  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
  • C
    C
    ceech
    There is a Maxim integrated buck-boost converter, that goes down to 0.7V
    http://www.mouser.com/ds/2/256/MAX1584-MAX1585-43040.pdf
    It's quite complex though
    alexsh1A 1 Reply Last reply
      @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
      Interesting buck-boost converter, but Input voltage is from 1.8v to 5.5v.
      I'm looking at the one with a better range of 0.9-5.5V
      I need to use two 2.7V super caps in series with a maximum efficiency
      According to its datasheet (http://www.ti.com/product/TPS63030), the TPS63030 has exactly the same Input Voltage Range: 1.8 V to 5.5 V
      alexsh1A
      alexsh1A
      alexsh1
      @NeverDie you are correct - TPS63030 has got 1.8-5.5V input voltage.
      I wonder if there is a buck-boost converter with lower than 1V lower voltage?
      • C ceech
        alexsh1A
        alexsh1A
        alexsh1
        @ceech you bet - personally I'd stick to something much more simple
        • alexsh1A alexsh1
          You'd probably get the biggest range by combining a separate boost converter with a separate buck converter, rather than using a single integrated buck-boost unit.
            Well, so far the green supercap isn't holding its charge any better. I'll leave it in-circuit for two or three days, though, and see if that improves. It's encouraging that the rate of voltage decrease is decreasing. Some supercaps apparently improve their ability to retain charge if they are forced to hold a charge long enough, though I have no idea why that is. For instance, some capacitor leakage test protocols call for holding a capacitor at its rated voltage for 72 hours before running the leakage test.
            #195
            @NeverDie said in How best to find the "best" small solar panel of a particular size?:
            Well, try as I might, I just can't recommend these Chinese supercaps. I've held them at rated voltage for days on end, and I've power cycled them too. For whatever reason, they just don't perform as well as the branded supercaps that I've ordered from Digikey. I'll use-up the few I have on some throw-away prototype experiments, and I won't be ordering any more of them. Presently I think the 10F supercap on Digikey for $2 from Illinois Capacitor continues to be the best of the "value" capacitors. For best performance, I've been pleased with the AVX brand of supercaps.
            However, if someone finds something better, either by value or by performance, please do post and let me know.
              alexsh1A
              alexsh1A
              alexsh1
              #196
              @NeverDie I have a few AVX caps and they are really good
              • C
                C
                ceech
                wrote on last edited by ceech
                #197
                A few boards arrived and a couple are assembled
                The board charges four 1.5F 2.7V super capacitors. It also provides a boost circuit with 3.45V output on main and sub outputs. It works down to 180mV and provides 3.5mA for 30 minutes. I'll report on leakage.
                There are two outputs main and sub. Main is on all the time and sub is switched with high signal on the mode connector.
                gohanG 1 Reply Last reply
                • C ceech
                  @ceech is the output clean enough to power a nrf24?
                  wallyllamaW 1 Reply Last reply
                    wallyllamaW
                    wallyllamaW
                    wallyllama
                    @gohan if not you could add.... wait for it.... a capacitor. (Weak, I know, but I couldnt resist)
                      Unfortunately it's not that easy, it depends on the type of "noise" created by the booster so one type of capacitor is better than another, a low pass filter may be needed.
                      • C
                        C
                        ceech
                        Noise isn't bad at all. Surprisingly. It is no bigger than the background noise when no input is connected.
                        • C ceech
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @ceech very impressive! I really like:
                          the boost to 3.45V works until the board voltage (between pin 5 and GND) goes down to 180mV?
                          C 1 Reply Last reply
                          • alexsh1A alexsh1
                            C
                            C
                            ceech
                            @alexsh1 Yes, the boost converter works down to 180mV. In other words, it can almost completely discharge capacitors.
                            • C ceech
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @ceech Which brand of caps you are using?
                              I may be interested in this board too.
                              I am currently running your other board with two 10F caps in a test mode with a sensor. Do not have much time for it now, most likely will report in September about my findings.
                              • alexsh1A alexsh1
                                C
                                C
                                ceech
                                @alexsh1 Normally I use AVX brand.
                                • C
                                  C
                                  ceech
                                  Here is a link to openhardware page.
                                  • C ceech
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #207
                                    @ceech They are very good - I ordered a few myself.
                                    Have you looked at using a flat super caps?
                                    http://sigma.octopart.com/17606633/image/Maxwell-Technologies-PC10.jpg
                                      @gohan
                                      If it became an issue, you could turn off the boost converter while doing the radio receptions, and then turn it back on. Unless you were in some sort of continuous receive mode, which would drain things pretty quickly anyway.
                                      • alexsh1A alexsh1
                                        C
                                        C
                                        ceech
                                        @alexsh1 I think they are being discontinued.
                                        • C ceech
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @ceech all of them? I mean you get the idea. As flat as possible. Size, size and size ...
                                          NeverDieN C 2 Replies Last reply
