  2. Announcements
  3. 💬 Advanced Gateway Options
59 Posts 16 Posters 35.3k Views 13 Watching
    Doesn't this error message show when you are trying to compile?
    https://github.com/mysensors/MySensors/blob/dd9dff77ed1948db2b348bbdb82d0d3daa9e8e3a/MySensors.h#L89-L93
    • proddyP proddy
      MY_LEDS_BLINKING_FEATURE is now obsolete in the latest 2.1
      @Paul-Derbyshire thanks for noticing. I have removed MY_LEDS_BLINKING_FEATURE from the instructions.
      • maghacM
        maghacM
        maghac
        Got the LEDs working now, after some issues relating to the weird GPIO mapping on the NodeMCU.
        However, they are always on, and only blink off when receiving or transmitting. Is this intended? Can it be inverted (so they are off normally but only on when there is activity).
        Also, under what circumstances will the ERR led blink?
        S 1 Reply Last reply
        • E
          E
          emc2
          @maghac said in 💬 Advanced Gateway Options:
          You should be able to use
          But because of the weird wiring on esp8266 based boards it's always a hit or miss, some LEDs should be inversed, some other not. You may have to play with pull-ups or pull-downs resistors on some pins.
          • mppM
            mppM
            mpp
            What would be needed to make this work with the MQTT gateway?
            MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
            • bbarriereB
              bbarriereB
              bbarriere
              Hello Builders,
              i am building a arduino 2560 node and i would like to activate radio blinking LED.
              I have tested to insert lines regarding Blinking for pins 4,5,6 but there is a issue :
              0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
              3 MCO:BGN:BFR
              203 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
              208 !MCO:SLP:REP
              1 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
              5 MCO:BGN:BFR
              205 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
              209 !MCO:SLP:REP
              4 MCO:BGN:BFR
              204 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
              209 !MCO:SLP:REP
              5 MCO:BGN:BFR
              209 !MCO:SLP:REP
              4 MCO:BGN:BFR
              209 !MCO:SLP:REP
              5 MCO:BGN:BFR
              209 !MCO:SLP:REP
              4 MCO:BGN:BFR
              209 !MCO:SLP:REP
              Radio don't want initialized and probably the 2560 pinout don't work for blinking with pins 4,5,6.
              Are there a specific pinout for 2560 for radio blinking ?
              • tomtasticT
                tomtasticT
                tomtastic
                For an RFM69HW, is anything other than '#define MY_RADIO_RFM69' required to make use of the higher tx power?
                • tomtasticT tomtastic
                  @tomtastic yes. define MY_IS_RFM69HW.
                  References:
                  https://github.com/mysensors/MySensors/blob/726a20dad9696ed86408106061a9e0be31995b5c/MyConfig.h#L800
                  https://www.mysensors.org/build/connect_radio (Scroll down to Configuring MySensors for RFM69)
                  tomtasticT 1 Reply Last reply
                    References:
                    tomtasticT
                    tomtasticT
                    tomtastic
                    @mfalkvidd Thats great, many thanks!
                    Still much to learn and finding important snippets of information here and there.
                    I feel like both the options 'MY_RFM69_FREQUENCY RF69_433MHZ' and 'MY_IS_RFM69HW' should probably be mentioned in the SensebenderGatewaySerial.ino configuration file example lines.
                    • R
                      R
                      r-nox
                      • pihomeP
                        pihomeP
                        pihome
                        is there a way to have one led that show if controller is connected to gateway ?
                        PiHome - Smart Heating Control
                        • maghacM maghac
                          Strixx
                          @maghac What pins are you using for the LEDs? I have been investigating the GPIO vs PIN layout for the NodeMCU now for several hours. And I am still not shore which I shall use.
                          I have found complete maps for the GPIO and thought I had it all figured out. But then I saw in the example code for the gateway (GatewayESP8266.ino) the following:
                           * Inclusion mode button:
                          But on NodeMCU GPIO5 is PIN D1 and not D3 (which is GPIO0)
                          So please... Anyone... What pins on the NodeMCU is usable for connecting radio traffic LEDs, and how do I name them in the code?
                          maghacM 1 Reply Last reply
                          • S Strixx
                            maghacM
                            maghacM
                            maghac
                            @Strixx Sorry, I don't remember and I have since then stopped using the LEDs. Couldn't get the inverse feature to work and I realized having LED indicators were not all that useful anyway in the end. If the gateway works, I will see it on MQTT traffic anyway.
                            • maghacM maghac
                              Strixx
                              @maghac Well... I guess you are right about how useful the LEDs are. But I still would like to learn how to use the NodeMCU. And then there is also this, shall we call it OCD... ;-)
                              • mntlvrM
                                mntlvrM
                                mntlvr
                                So what is the finial solution to using the Led's on a ESP 8266-E gateway are they of any use if using a Vera Controller?
                                I have used them when I had a working Ethernet gateway but I am wanting to use an Esp 8266-E gateway now . What pins do one use on ESP device
                                Thanks for the help
                                S 2 Replies Last reply
                                • mntlvrM mntlvr
                                  Thanks for the help
                                  Strixx
                                  @mntlvr I am using D1, D9 and D10. And it works perfectly on NodeMCU 0.9. Without the need of "MY_WITH_LEDS_BLINKING_INVERSE".
                                  Here is the code:
                                  // Set blinking period (in milliseconds)
                                  // Flash leds on rx/tx/err
                                  // Internal onboard LED is PIN 16
                                  #define MY_DEFAULT_ERR_LED_PIN D10  // Error led pin (Red)
                                  #define MY_DEFAULT_RX_LED_PIN  D9  // Receive led pin (Yellow)
                                  #define MY_DEFAULT_TX_LED_PIN  D1  // Transmit led pin (Green)
                                  • mntlvrM
                                    mntlvrM
                                    mntlvr
                                    Thanks Strixx
                                    I am using D4 D5 D9 D10
                                    and as soon as I can get the unit to work with either of my Vera's I will know if mine works. It seems sinceI have gone over to the newest Library none of the gateways I build works.
                                    • mntlvrM mntlvr
                                      Thanks for the help
                                      Strixx
                                      @mntlvr said in 💬 Advanced Gateway Options:
                                      I have had a lot of help with the leds. I have noticed that you get a lot of errors (in some positions it is impossible to communicate with the nodes at all) if not the radio is positioned to close to the ESP. It seems to me that the radio on the NodeMCU interferes with the NRF24L01+PA+LNA that i am using on my gateway. I found I thread on this forum about it but can't find it again.
                                      So thanks to the leds I have been able to build a box where i have no transmission errors due to interference.
                                      mntlvrM 1 Reply Last reply
                                      • mntlvrM mntlvr
                                        Thanks Strixx
                                        Strixx
                                        Thanks Strixx
                                        Don't know what radio you are using, but for the NRF24L01+ D5 is used for the radio.
                                        And D4 is not possible to use for LED. It can not be high or low on boot. That has some special purpose.
                                        The only pins available for LED is the ones I use. D1, D9 and D10.
                                        I use D4 for inclusion button. That works as long as I don't press the button at startup of gateway. Then it will not start.
                                        • mntlvrM
                                          mntlvrM
                                          mntlvr
                                          wrote on last edited by mntlvr
                                          #23
                                          Yes on the 8266-E devkit V3 ,D1 is GPIO 5, D9 is the GPIO 03 (RX) and D10 is GPIO 01 (TX) D5 is GPIO 14 so I am using GPIO 05 and 01 and 03 and 02 . So I guess I am not clear as to what you use GPIO pins or lettered pins on 8266. On V3 of the 8266-E the builtin LED is on GPIO 2 which is D4 so when I tried your hookup All I got was Builtin LED on 100% and exception errors and would not boot
                                          I will wait for your reply and thanks this may help if I am on the same page as you
