  3. [SOLVED] SensebenderMicro restarts/crashes triggered by D3
5 Posts 2 Posters 1.5k Views 2 Watching
  • t3chieT Offline
    t3chieT Offline
    t3chie
    I have a weird problem with a sensebender micro.
    Loaded the standard sensebender sketch and all works fine.
    Then I added a switch between 3.3V and D3 and initialized this with:
    setup()
    pinMode(MOTION_PIN, INPUT);
    digitalWrite(MOTION_PIN, HIGH);
    Now comes the weird part:
    Whenever I press the D3 button, the sketch restarts. No matter if I sleep with interrupt or without etc.
    If the serial console is NOT attached, it looks like the sketch continue to run.
    I would assume some power issue, but for this test the board is powered over the USB-serial converter with 3.3V and everything else is working with or without opening the serial monitor in the Arduino Application.
    Any idea what I am doing wrong?
    According to this thread (https://forum.mysensors.org/topic/1573/my-generic-room-senser-sensebender-with-motion-and-light) I have tried to put a 25k resistor between D3 and ground, but without difference.
    Y 1 Reply Last reply
    • t3chieT t3chie
      setup()
      Y Offline
      Y Offline
      @t3chie Shot in the dark, but you're not accidently shorting Vcc and Gnd by pressing the switch?
      t3chieT 1 Reply Last reply
      • Y Yveaux
        t3chieT Offline
        t3chieT Offline
        t3chie
        @Yveaux Thanks for that - I checked my cabling again and discovered a "hairline connection" between D3 and DTR. It is working better now.
        • t3chieT t3chie
          Y Offline
          Y Offline
          @t3chie said in SensebenderMicro restarts/crashes triggered by D3:
          You mean the issue has been solved?
          • Y Yveaux
            t3chieT Offline
            t3chieT Offline
            t3chie
            @Yveaux Yes, it works now.
            12.2k
