  2. Announcements
  3. 💬 Rain Gauge
💬 Rain Gauge
61 Posts 17 Posters 28.9k Views 16 Watching
  • dbemowskD dbemowsk
    @Enfeet I have been trying to wrap my head around the formulas for this. I have been basing numbers off of the formulas on this instructables page and after looking at his numbers, I think he has them wrong too. He states :
    rainfall height = volume of rain collected / catchment area
    In my rain collector, the length and breadth were 11 cm by 5 cm respectively giving a catchment area of 55 sq.cm. So a collection of 9 milliliters of rain would mean 9 cc/55 sq.cm = 0.16363... cm = 1.6363... mm = 0.394 inches.
    9cc/55 is 0.16363 cm, but 1.6363 mm does not equal 0.394 inches as stated in the article. According to the conversion I did it is 0.064421. Did I do a calculation wrong?
    EnfeetE
    EnfeetE
    Enfeet
    @dbemowsk I think it's time to look in a book ;-) "The amount of precipitation is expressed in millimeters of a layer of water that would be formed from the precipitation, if they did not evaporate, did not seep into the soil and would not drain. Numerically, the amount of precipitation in millimeters is equal to the amount of kilograms of water left on the site in 1 sq.meter, i.e. 1 mm = 1 kg / 1 m2.
    EnfeetE dbemowskD 2 Replies Last reply
    • EnfeetE Enfeet
      EnfeetE
      EnfeetE
      Enfeet
      @Enfeet Precipitation intensity
      "Strong" is called rain, if it drops from 15 to 49 mm in 12 hours. Precipitation is also "very strong" when it falls from 50 mm in 12 hours.
      "Strong snow" - the amount of precipitation from 7 to 19 mm for 12 hours. "Very heavy snow," when its amount exceeds 20 mm in 12 hours.
      • EnfeetE Enfeet
        dbemowskD
        dbemowskD
        @Enfeet I understand that, my point was I guess more that it gets confusing when the person that wrote the article gets the numbers wrong. The other part that can get a little confusing in this at times is the units of measure and the conversions. When you talk about mm (length) vs mm2 (area) vs mm3 (volume) and you start mixing these together in the calculations. I am in the US, so I work with imperial measures, so then there is the conversions from metric to imperial on top of that. The thing that I think the guy that wrote the article got wrong was his conversion to imperial measure (inches of rainfall). That is more what I was trying to wrap my head around.
        EnfeetE 1 Reply Last reply
          EnfeetE
          EnfeetE
          Enfeet
          @dbemowsk Sorry, i m living in metric units ;-) But, i think it can be calculated logically. Just look at a DIY project: https://www.education.com/science-fair/article/DIY-rain-gauge/ The logic is to attach a scale to a bottle and measure the mm or inches of rain occured. Our goal is recalculate the number of impulses to the amount of precipitation depending on square of our bucket. So it's possible to take a bottle with the same square like our bucket, attach a scale (inches or mm does not matter) and let collect all water out of our measuring gauge i.e. take a litter or half flow it to a gauge and collect after. And finally just divide measured level of collected water to the number of impulses counted....
          Sorry if method is not clear... ;-) I can draw an idea in a pictures ;-)
          • EnfeetE
            EnfeetE
            Enfeet
            Ups! After 3 days.....
              schmucke
              What kind of powersupply is a good one, if i have errors with bouncing/fakerain?
              • S schmucke
                EnfeetE
                EnfeetE
                Enfeet
                @schmucke I'm using 5V 1Amp from tiny mobile charger https://www.thingiverse.com/thing:2171813
                  schmucke
                  I have the following problem:
                  Every Time, if a normal switch with a led bulb is switching, the arduino is count one up...
                  • mfalkviddM
                    Sounds like the hardware debouncing described in the troubleshooting section might be needed.
                      schmucke
                      I have just one build, but i use 300ohm. I think, thats to small :/
                      • kotzerK
                        kotzerK
                        kotzer
                        nice idea, nice project, nice documentation, nice result :+1: :heart: :heart:
                        but i've a problem with the led. this is only HIGH when the arduino boots up for ~2 secs. then set to 0 (LOW).
                        i adjusted some debugging message to find out, what exactly happens, but am stucking here.. in the loop it goes into slowFlash(), but there nothing is called against the led_pin (because of if (millis() - pulseStart < 100UL))
                        what am i doing wrong?
                        why is the led only fired at startup, but not when trapped (manually closed the reed switch for short time to simulate some rain)?
                        what was the intension of the led? (nothing could be found in description & video of pete)
                        @petewill I don't see the led in your vid... where is it?
                        • I
                          I
                          itbeyond
                          Folks, A question of interest. I have had my gauge working great for several months but it has just started to play up. It seems to crash after a few hours. I have not plugged in a debug/console or anything as yet but decided to have a good look at the code and I have noticed that every hour the system cycles through updating EPROM values to cascade the rain rates. I have also noted with interest a comment in the API that mentions some 300K updates as max for the EPROM - I just looked at the Ardunio documentation and it states 100K read/write cycles till EPROM failure. If I am reading this right then maybe my problems are related to dead EPROM storage caused after months of hourly write cycles - Is this a possibility and if yes should we not look at another method of update management for the gauge - I do not want to have to trash an Arduino every few months, I am looking at the code and need more time to get a full handle on it however there appears to be write cycles every hour even if the values have not changed. Is this something to investigate? Is there a way to know if an Arduino EPROM has failed due to excessive write cycles?
                          • I itbeyond
                            #55
                            @itbeyond there are 8,760 hours in a year, so 100,000 writes should last more than 10 years.
                            MySensors does not re-write the same data if the data has not changed, so a save call does not always result in a write.
                            The code uses a ring buffer to lessen the risk of writing too much to a single eeprom position.
                            So eeprom writes should not be a problem. But maybe Arduino clones can't handle 100,000 writes?
                            I guess an alternative could be to store the data in ram and send it to the controller periodically so the data can be fetched when the Arduino (re)boots. Or do the aggregation on the controller, where ram and storage is plentiful.
                            The best way I know to detect eeprom failures is to repeatedly read and measure time for each read. On esp8266 I've seen reads that take more than 100x normal time when the eeprom was damaged.
                            I 1 Reply Last reply
                              I
                              I
                              itbeyond
                              @mfalkvidd thanks for the important info on the saveState - I have not looked at the API code in this respect and if it does not write same data this is a very good. I have also looked into the code some more there are 4 possible writes per hour which using your maths is 35k write per year so it still should be good for a few years (clones well yes who knows). I may have another problem but I am not sure what - if I reboot it is runs fine for several hours and randomly seems to stop sending data however even if the EPROM is stuffed it should not affect the temp, hum and light level sensors. I may be seeing some funny humid reading so the DHT could be faulty also - I may replace this firstly and see what the result is. Thanks for the response.
                              petewillP 1 Reply Last reply
                              • EnfeetE
                                EnfeetE
                                Enfeet
                                Hi all,
                                finally i rewrite a code for myself. There is no More EEPROM usage at all.
                                I'm using MajorDoMo (http://majordomohome.com/) and it more suitable for me to have a 10 minutes counts from Rain Gauge.
                                Here is my new code:
                                #define MY_RFM69_ENABLE_ENCRYPTION
                                 Author: Sergey E. Yakovlev
                                 Date: 2017/02/25 u001
                                #define SKETCH_NAME "Enic Rain Gauge"
                                #define SKETCH_VERSION "0.1"
                                #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
                                #define DHT_ON // uncomment out this line to enable DHT sensor
                                //#define MY_DEBUG_VERBOSE
                                //#define MY_NODE_ID AUTO
                                #define MY_NODE_ID 15
                                #define MY_RADIO_RFM69
                                #define MY_IS_RFM69HW
                                #define MY_RFM69_TX_POWER 31
                                #include <Adafruit_Sensor.h>
                                #include <DHT_U.h>
                                #define CHILD_ID_HUM 0
                                #define CHILD_ID_TEMP 1
                                #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
                                int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
                                int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
                                #define DHTPIN       8         // Pin which is connected to the DHT sensor.
                                // Uncomment the type of sensor in use:
                                //#define DHTTYPE           DHT11     // DHT 11
                                #define DHTTYPE           DHT22     // DHT 22 (AM2302)
                                //#define DHTTYPE           DHT21     // DHT 21 (AM2301)
                                char buff[10];
                                unsigned long SEND_FREQUENCY = 60000*10; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                                DHT_Unified dht(DHTPIN, DHTTYPE);
                                #define TIP_SENSOR_PIN 3
                                //d=112 mm
                                //11689.863832 mm2 =  116,89863832 cm2
                                //42,77209787776081 mm
                                //88 89 91 91 90 = 89,8
                                //0,4763039852757329
                                #define CALIBRATE_FACTOR 48 // amount of rain per rain bucket tip e.g. 5 is .05mm
                                MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
                                sensors_event_t event;
                                unsigned long lastSend;               //Last Send millis()
                                unsigned long lastTipTime=millis();
                                volatile unsigned int rainBucket=0;
                                void presentation()  {
                                  wait(DWELL_TIME);
                                  present(CHILD_ID_RAIN_LOG, S_RAIN);
                                  wait(DWELL_TIME);
                                #ifdef DHT_ON
                                  present(CHILD_ID_HUM, S_HUM);
                                  wait(DWELL_TIME);
                                  wait(DWELL_TIME);
                                //  M_DEBUG_PRINTLN(F("Sensor Presentation Complete"));
                                  // Set up the IO
                                  pinMode(TIP_SENSOR_PIN, INPUT);
                                  attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
                                  pinMode(ledPin, OUTPUT);
                                  digitalWrite(ledPin, HIGH);
                                void loop(){
                                  unsigned long now = millis();
                                  if (now - lastSend > SEND_FREQUENCY) {
                                  send(msgRain.set((float)rainBucket / 100, 1));
                                  rainBucket=0;
                                  wait(DWELL_TIME);
                                  // Get temperature event and print its value.
                                  double t = -1;
                                  dht.temperature().getEvent(&event);
                                  if (isnan(event.temperature)) {
                                    debug(PSTR("!USR:DHT:Error reading temperature!\n"));
                                      t = event.temperature;
                                      dtostrf(t,6,(uint8_t)2,buff);
                                      debug(PSTR("USR:DHT:t=%s\n"),buff);
                                      send(msgTemp.set(buff));
                                  // Get humidity event and print its value.
                                  double h = -1;
                                  dht.humidity().getEvent(&event);
                                  if (isnan(event.relative_humidity)) {
                                    debug(PSTR("!USR:DHT:Error reading humidity!\n"));
                                      h = event.relative_humidity;
                                      dtostrf(h,6,(uint8_t)2,buff);
                                      debug(PSTR("USR:DHT:h=%s\n"),buff);
                                      send(msgHum.set(buff));
                                    lastSend=now;
                                void sensorTipped()
                                  unsigned long thisTipTime = millis();
                                  if (thisTipTime - lastTipTime > 100UL)
                                    rainBucket += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
                                  lastTipTime = thisTipTime;
                                And now i able to see when it was a rain and how strong it was ;-)
                                SY
                                Sergey
                                • I itbeyond
                                  petewillP
                                  petewillP
                                  petewill
                                  @itbeyond Like @mfalkvidd pointed out eeprom writes are done to multiple locations so it actually gets 120 hours before the same eeprom location is used. So, 120 X 100,000 is over 1,000 years (if my math is right). That should be enough :)
                                  The good thing about using eeprom is that you won't loose any data if your gateway is down or the communication is lost for some reason.
                                  I think you are correct debugging other areas like the DHT. Also, is there a chance your arduino got wet? That could also cause issues.
                                  • H
                                    H
                                    haroon552
                                    Hi, dear how can we connect with application or something to watch and to connect with nidemcu?
                                    • sundberg84S
                                      sundberg84S
                                      #60
                                      Hello! This is my just revised rain gauge sensor. Working with Homeassistant and needs a tipping bucket which closes and opens a reed switch when tipping in the different directions. (Pro Mini 3.3v, Battery operated (voltage divider included in code) and NRF24 radio).
                                      #define MY_RADIO_RF24
                                      #define MY_NODE_ID 7
                                      #define MY_PARENT_NODE_ID 99
                                      #define DIGITAL_INPUT_SENSOR 3                  // The reed switch you attached.  (Only 2 and 3 generates interrupt!)
                                      #define CHILD_ID 1                              // Id of the sensor child
                                      #define SKETCH_NAME "Rain Gauge"                // Change to a fancy name you like
                                      #define SKETCH_VERSION "1.2"                    // Your version
                                      unsigned long SLEEP_TIME = 18 * 60000;          // Sleep time (in milliseconds).
                                      //unsigned long SLEEP_TIME = 20000;             // use this instead for debug
                                      float hwRainVolume = 0;                         // Current rainvolume calculated in hardware.
                                      int pulseCount = 0;                             // Pulsecount recieved from GW
                                      float fullCounter = 0;                           // Counts when to send counter
                                      float bucketSize = 0.5;                           // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
                                      boolean pcReceived = false;                     // If we have recieved the pulscount from GW or not
                                      int recrequestcount = 0;                        //Counter for how many times we request pulses before we reset it.
                                      boolean reedState;                              // Current state the reedswitch is in
                                      boolean oldReedState;                           // Old state (last state) of the reedswitch
                                      unsigned long lastSend = 0;                     // Time we last tried to fetch counter.
                                      MyMessage volumeMsg(CHILD_ID, V_RAIN);
                                      MyMessage lastCounterMsg(CHILD_ID, V_VAR1);
                                      // BATTERY MEASURER
                                      // VOLTAGE DIVIDER SETUP
                                      #define VMIN 2.2                                  //  Vmin (radio Min Volt)=1.9V (564v)
                                      #define VMAX 3.1                                  //  Vmax = (2xAA bat)=3.0V (892v)
                                        // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
                                        present(CHILD_ID, S_RAIN);
                                        // BATTERY MEASURER
                                        //Set internal ref to internal to be able to measure bat 0-1v
                                        //Make sure this fits other sensors using analogRead()!
                                        //If you have a sensor reporting 0-5v you need to change analogReference() before reading that sensor.
                                        analogReference(INTERNAL);
                                        //DEFAULT: the default analog reference of 5 volts (on 5V Arduino boards) or 3.3 volts (on 3.3V Arduino boards)
                                        //INTERNAL: an built-in reference, equal to 1.1 volts on the ATmega168 or ATmega328 and 2.56 volts on the ATmega8 (not available on the Arduino Mega)
                                        //EXTERNAL: the voltage applied to the AREF pin (0 to 5V only) is used as the reference.
                                        //Battery inital calc
                                        Serial.print("With Battery VMax (100%) = "); Serial.print(VMAX); Serial.print("volts and Vmin (0%) = "); Serial.print(VMIN); Serial.println(" volts");
                                        Serial.print("Battery Percent 25%/50%/75% calculates to: "); Serial.print(((VMAX - VMIN) / 4) + VMIN); Serial.print("/"); Serial.print(((VMAX - VMIN) / 2) + VMIN); Serial.print("/"); Serial.println(VMAX - ((VMAX - VMIN) / 4));
                                        delay(1000);
                                        delay(50);
                                        int batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN)) * 100.);
                                        Serial.print("Current battery are measured to (please confirm!): "); Serial.print(batteryPcnt); Serial.print(" % - Or "); Serial.print(Vbat); Serial.println(" Volts");
                                        pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);  // sets the reed sensor digital pin as input
                                        reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
                                        oldReedState = reedState; // Set startup position for reedswitch
                                        Serial.println("Startup completed");
                                      void loop()     {
                                        unsigned long currentTime = millis();
                                        //Read if the bucket tipped over
                                        Serial.println(reedState);
                                        Serial.println(oldReedState);
                                        boolean tipped = oldReedState != reedState;
                                        if (recrequestcount == 10 && !pcReceived) {
                                          //For some controllers, if you dont have any V_VAR1 stored node will not get an answer.
                                          //Try 10 times, then set V_VAR1 to 0 and update controller
                                          Serial.println("Set p-cnt and update controller");
                                          pcReceived = true;
                                          send(lastCounterMsg.set(pulseCount));  // Send pulse count 0 value to gw
                                          hwRainVolume = 0;
                                          send(volumeMsg.set((float)hwRainVolume, 1));
                                          lastSend = currentTime;
                                        //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
                                        if (!pcReceived && (currentTime - lastSend > 5000)) {
                                          request(CHILD_ID, V_VAR1);
                                      #ifdef MY_DEBUG
                                          Serial.println("Req p-cnt");
                                          recrequestcount = recrequestcount + 1;
                                          return;
                                        if (!pcReceived) {
                                          return;
                                        //BUCKET TIPS!
                                        if (tipped == true) {
                                          Serial.println("The bucket has tipped over...");
                                          hwRainVolume = hwRainVolume + bucketSize;
                                          wait(500);
                                          fullCounter = fullCounter + bucketSize;
                                          //Count so we send the counter for every 1mm
                                          if (fullCounter >= 1) {
                                            pulseCount++;
                                            wait(1000);
                                            fullCounter = 0;
                                        if (tipped == false) {
                                          //No bucket tipped over last sleep-period, check battery then...
                                          MeasureBattery();
                                        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME); //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
                                        if (message.getType() == V_VAR1) {
                                          pulseCount = message.getLong();
                                          Serial.print("Received last pulse count value from gw:");
                                          Serial.println(pulseCount);
                                          pcReceived = true;
                                      // BATTERY MEASURER
                                      void MeasureBattery() {  //The battery calculations
                                        delay(500);
                                        // Battery monitoring reading
                                        delay(500);
                                        // Calculate the battery in %
                                      #ifdef MY_DEBUG
                                        Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.print(" % - "); Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" Volts");
                                        if (batLoop > 2) {
                                          batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
                                          if (batteryPcnt > 100) {
                                            batteryPcnt = 100;
                                      #ifdef MY_DEBUG
                                          batLoop = 0;
                                          batLoop++;
                                      • D
                                        djal
                                        Hi all,
                                        thanks for sharing the models for 3D printing. I built one 3 years ago and it is still running with one pair of AA batteries, MySensors and Arduino Pro Mini.
                                        Last year I needed some adjustments and adaptations for friends so I got inspired and remodeled the rain gauge for 3Dprinter.
                                        Maybe it could be usefull for someone so I decided to share it here (https://www.prusaprinters.org/prints/130513-rain-gauge)
