  3. Waterpulse Sensor - ESP8266GW without Radio only as node
14 Posts 3 Posters 3.6k Views 3 Watching
  • HarrySteffH Offline
    HarrySteffH Offline
    HarrySteff
    wrote on last edited by HarrySteff
    Dear experts,
    i tried to setup my Wemos D1 mini Board as a node.
    I used 2.2.0 Beta version of Mysensors API.
    But it seems that only the gateway part is starting. Sensors are not presenting (serial monitor) nothing happens here after connection to WLAN is established...
    Am i correct? These defines are for (W)LAN communication with my Gateway(192.168.0.136):
    #define MY_USE_UDP
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 136
    Here my whole sketch:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "Fritzbox7390"
    #define MY_ESP8266_PASSWORD "xxx"
    // Enable UDP communication
    #define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_ESP8266_HOSTNAME "waterpulse-sensor"
    #define MY_IP_ADDRESS 192,168,0,137
    #define MY_PORT 5003
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
    #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
    #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
    #define MY_NODE_ID 17                           // Static Node ID
    #define CHILD_ID 1                              // Id of the sensor child
    #include <ESP8266WiFi.h>
    unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
    MyMessage flowMsg(CHILD_ID,V_FLOW);
    MyMessage volumeMsg(CHILD_ID,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
    volatile uint16_t pulseCount = 0;
    volatile uint16_t lastBlink = 0;
    volatile double flow = 0;
    bool pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long newBlink = 0;
    double oldflow = 0;
    double volume =0;
    double oldvolume =0;
    unsigned long lastSend =0;
    unsigned long lastPulse =0;
        // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
        pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
        pulseCount = oldPulseCount = 0;
        request(CHILD_ID, V_VAR1);
        lastSend = lastPulse = millis();
        attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
        sendSketchInfo("Water Meter", "1.1");
        // Register this device as Waterflow sensor
        present(CHILD_ID, S_WATER);
        unsigned long currentTime = millis();
        if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY)) {
            lastSend=currentTime;
            if (!pcReceived) {
                //Last Pulsecount not yet received from controller, request it again
                return;
            if (!SLEEP_MODE && flow != oldflow) {
                oldflow = flow;
                Serial.print("l/min:");
                Serial.println(flow);
                // Check that we dont get unresonable large flow value.
                if (flow<((unsigned long)MAX_FLOW)) {
                    send(flowMsg.set(flow, 2));                   // Send flow value to gw
            // No Pulse count received in 2min
            if(currentTime - lastPulse > 120000) {
                flow = 0;
            // Pulse count has changed
            if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                oldPulseCount = pulseCount;
                Serial.print("pulsecount:");
                Serial.println(pulseCount);
                send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                if ((volume != oldvolume)||(!SLEEP_MODE)) {
                    oldvolume = volume;
                    Serial.print("volume:");
                    Serial.println(volume, 3);
                    send(volumeMsg.set(volume, 3));               // Send volume value to gw
        if (SLEEP_MODE) {
            sleep(SEND_FREQUENCY);
        if (message.type==V_VAR1) {
            unsigned long gwPulseCount=message.getULong();
            pulseCount += gwPulseCount;
            flow=oldflow=0;
            Serial.print("Received last pulse count from gw:");
            pcReceived = true;
    void onPulse()
        if (!SLEEP_MODE) {
            unsigned long interval = newBlink-lastBlink;
            if (interval!=0) {
                if (interval<500000L) {
                    // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                    return;
                flow = (60000000.0 /interval) / ppl;
            lastBlink = newBlink;
        pulseCount++;
    Hope that somebody has an idea...
      HarrySteffH Offline
      HarrySteff
      Mhhh, nobody has an idea?
      It seems that the sensor did not "start" the "void presentation()" section of sketch... :-(
      • HarrySteffH HarrySteff
        @HarrySteff the code looks good to me. Could you post the full debug output?
          HarrySteffH Offline
          HarrySteff
          Okay i will, as soon as I'am back home... maybe monday! Thank you so far
            What controller are you using? Because I'd comment out the define my controller address
              HarrySteffH Offline
              HarrySteff
              Iam using Pimatic, but only for displaying Sensor values. I set my node ID's manually...
                HarrySteffH Offline
                HarrySteff
                @mfalkvidd Here is my Serial Output:
                MCO:BGN:INIT GW,CP=R-NGE---,VER=2.2.0-beta
                scandone
                f 0, scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 0 (29)
                ..reconnect
                f -180, scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 0 (29)
                ..reconnect
                f r0, scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 0 (29)
                ..reconnect
                f 0, .scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 0 (29)
                ..reconnect
                f -180, scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 0 (29)
                ..reconnect
                f r0, scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 3
                cnt
                connected with Fritzbox7390, channel 10
                ip:192.168.0.137,mask:255.255.255.0,gw:192.168.0.1
                .IP: 192.168.0.137
                0;255;3;0;9;6400 MCO:BGN:STP
                0;255;3;0;9;6473 MCO:REG:NOT NEEDED
                0;255;3;0;9;6510 MCO:BGN:INIT OK,TSP=NA
                pm open,type:2 0
                And nothing more happens...
                I tried to give out some serial prints in "void presentation" section, but they did not appear...
                Strange...
                For what is the MY_CONTROLLER_IP_ADRESS ? The IP i inserted here is the IP from my other/main "Mysensors-Gateway..."
                  scandone
                  f 0, scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 0 (29)
                  ..reconnect
                  f -180, scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 0 (29)
                  ..reconnect
                  f r0, scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 0 (29)
                  ..reconnect
                  f 0, .scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 0 (29)
                  ..reconnect
                  f -180, scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 0 (29)
                  ..reconnect
                  f r0, scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 3
                  cnt
                  .IP: 192.168.0.137
                  pm open,type:2 0
                  Strange...
                  @HarrySteff a controller and a gateway are different things. See https://www.mysensors.org/about/network#the-controller for information on what a controller is.
                  Try removing that define as per gohan's recommendation.
                    HarrySteffH Offline
                    HarrySteff
                    Okay i understood this, but how does my ESP8266 node (only wifi) knows where the gateway is`?
                    I think i must tell it somwhere?
                    I will try to remove defined
                    MY_CONTROLLER_IP_ADRESS & MY_USE_UDP
                    posting serial output here...
                      it doesn't, if you use a esp8266 as a node without nrf24/rmf69 radio it needs to be a gateway on its own
                        HarrySteffH Offline
                        HarrySteff
                        It is a gateway, here the serial output:
                        (nothing changes)
                        ⸮Hl⸮G⸮C⸮d⸮xpI⸮⸮0;255;3;0;9;338 MCO:BGN:INIT GW,CP=R-NGE---,VER=2.2.0-beta
                        scandone
                        f 0, scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 1
                        cnt
                        .IP: 192.168.0.137
                        0;255;3;0;9;899 MCO:BGN:STP
                        0;255;3;0;9;948 MCO:REG:NOT NEEDED
                        0;255;3;0;9;1004 MCO:BGN:INIT OK,TSP=NA
                        pm open,type:2 0
                        No local atached Sensor is presented?!?
                        I use a wemos d1 Mini...
                        Sensor is connected to Port D2
                        What digital-Input-Port Must i use?
                        I found some Pin mappings:
                        There it is Port 4
                          On the controller, did you add the 192.168.0.137 as a mysensors gateway?
                            HarrySteffH Offline
                            HarrySteff
                            No, until now i did not, but do i need a controller at all?
                            (In my opinion it should present values even i do not have a controller)
                            So now i even disabled the define of the controller IP in my sketch...
                              The esp8266 is a complete stand alone mysensors network, it can't interact with the other unless you use a controller in between
