  3. pir trigger must start delay
16 Posts 4 Posters 4.7k Views 3 Watching
  • DickD
    DickD
    Dick
    Is there anyone who can me help with the next step in getting this sensor to work. It is a combi of 3 relays, motion sensor and 2 temps. All works now but if the Motion is triggered it starts the SLEEP_TIME. but in this period I cannot use the buttons to activate the relays. How can I only stop the motion trigger (for a period of time) without affecting the test of the sensors.
    DickD m26872M 2 Replies Last reply
    • DickD Dick
      DickD
      DickD
      Dick
      Here the code to make it more clear
      @Dick said in pir trigger must start delay:
      // 2x binary switch + dallas temp example
      // digitial I/O pin 4,5 (BUTTON_PIN_4/BUTTON_PIN_5 below) and GND.
      // Connect dallas temp sensor to digital pin 3
      #include <OneWire.h>
      #define DIGITAL_MOTION_SENSOR 2
      #define CHILD_ID_MOTION 6
      #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
      #define RELAY_OFF 1
      Bounce motionsDebouncer = Bounce();
      int lastMOTION;
      unsigned long SLEEP_TIME = 60000;
      #define noRelays 3
      const int relayPin[] = {A3, A4, A5}; //  switch around pins to your desire
      const int buttonPin[] = {6, 7, 8}; //  switch around pins to your desire
      class Relay             // relay class, store all relevant data (equivalent to struct)
      public:
        int buttonPin;                    // physical pin number of button
        int relayPin;                     // physical pin number of relay
        byte oldValue;                    // last Values for key (debounce)
        boolean relayState;               // relay status (also stored in EEPROM)
      Relay Relays[noRelays];
      Bounce debouncerRELAY[noRelays];
      MyMessage msgRELAY[noRelays];
      int numSensors=0;
      boolean receivedConfig = false;
      boolean metric = true;
      MyMessage msg(0,V_TEMP);
      MyMessage msgMOTION(CHILD_ID_MOTION, V_TRIPPED);
        sensors.begin();
        //gw.begin();
        gw.sendSketchInfo("Motion/Temp/relay", "1.0");
        for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++)
          gw.present(i, S_TEMP);
      pinMode(DIGITAL_MOTION_SENSOR, INPUT_PULLUP);      // sets the motion sensor digital pin as input
        motionsDebouncer.attach(DIGITAL_MOTION_SENSOR);
        motionsDebouncer.interval(10);
        gw.present(CHILD_ID_MOTION, S_MOTION, "Motion needs presentation", true);
         for (int i = 0; i < noRelays; i++)
          Relays[i].buttonPin = buttonPin[i];              // assign physical pins
          msgRELAY[i].sensor = i;                                   // initialize messages
          msgRELAY[i].type = V_LIGHT;
          debouncerRELAY[i] = Bounce();                        // initialize debouncer
          debouncerRELAY[i].attach(buttonPin[i]);
          debouncerRELAY[i].interval(5);
          Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
          digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          gw.send(msgRELAY[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
          gw.present(i, S_LIGHT);                               // present sensor to gateway
          delay(250);
      for (byte i = 0; i < noRelays; i++)
          debouncerRELAY[i].update();
          byte value = debouncerRELAY[i].read();
          if (value != Relays[i].oldValue && value == 0)
            gw.saveState( i, Relays[i].relayState );
          }                 // save sensor state in EEPROM (location == sensor number)
          Relays[i].oldValue = value;
        if ( motionsDebouncer.update()) {
          int value = motionsDebouncer.read();
          Serial.println( "PIR " + (String)value );
          gw.send( msgMOTION.set( value ), true ); // Also it might need inverted value
      // Sleep until interrupt comes in on motion sensor. Send update.
        gw.sleep(DIGITAL_MOTION_SENSOR, CHANGE, SLEEP_TIME);
        updateTemperature(30);// update time in seconds
      void updateTemperature(int frequency)
        if (millis() - lastUpdateTime >= frequency * 1000UL)
          for (int i=0; i<numSensors && i< MAX_ATTACHED_DS18B20; i++)
            float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
            if (lastTemperature[i] != temperature && temperature != -127.00)
              gw.send(msg.setSensor(i).set(temperature,1));
          lastUpdateTime += frequency * 1000UL;
      void incomingMessage(const MyMessage &message)
        if (message.type == V_LIGHT)
          if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
            digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
            gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
      //gw.wait(50);
        During sleep you can only wake it up by using the interrupts of pins 2 and 3. Is it a battery powered node?
        • DickD Dick
          m26872M
          m26872M
          m26872
          wrote on last edited by m26872
          @Dick You should use a non-blocking code. Replace your if ( motionsDebouncer.update()) {...} with an updateMotion(SLEEP_TIME); which could be something like
          void updateMotion(unsigned long blockedMotionTime)
            if (millis() - lastUpdateTime >= blockedMotionTime)
          		lastUpdateTime += blockedMotionTime;
          Never use sleep if you want to listen for incoming messages. wait is not good either since you expect button press. Buttons could use an interruptpin if needed, but it looks like your not on battery.
          DickD 2 Replies Last reply
          • m26872M m26872
            DickD
            DickD
            Dick
            @m26872
            thanks for the short lesson. I change the code it test it.
            • m26872M m26872
              DickD
              DickD
              Dick
              @m26872 I implemented the function but it does not work. I also read more about the NON BLOCKING code. is new for me. At the moment the pir pin give no reaction. nothing happend with the new function. The relays and temp sensors are working fine. Any idea to get it work so I can see a working example so I can use it in my other sensors.
              m26872M 1 Reply Last reply
              • DickD Dick
                m26872M
                m26872M
                m26872
                @Dick I'm no code expert, but I would make the two lastUpdateTime-variables as global ones and initialize them with 0.
                DickD 1 Reply Last reply
                • m26872M m26872
                  DickD
                  DickD
                  Dick
                  @m26872 it is all new for me this solution. How can I make them global?? that means outside the function? is that the only thing I have to do?
                  • DickD Dick
                    m26872M
                    m26872M
                    m26872
                    @Dick Since they are 'static' I think you only need to initialize them with 0 , maybe not even that. I simply dont know. Your problem could be something else too. Sorry.
                    • m26872M m26872
                      DickD
                      DickD
                      Dick
                      @m26872 No Problem. I continue reading. If someone else knows what to do please reply.
                      • BartEB
                        BartEB
                        BartE
                        wrote on last edited by BartE
                        Replace this piece of code
                        with something like this
                        if (blockMotionTimer == 0) {
                            if (motionsDebouncer.update()) {
                                blockMotionTimer = (millis() + SLEEP_TIME);
                                motionsDebouncer.update(); // dummy update to prevent false trigger after timer expires
                                if (blockMotionTimer < millis()) {
                                    blockMotionTimer = 0;
                        Add this line at the top of your sketch (just below SLEEP_TIME)
                        unsigned long blockMotionTimer = 0;
                        • BartEB BartE
                          DickD
                          DickD
                          Dick
                          @BartE Hi Bart thanks for the solution but hopefully you can help me with the last hurdle:
                          I added your solution, after starting the node I can activate the PIR once (it state change from 1 to 0) and stays in 0 and will not change anymore.
                          Here the code as it is now
                          #define RELAY_OFF 1
                          int lastMOTION;
                          unsigned long SLEEP_TIME = 3600;
                          #define noRelays 3
                          public:
                          int numSensors=0;
                            sensors.begin();
                            //gw.begin();
                            motionsDebouncer.interval(400);
                              delay(250);
                          //gw.wait(50);
                          • BartEB
                            BartEB
                            BartE
                            @Dick mm look like a } on the wrong line. The } on line 126 should move up between line 119 and 120
                            (and there are 2 additional brackets)
                            The result should look like this
                            • BartEB BartE
                              DickD
                              DickD
                              Dick
                              @BartE It works fine. Now I try to understand how it works, have found already some documentation about this item. again thanks!
                              BartEB 1 Reply Last reply
                              • DickD Dick
                                BartEB
                                BartEB
                                BartE
                                @Dick nice to hear
                                How it works:
                                As long as 'blockMotionTimer' is zero the motion debouncer is being monitored for any change.
                                When a PIR-change is detected the blockMotionTimer gets the value of the Arduino's internal milliseconds timer + the delay in milliseconds one want to wait.
                                This happes on this line: "blockMotionTimer = (millis() + SLEEP_TIME);"
                                See more about the millis() here
                                The blockMotionTimer is set back to zero the when mills() reaches the value set for time-out done with this check "if (blockMotionTimer < millis()) {" , and because the blockMotionTimer is non-zero the PIR value will not be checked during this period.
                                Expert note: since the milliseconds counter is returned in an unsigned long it will carry over one moment in time. Since Arduino stores it's ulong in 32 bits this means a carry over each 2^32 thus 4294967296 milliseconds. This is approx. every 50 days (49,71 days) So in theory this mechanism could result in a wrong (very short) delay, when timer is started precisely with the SLEEP_TIME period just before these 49,71 days. The result of millis() + SLEEP_TIME will then carry over and is immediate smaller than millis() on the next check. So be aware that this check if (blockMotionTimer > (millis() - SLEEP_TIME)) can result in a death-lock when blockMotionTimer = millis(); was set on the wrong moment in time.
                                • BartEB BartE
                                  @Dick nice to hear
                                  How it works:
                                  DickD
                                  DickD
                                  Dick
                                  @BartE What an extended answere. Here I can do something with. Good learning stuff.
