  3. [SOLVED] Too frequent updates form DHT
14 Posts 2 Posters 2.8k Views 2 Watching
  • archiijsA Offline
    archiijsA Offline
    archiijs
    Hi.
    I just managed to convert one of my ESP nodes to mysensors, but I got some interesting problems- Temp sensor sends updates very quickly, in my controllers I can see temperature changing back and forth all the time.
    Here is my sketch. It is combination from humidity sensor example from Mysensors examples and relays with switches from Openhardware.io
    My code (you probably will notice right away that I'm no good with this, so any advice is appreciated)
    #include <ArduinoOTA.h>
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "Paltes"
    #define MY_ESP8266_PASSWORD "virus.exe"
    #define MY_IP_ADDRESS 192,168,1,53
    #define MY_PORT 5003
    #define MY_GATEWAY_MAX_CLIENTS 3
    #if defined(MY_USE_UDP)
    #include <WiFiUDP.h>
    #include <ESP8266WiFi.h>
    #define MY_NODE_ID                  3
    #define MY_TRANSPORT_WAIT_READY_MS  200
    #define RELAY_PIN1    D1  // Arduino Digital I/O pin number for relay K1
    #define RELAY_PIN2    D2  // Arduino Digital I/O pin number for relay K2
    //#define RELAY_PIN3   // Arduino Digital I/O pin number for relay K3
    #define BUTTON_PIN1   D3  // Arduino Digital I/O pin for temp sensor
    #define BUTTON_PIN2   D5  // Arduino Digital I/O pin number for button relay K3
    //#define BUTTON_PIN3   // Arduino Digital I/O pin for PIR
    #define DHT_PIN       D4
    #define CHILD_ID1     5   // Id of the sensor child
    #define CHILD_ID2     6   // Id of the sensor child
    //#define CHILD_ID3   3   // Id of the sensor child
    #define CHILD_ID_TEMP 7
    #define CHILD_ID_HUM  8
    #define RELAY_ON      1
    #define RELAY_OFF     0
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    static const uint8_t FORCE_UPDATE_N_READS = 100;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    boolean metric = true;
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    //Bounce debouncer3 = Bounce();
    int oldValue1 = 0;
    int oldValue2 = 0;
    //int oldValue3 = 0;
    int state;
    bool initial_state_sent;
    MyMessage msg1(CHILD_ID1, V_STATUS);
    MyMessage msg2(CHILD_ID2, V_STATUS);
    //MyMessage msg3(CHILD_ID3, V_STATUS);
    DHT dht;
    void changeState(int chiled, int newState) {
      //state = newState;
      //digitalWrite(pin, newState);
      saveState(chiled, newState);
      switch(chiled){
        case CHILD_ID1:
          digitalWrite(RELAY_PIN1, newState);
          send(msg1.set(newState));
        case CHILD_ID2:
          digitalWrite(RELAY_PIN2, newState);
          send(msg2.set(newState));
          break; /*
        case CHILD_ID3:
          digitalWrite(RELAY_PIN3, newState);
          send(msg3.set(newState));
          break;*/
        default:
    void before() {
      // Setup the button
      pinMode(BUTTON_PIN1, INPUT_PULLUP);
      pinMode(BUTTON_PIN2, INPUT_PULLUP);
      //pinMode(BUTTON_PIN3, INPUT_PULLUP);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN1, HIGH);
      digitalWrite(BUTTON_PIN2, HIGH);
      //digitalWrite(BUTTON_PIN3, HIGH);
      debouncer1.attach(BUTTON_PIN1);
      debouncer1.interval(5);
      debouncer2.attach(BUTTON_PIN2);
      debouncer2.interval(5);
      //debouncer3.attach(BUTTON_PIN3);
      //debouncer3.interval(5);
      digitalWrite(RELAY_PIN1, RELAY_OFF);
      pinMode(RELAY_PIN1, OUTPUT);
      digitalWrite(RELAY_PIN2, RELAY_OFF);
      pinMode(RELAY_PIN2, OUTPUT);
      //digitalWrite(RELAY_PIN3, RELAY_OFF);
      //pinMode(RELAY_PIN3, OUTPUT);
      // digitalWrite(LED_PIN, RELAY_OFF);
      // // Then set relay pins in output mode
      // pinMode(LED_PIN, OUTPUT);
    void setup()  {
      ArduinoOTA.onStart([]() {
        Serial.println("ArduinoOTA start");
      ArduinoOTA.onEnd([]() {
        Serial.println("\nArduinoOTA end");
      ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
        Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
      ArduinoOTA.onError([](ota_error_t error) {
        Serial.printf("Error[%u]: ", error);
        if (error == OTA_AUTH_ERROR) {
          Serial.println("Auth Failed");
        } else if (error == OTA_BEGIN_ERROR) {
          Serial.println("Begin Failed");
        } else if (error == OTA_CONNECT_ERROR) {
          Serial.println("Connect Failed");
        } else if (error == OTA_RECEIVE_ERROR) {
          Serial.println("Receive Failed");
        } else if (error == OTA_END_ERROR) {
          Serial.println("End Failed");
      ArduinoOTA.begin();
      Serial.println("Ready");
      Serial.print("IP address: ");
      Serial.println(WiFi.localIP());
      dht.setup(DHT_PIN);
      int newState = loadState(CHILD_ID1);
      if (newState == 0Xff) {//if eeprom is empty
        newState = RELAY_OFF;
      changeState(CHILD_ID1, newState);
      newState = loadState(CHILD_ID2);
      changeState(CHILD_ID2, newState);
      //newState = loadState(CHILD_ID3);
      //if (newState == 0Xff) {//if eeprom is empty
      //  newState = RELAY_OFF;
      //changeState(CHILD_ID3, newState);
    void presentation()  {
      sendSketchInfo("Koridors", "2.0");
      present(CHILD_ID1, S_BINARY);
      present(CHILD_ID2, S_BINARY);
      //present(CHILD_ID3, S_BINARY);
      present(CHILD_ID_HUM, S_HUM);
      ArduinoOTA.handle();
      if (!initial_state_sent) {
        Serial.println("Sending initial value");
        send(msg1.set(loadState(CHILD_ID1) ? true : false));
        send(msg2.set(loadState(CHILD_ID2) ? true : false));
        //send(msg3.set(loadState(CHILD_ID3) ? true : false));
        initial_state_sent = true;
      debouncer1.update();
      // Get the update value
      int value = debouncer1.read();
      if (value != oldValue1 && value==0) {
    	  //toggle switch state
    	  changeState(CHILD_ID1, loadState(CHILD_ID1) ? RELAY_OFF : RELAY_ON);
          //digitalWrite(RELAY_PIN, state ? RELAY_OFF : RELAY_ON);
          //send(msg.set(state?false:true)); // Send new state and request ack back
      oldValue1 = value;
      debouncer2.update();
      value = debouncer2.read();
      if (value != oldValue2 && value==0) {
    	  changeState(CHILD_ID2, loadState(CHILD_ID2) ? RELAY_OFF : RELAY_ON);
      oldValue2 = value;
      debouncer3.update();
      value = debouncer3.read();
      if (value != oldValue3 && value==0) {
    	  changeState(CHILD_ID3, loadState(CHILD_ID3) ? RELAY_OFF : RELAY_ON);
        //state = loadState(CHILD_ID3);
        //digitalWrite(RELAY_PIN3, state ? RELAY_OFF : RELAY_ON);
      oldValue3 = value; */
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
      }   else {
        nNoUpdatesHum++;
        sleep(UPDATE_INTERVAL);
      if (message.isAck()) {
    #ifdef MY_DEBUG
    #ifdef MY_DEBUG
        // chnage the state of the related sensor
        changeState(message.sensor, message.getBool() ? RELAY_ON : RELAY_OFF);
    Here is a link to galery with some screensoots and videos thats kind of describe problem Google photos, hope you can see galery
    • archiijsA archiijs
      Hi.
      #define DHT_PIN       D4
      #define RELAY_ON      1
      #define RELAY_OFF     0
      float lastTemp;
      float lastHum;
      int oldValue1 = 0;
      int oldValue2 = 0;
      int state;
      DHT dht;
        //state = newState;
        switch(chiled){
          case CHILD_ID1:
          case CHILD_ID2:
            break; /*
          case CHILD_ID3:
            break;*/
          default:
      void before() {
        // Setup the button
      void setup()  {
        ArduinoOTA.begin();
        dht.setup(DHT_PIN);
        oldValue1 = value;
        oldValue2 = value;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
        }   else {
          nNoUpdatesHum++;
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
      @archiijs if you look at the debug output of the node (which should always be the first step when troubleshooting) you'll probably see that the node does not sleep.
      That happens because sleep is not supported on esp8266. Try using wait instead.
      • archiijsA Offline
        archiijsA Offline
        archiijs
        @mfalkvidd said in Too frequent updates form DHT:
        Hi, and thanks for the response.
        Well, I'm not really interested in sleep, all my nodes are AC powered. Can you guide me to some example using wait, thanks in advance.
          @archiijs just replace the letters sleep with wait in your code.
          • archiijsA Offline
            archiijsA Offline
            archiijs
            wait
            That was easier than expected, thanks for your advice, seems to do the trick. Will apply this to all my nodes now and test.
            Thanks for your fast replays.
              wait
              @archiijs great! Thanks for reporting back.
              • archiijsA Offline
                archiijsA Offline
                archiijs
                wrote on last edited by archiijs
                @mfalkvidd
                Hi again.
                I got small problem that emerged after this change. When I try to use my wall switches nothing happens, I still can turn on/off all lights from controller without problems, only localy attached switches do not work and that is not an option.
                so the problem lies in this line, if I understand correctly
                if I change sleep to wait, so I'm back to the beginning now. Is there any way to fix this?
                  @mfalkvidd
                  Hi again.
                  @archiijs I would remove the wait/sleep and change
                  to
                  else if (temperature != lastTemp)
                  That will cause the temperature to be sent whenever it has changed.
                  There are several other ways to get a similar result. What is best depends on how you want the node to behave.
                  • archiijsA Offline
                    archiijsA Offline
                    archiijs
                    @mfalkvidd Thanks again for your response.
                    I just changed else if functions as you suggested and uncommented wait/sleep(update_interval);
                    Actually, I think that I had code like this couple days before...
                    The result is kind of what is needed, I get new values as they change, BUT they change all the time. Like my temperature just changes true 21.7 to 21.6 to 21.7 to 21.8 an ower and ower again nonstop, same with humidity.
                    EDIT: Just switched out DHT sensor for anorther and nothing has changed.
                      @archiijs you either need to add som hysteresis (only send update if the temperature has changed with X amount, for example 1 degree) or a time limit (never send updates unless X time has passed since last send, for example 5 minutes)
                      • archiijsA Offline
                        archiijsA Offline
                        archiijs
                        @mfalkvidd That sounds about right. But sadly I can not find any examples of such sensors and I'm not sure if I could figure this out by myself :/
                          Hysteresis: https://forum.mysensors.org/post/66870
                          Timer: https://forum.mysensors.org/post/70243
                          • archiijsA Offline
                            archiijsA Offline
                            archiijs
                            @mfalkvidd Superb, I will study your suggestions and report back. Thanks again for your patience with me.
                            • archiijsA Offline
                              archiijsA Offline
                              archiijs
                              Hi @mfalkvidd and others.
                              Yesterday after work I tried to get my head around code suggestions but somehow I cold not make them work so I did some google search and after some time I find something that I implemented in my nodes for testing.
                              Interestingly it works as expected for two of my nodes, but one still keeps jumping around, not that often, but that's still strange, I will compare code to other two to see what I've done wrong there.
                              So I used Hysteresis approach by doing this.
                              #define HYSTERISIS    0.5        // Hysteresis for sensor
                                } else if (abs(temperature - lastTemp ) > HYSTERISIS) {
                                  if (!metric) {
                              And the same for humidity.
                              Still not sure that this will work as expected in long run, but will see.
                              But now it is way better than before. Thanks.
                              11.8k
                              113.2k
