  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
  • C ceech
    A few boards arrived and a couple are assembled
    The board charges four 1.5F 2.7V super capacitors. It also provides a boost circuit with 3.45V output on main and sub outputs. It works down to 180mV and provides 3.5mA for 30 minutes. I'll report on leakage.
    There are two outputs main and sub. Main is on all the time and sub is switched with high signal on the mode connector.
    @ceech is the output clean enough to power a nrf24?
    wallyllamaW 1 Reply Last reply
      wallyllamaW
      wallyllamaW
      wallyllama
      @gohan if not you could add.... wait for it.... a capacitor. (Weak, I know, but I couldnt resist)
        Unfortunately it's not that easy, it depends on the type of "noise" created by the booster so one type of capacitor is better than another, a low pass filter may be needed.
        • C
          C
          ceech
          Noise isn't bad at all. Surprisingly. It is no bigger than the background noise when no input is connected.
          alexsh1A 1 Reply Last reply
          • C ceech
            alexsh1A
            alexsh1A
            alexsh1
            @ceech very impressive! I really like:
            the boost to 3.45V works until the board voltage (between pin 5 and GND) goes down to 180mV?
            C 1 Reply Last reply
            • alexsh1A alexsh1
              C
              C
              ceech
              @alexsh1 Yes, the boost converter works down to 180mV. In other words, it can almost completely discharge capacitors.
              • C ceech
                alexsh1A
                alexsh1A
                alexsh1
                @ceech Which brand of caps you are using?
                I may be interested in this board too.
                I am currently running your other board with two 10F caps in a test mode with a sensor. Do not have much time for it now, most likely will report in September about my findings.
                • alexsh1A alexsh1
                  C
                  C
                  ceech
                  @alexsh1 Normally I use AVX brand.
                  • C
                    C
                    ceech
                    Here is a link to openhardware page.
                    • C ceech
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #207
                      @ceech They are very good - I ordered a few myself.
                      Have you looked at using a flat super caps?
                      http://sigma.octopart.com/17606633/image/Maxwell-Technologies-PC10.jpg
                        @gohan
                        If it became an issue, you could turn off the boost converter while doing the radio receptions, and then turn it back on. Unless you were in some sort of continuous receive mode, which would drain things pretty quickly anyway.
                        • alexsh1A alexsh1
                          C
                          C
                          ceech
                          @alexsh1 I think they are being discontinued.
                          • C ceech
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @ceech all of them? I mean you get the idea. As flat as possible. Size, size and size ...
                            NeverDieN C 2 Replies Last reply
                            • alexsh1A alexsh1
                              @alexsh1
                              See if you can find something you like on Digikey. They categorize by active, obsolete, and discontinued.
                                @alexsh1
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @NeverDie Digikey is good, but too expensive for me. I have to order minimum £33 to have a free delivery.
                                I still may use them as the search engine only.
                                Thanks for heads up
                                • alexsh1A alexsh1
                                  Thanks for heads up
                                  @alexsh1
                                  yeah, that's what I meant. You needn't buy from them.
                                  • alexsh1A alexsh1
                                    C
                                    C
                                    ceech
                                    @alexsh1 Manufacturers are probably not very keen on making them, since the production costs are higher.
                                    • X
                                      X
                                      xgarb
                                      I've been following this thread and have bought a variety of little panels to experiment with.
                                      These 5.5v 4F 'supercaps' have arrived in the post and I'm not sure how I should test them.
                                      https://www.aliexpress.com/item/2Pcs-ultra-capacitor-5-5v4f-super-capacitor-H-style-For-promotion-Now-Lowest-Price/32571210201.html
                                      For now I would just like to see how well they hold a charge. What's the best procedure to test them?
                                      NeverDieN gohanG 2 Replies Last reply
                                      • X xgarb
                                        #216
                                        @xgarb
                                        I wish there were standard tests that were widely used, but there don't seem to be. You might try holding it at its rated voltage for 72 hours, then remove power and check its voltage after 24 hours with no charging to get some idea as to what its leakage is. These tests only mean something if you compare them against a capacitor that you like though. Then maybe it will tell you whether it's better or worse.
                                        The only test that really matters is how it performs in your use-case.
                                        • X xgarb
                                          @xgarb I have them too, I tried and there is definitely leakage but it should not matter much as the sensor will not have to stay for days without charging
