = false;
              send (msgPIR00.set(sensorKelderActive));
            void Pir1lezen() {
              if (PIR1new != PIR1old && PIR1new >=710) {
              sensorOnderActive = true ;
              sensorBovenActive = false ;
              send (msgPIR01.set(sensorOnderActive?"1":"0"));
              PIR1old = PIR1new;
            void Pir2lezen() {
              if (PIR2new != PIR2old && PIR2new >=710) {
              sensorBovenActive = true ;
              sensorOnderActive = false ;
              send (msgPIR02.set(sensorBovenActive?"1":"0"));
              PIR2old = PIR2new;
            void effopneer() {
                if (sensorOnderActive==true && sensorBovenActive==false){
                Serial.println("PIR1--aan");
                setLEDA(B01111111);  // Tree 1
                delay(StairDelay);
                setLEDA(B00111111);  // Tree 2
                delay(StairDelay);
                setLEDA(B00011111);  // Tree 3
                delay(StairDelay);
                setLEDA(B00001111);  // Tree 4
                delay(StairDelay);
                setLEDA(B00000111);  // Tree 5
                delay(StairDelay);
                setLEDA(B00000011);  // Tree 6
                delay(StairDelay);
                setLEDA(B00000001);  // Tree 7
                delay(StairDelay);
                setLEDA(B00000000);  // Tree 8
                delay(StairDelay);
                setLEDB(B01111111);  // Tree 9
                delay(StairDelay);
                setLEDB(B00111111);  // Tree 10
                delay(StairDelay);
                setLEDB(B00011111);  // Tree 11
                delay(StairDelay);
                setLEDB(B00001111);  // Tree 12
                delay(StairDelay);
                setLEDB(B00000111);  // Tree 13
                delay(StairDelay);
                setLEDB(B00000011);  // Tree 14
                send (msgPIR01.set(sensorOnderActive)); // switch off before delay
                delay(StairOn);
                setLEDA(B11111111);  // all off
                setLEDB(B11111111);  // all off
            void effneerop() {
              if (sensorOnderActive==false && sensorBovenActive==true){
                Serial.println("PIR2--aan");
                setLEDB(B11111011);  // Tree 14
                delay(StairDelay);
                setLEDB(B11110011);  // Tree 13
                delay(StairDelay);
                setLEDB(B11100011);  // Tree 12
                delay(StairDelay);
                setLEDB(B11000011);  // Tree 11
                delay(StairDelay);
                setLEDB(B10000111);  // Tree 10
                delay(StairDelay);
                setLEDB(B00000011);  // Tree 9
                delay(StairDelay);
                setLEDA(B11111110);  // Tree 8
                delay(StairDelay);
                setLEDA(B11111100);  // Tree 7
                delay(StairDelay);
                setLEDA(B11111000);  // Tree 6
                delay(StairDelay);
                setLEDA(B11110000);  // Tree 5
                delay(StairDelay);
                setLEDA(B11100000);  // Tree 4
                delay(StairDelay);
                setLEDA(B11000000);  // Tree 3
                delay(StairDelay);
                setLEDA(B10000000);  // Tree 2
                delay(StairDelay);
                setLEDA(B00000000);  // Tree 1
                send (msgPIR02.set(sensorBovenActive));
                delay(StairOn);
            void effKelder() {
            void setLEDA(byte value)
             Wire.write(GPIOA);                            // gpioa
             Wire.write(byte(value));                      // set LEDs volgens waarde 'value'
            void setLEDB(byte value)
             Wire.write(GPIOB);                            // gpiob
            void bonuseff() {
                delay(StairDelay);
                setLEDB(B11110111);  // Tree 13
                delay(StairDelay);
                setLEDB(B11101111);  // Tree 12
                delay(StairDelay);
                setLEDB(B11011111);  // Tree 11
                delay(StairDelay);
                setLEDB(B10111111);  // Tree 10
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                setLEDA(B11111101);  // Tree 7
                delay(StairDelay); ;
                setLEDA(B11111011);  // Tree 6
                setLEDA(B11110111);  // Tree 5
                delay(StairDelay);
                setLEDA(B11101111);  // Tree 4
                delay(StairDelay);
                setLEDA(B11011111);  // Tree 3
                delay(StairDelay);
                setLEDB(B10111110);  // Tree 2
                delay(StairDelay);
                setLEDB(B01111111);  // Tree 1
                delay(StairDelay);
                setLEDA(B10111111);  // Tree 2
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
                delay(StairDelay);
