Ethernet Gateway connection to Raspberry Pi
I'm new to this and have constructed an Ethernet Gateway with Arduino UNO and Nrf24+ and an Ethernet shield.. The sketch loads and the serial port shows no errors however it fails to get an IP address and then shows DHCP failure. I've tried a different cable, different Raspberry Pi, etc. but no matter what I get the same problem. I have tested the shield by loading the arduino printer sketch from the examples page and it works. It simply can't get an address via the Pi. I'm running Domoticz as the controller.
Any pointers gratefully appreciated.
David -
DavidWelcome to the MySensors community @urbanus!
How are the ethernet sield and the raspberry pi connected?
What other devices are on the network?
Do you have a router as dhcp server? Can other devices get an ip address from it?
Could you post the debug output from the gateway?
Did you #define MY_MAC_ADDRESS to the mac address printed on the ethernet module? -
Hi and thank you for the warm welcome and quick response.
The ethernet shield piggybacks on to the Arduino and connects to the Pi by a standard RJ45 cable.
Its my home wifi fed by a Virgin Superb. No sensors etc. connected on the network yet.
The router issues DHCP commands as if I connect the ethernet shield direct to my laptop and load an example sketch it is issued an IP address without issue.
Cannot seem to copy the debug code from the gateway serial output so I will have to type it in.
I set the mac address based on the output I got from the example sketch serial output.Many thanks
@urbanus hreat info, thanks! Seem you got the mac address right. It can be easily forgotten so I wanted to check :)
Just so I understand this right: when you load the example print sketch, the ethernet shield is connected to your laptop and gets an ip address?
What happens if you load the example print sketch and connect the ethernet shield to the raspberry pi?
What happens if you load the mysensor gateway sketch and connect the ethernet shield to your laptop?
When you connect the ethernet shield to the raspberry pi, do the leds for the link light up? -
- Correct
2)Good idea, haven't tried that! Will get onto that now.
3)Assuming you mean connect by ethernet, as above, will try that after 2) - Yes they do.
debug code is as below:
0;255;3;0;9;MC0:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
0;255;3;0;9;TSM:INIT
0;255;3;0;9;TSF:WUR:MS=0
0;255;3;0;9;TSM;INIT:TSP OK
0;255;3;0;9;TSM:INIT:GW MODE
0;255;3;0;9;MC0:REG:NOT NEEDED
DHCP FAILURE...0;255;3;0;9;!MC0:BGN:TSP FAIL - Correct
Sorry, not sure why my bullet numbers are wrong, they are correct on the reply section. I think you get which answer is for which point though.
thanks@urbanus I do, thanks!
My guess is that your laptop is configured to share the wireless network with its ethernet port, but the raspberry pi is not configured that way.EDIT: Does the "Virgin Superb" have ethernet ports? If so, can you connect the ethernet shield directly to the "Virgin Superb" and see if that works?
Hi. If I connect the gateway to my laptop by cable it picks up an IP address without issue (using the gateway sketch). I guess this points to the problem being at the PI end. I came to this conclusion last night (around midnight!!) and checked the /etc/interfaces on the pi but it seemed okay.
@mfalkvidd Yes, it does. Didn't realise I could do that. Will try that as soon as Question Time finishes (I know thats sad but what can I say...)
Will also search for the raspberry pi configuration you pointed to - thanks a lot. I learn a great deal from forums but sometimes you just need a second pair of eyes to point you in the right direction -
Will also search for the raspberry pi configuration you pointed to - thanks a lot. I learn a great deal from forums but sometimes you just need a second pair of eyes to point you in the right direction@urbanus have you considered wiring the nrf24 directly to the gpio ports on your raspberry pi (instructions: https://www.mysensors.org/build/raspberry ) ?
That would eliminate the need for the ethernet shield and you can use your Uno for other stuff. -
Hi. I did originally do that but thought I had misunderstood the instructions as my understanding is that I need a host for the control software (the pi) and a separate gateway (arduino) to relay info from the nodes so I stopped and constructed the ethernet gateway
I'm seriously thinking of taking up knitting! This is driving me bananas.
So, as I'm unable to get the ethernet gateway working I thought I would follow the advise given and connect the radio direct to the pi and set it as a serial gateway following the instruction on this site.
Software installs okay. Using a RPi 2 and a NRF24+. Connections triple checked and as per the drawing.
When I run the sudo ./bin/mysgw -d command to test the link I get:mysgw: Starting gateway...
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: !TSM:INIT:TSP FAIL
mysgw: TSM:FAIL:CNT=1
mysgw: TSM:FAIL:PDTI have checked the radio using the UNO/Ethernet shield as above and it works but no matter what I do on the pi I cannot get past the above error.
Help or directions to a nearby wool shop please!
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
Hi, Thanks in advance for the help.
This is what I get from asmod on the pi:
Module Size Used by
8192cu 582217 0
cfg80211 543027 1 8192cu
rfkill 20851 2 cfg80211
evdev 12423 1
joydev 9988 0
spidev 7373 0
snd_bcm2835 24427 0
snd_pcm 98501 1 snd_bcm2835
snd_timer 23904 1 snd_pcm
snd 70032 3 snd_timer,snd_bcm2835,snd_pcm
spi_bcm2835 7596 0
bcm2835_gpiomem 3940 0
uio_pdrv_genirq 3923 0
rpi_ft5406 4783 0
uio 10204 1 uio_pdrv_genirq
rpi_backlight 2632 0
fixed 3285 0
i2c_dev 6913 0
fuse 99603 1
ipv6 406751 30attached are two photos. One shows the arduino with ethernet and NRF and the other shows the RPi with the NRF. I have several NRF units, both types- and they all show on the Arduino running the given sketch so I know the radio modules are ok. I have a slightly different capacitor on the 2 units shown but I have tried with the same cap and the result is the same.
I should point out that grey has been used instead of orange on the RPi connection - I ran out of Dupont leads!
I used
./configure --my-transport=nrf24
and./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
The Uno is working fine but I can't get the ethernet connection to the pi to work on that, hence why I took the advise to use the pi as both gateway and controller. It does work as a good testbed for the radio modules though! -
I used
The Uno is working fine but I can't get the ethernet connection to the pi to work on that, hence why I took the advise to use the pi as both gateway and controller. It does work as a good testbed for the radio modules though!@urbanus only the last configure command will be considered, so the first command will be completely ignored.
That doesn't matter in this case though, since nrf24 is the default transport.
I'm out of ideas. It is time to go to http://www.ebay.com/itm/New-Knitting-Tools-Kit-Crochet-Needle-Hook-Accessories-Supplies-With-Case-/291870313249
