  3. Change valuename send to Controller
4 Posts 2 Posters 1.4k Views 2 Watching
  • WieselW
    WieselW
    Wiesel
    Hey everybody,
    I built a soil moisture sensors with the YL-39 and YL-69. I'm using FHEM as Controller. The name of the value from sensors is present as "level". I would like to rename it to "moisture level".
    Can someone explain how I can change the valuename ?
    #define CHILD_ID 0
    MyMessage msg(CHILD_ID, V_LEVEL);
    unsigned long SLEEP_TIME = 10000; // Sleep time between reads (in milliseconds)
    int lastSoilValue;
    // YL-39 + YL-69 humidity sensor
    byte humidity_sensor_pin = A1;
    byte humidity_sensor_vcc = 6;
      sendSketchInfo("Soil Moisture Sensor", "1.0");
      present(CHILD_ID, S_MOISTURE);
      // Init the humidity sensor board
      pinMode(humidity_sensor_vcc, OUTPUT);
      digitalWrite(humidity_sensor_vcc, LOW);
    int read_humidity_sensor() {
      digitalWrite(humidity_sensor_vcc, HIGH);
      delay(500);
      int value = analogRead(humidity_sensor_pin);
      return 1023 - value;
      int soilValue = read_humidity_sensor();
      Serial.print("Soil Moisture Level (0-1023): ");
      Serial.println(soilValue);
      //send back the values
      if (soilValue != lastSoilValue) {
      send(msg.set(soilValue, 0));
      lastSoilValue = soilValue;
      // delay until next measurement (msec)
      sleep(SLEEP_TIME);
      I think it is more related to the controller than mysensors. Have you tried asking in their forum?
      • WieselW
        WieselW
        Wiesel
        Hi gohan.
        Oh, I thought it was a mysensors thing. That there's anywhere a declaration for the value name.
        I'm new in house automation and still have a lot to learn.
        I will ask in FHEM Forum. Thank you.
          Well, mysensors is kind of a transport of information that is then presented to the user by the controller, so it is more a user interface business to present the data the way you like :)
