  2. Announcements
  3. 💬 Advanced Gateway Options
59 Posts 16 Posters 30.9k Views 13 Watching
  • H Offline
    H Offline
    wrote on last edited by hek
    This thread contains comments for the article "Advanced Gateway Options" posted on MySensors.org.
    • proddyP Offline
      proddyP Offline
      proddy
      MY_LEDS_BLINKING_FEATURE is now obsolete in the latest 2.1
      • maghacM Offline
        maghacM Offline
        maghac
        Is there a new way to get the radio status LEDs?
        • H Offline
          H Offline
          Doesn't this error message show when you are trying to compile?
          https://github.com/mysensors/MySensors/blob/dd9dff77ed1948db2b348bbdb82d0d3daa9e8e3a/MySensors.h#L89-L93
          • proddyP proddy
            @Paul-Derbyshire thanks for noticing. I have removed MY_LEDS_BLINKING_FEATURE from the instructions.
            • maghacM Offline
              maghacM Offline
              maghac
              Got the LEDs working now, after some issues relating to the weird GPIO mapping on the NodeMCU.
              However, they are always on, and only blink off when receiving or transmitting. Is this intended? Can it be inverted (so they are off normally but only on when there is activity).
              Also, under what circumstances will the ERR led blink?
              S 1 Reply Last reply
              • E Offline
                E Offline
                emc2
                @maghac said in 💬 Advanced Gateway Options:
                You should be able to use
                But because of the weird wiring on esp8266 based boards it's always a hit or miss, some LEDs should be inversed, some other not. You may have to play with pull-ups or pull-downs resistors on some pins.
                • mppM Offline
                  mppM Offline
                  mpp
                  What would be needed to make this work with the MQTT gateway?
                  MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
                  • bbarriereB Offline
                    bbarriereB Offline
                    bbarriere
                    Hello Builders,
                    i am building a arduino 2560 node and i would like to activate radio blinking LED.
                    I have tested to insert lines regarding Blinking for pins 4,5,6 but there is a issue :
                    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                    3 MCO:BGN:BFR
                    203 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    208 !MCO:SLP:REP
                    1 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                    5 MCO:BGN:BFR
                    205 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    209 !MCO:SLP:REP
                    4 MCO:BGN:BFR
                    204 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    209 !MCO:SLP:REP
                    5 MCO:BGN:BFR
                    209 !MCO:SLP:REP
                    4 MCO:BGN:BFR
                    209 !MCO:SLP:REP
                    5 MCO:BGN:BFR
                    209 !MCO:SLP:REP
                    4 MCO:BGN:BFR
                    209 !MCO:SLP:REP
                    Radio don't want initialized and probably the 2560 pinout don't work for blinking with pins 4,5,6.
                    Are there a specific pinout for 2560 for radio blinking ?
                    • tomtasticT Offline
                      tomtasticT Offline
                      tomtastic
                      For an RFM69HW, is anything other than '#define MY_RADIO_RFM69' required to make use of the higher tx power?
                      • tomtasticT tomtastic
                        @tomtastic yes. define MY_IS_RFM69HW.
                        References:
                        https://github.com/mysensors/MySensors/blob/726a20dad9696ed86408106061a9e0be31995b5c/MyConfig.h#L800
                        https://www.mysensors.org/build/connect_radio (Scroll down to Configuring MySensors for RFM69)
                        tomtasticT 1 Reply Last reply
                          References:
                          tomtasticT Offline
                          tomtasticT Offline
                          tomtastic
                          @mfalkvidd Thats great, many thanks!
                          Still much to learn and finding important snippets of information here and there.
                          I feel like both the options 'MY_RFM69_FREQUENCY RF69_433MHZ' and 'MY_IS_RFM69HW' should probably be mentioned in the SensebenderGatewaySerial.ino configuration file example lines.
                          • R Offline
                            R Offline
                            r-nox
                            • pihomeP Offline
                              pihomeP Offline
                              pihome
                              is there a way to have one led that show if controller is connected to gateway ?
                              PiHome - Smart Heating Control
                              • maghacM maghac
                                Strixx
                                @maghac What pins are you using for the LEDs? I have been investigating the GPIO vs PIN layout for the NodeMCU now for several hours. And I am still not shore which I shall use.
                                I have found complete maps for the GPIO and thought I had it all figured out. But then I saw in the example code for the gateway (GatewayESP8266.ino) the following:
                                 * Inclusion mode button:
                                But on NodeMCU GPIO5 is PIN D1 and not D3 (which is GPIO0)
                                So please... Anyone... What pins on the NodeMCU is usable for connecting radio traffic LEDs, and how do I name them in the code?
                                maghacM 1 Reply Last reply
                                • S Strixx
                                  maghacM Offline
                                  maghacM Offline
                                  maghac
                                  @Strixx Sorry, I don't remember and I have since then stopped using the LEDs. Couldn't get the inverse feature to work and I realized having LED indicators were not all that useful anyway in the end. If the gateway works, I will see it on MQTT traffic anyway.
                                  • maghacM maghac
                                    Strixx
                                    @maghac Well... I guess you are right about how useful the LEDs are. But I still would like to learn how to use the NodeMCU. And then there is also this, shall we call it OCD... ;-)
                                    • mntlvrM Offline
                                      mntlvrM Offline
                                      mntlvr
                                      So what is the finial solution to using the Led's on a ESP 8266-E gateway are they of any use if using a Vera Controller?
                                      I have used them when I had a working Ethernet gateway but I am wanting to use an Esp 8266-E gateway now . What pins do one use on ESP device
                                      Thanks for the help
                                      S 2 Replies Last reply
                                      • mntlvrM mntlvr
                                        Thanks for the help
                                        Strixx
                                        @mntlvr I am using D1, D9 and D10. And it works perfectly on NodeMCU 0.9. Without the need of "MY_WITH_LEDS_BLINKING_INVERSE".
                                        Here is the code:
                                        // Set blinking period (in milliseconds)
                                        // Flash leds on rx/tx/err
                                        // Internal onboard LED is PIN 16
                                        #define MY_DEFAULT_ERR_LED_PIN D10  // Error led pin (Red)
                                        #define MY_DEFAULT_RX_LED_PIN  D9  // Receive led pin (Yellow)
                                        #define MY_DEFAULT_TX_LED_PIN  D1  // Transmit led pin (Green)
                                        • mntlvrM Offline
                                          mntlvrM Offline
                                          mntlvr
                                          Thanks Strixx
                                          I am using D4 D5 D9 D10
                                          and as soon as I can get the unit to work with either of my Vera's I will know if mine works. It seems sinceI have gone over to the newest Library none of the gateways I build works.
                                          12.1k
