  3. Unexpected behavior with satatic IP adress (Ethernet Gateway)
7 Posts 3 Posters 1.6k Views 2 Watching
  • S Offline
    Solmorth
    wrote on last edited by Solmorth
    I copied the sample code from here and changed only ip adresses.
    But in serial console I see that arduino does not use static IP just to draw others. Somethimes they hit the correct ip for a moment.
    The screenshot will describe it better.
    When I use example from arduino.cc site everything work fine
    I use:
    arduino ide v 1.8.3
    MySensors 2.1.1
    • S Solmorth
      I use:
      arduino ide v 1.8.3
      MySensors 2.1.1
      @Solmorth the printed IP addresses are all over the place, including invalid addresses. I would suspect memory corruption. How much ram does the sketch use? (This is shown in the Arduino IDE when the sketch is compiled)
      • S Offline
        Solmorth
        Sketch uses 23860 bytes (77%). Global variables uses 1097 bajtów (53%)
        • S Solmorth
          @Solmorth 47% free ram should be plenty, so that should not be the problem. I don't have any other ideas unfortunately.
          • S Offline
            Solmorth
            Anyway, Thank you for your help
            • M Offline
              M Offline
              m26872
              I experienced something similiar lately with a few my W5100 modules. It went away when I moved from my breadboard setup to soldered cabels.
              • S Offline
                Solmorth
                But, when I use example from arduino.cc site everything work fine. (Links at first post).
                Tested on Nano, uno r3 and breadboard (328p with optiboot 6.2).
