  3. Air Humidity Sensor with DHT22 - Temp much to high (72°C)
dht22 temp
8 Posts 3 Posters 3.6k Views 3 Watching
  • M Offline
    M Offline
    marco4711
    i'm try to build a Air Humidity Sensor with a Arduino Nano and a DHT22. But the temp is much to high.
    With this Example-Sketch the temp is to high.
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    //#define MY_RS485
    #include "DHT.h"
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    But with this small Test-Sketch the temp is OK.
    #include "DHT.h"
    DHT dht;
      Serial.begin(9600);
      dht.setup(3); // data pin 2
      Serial.print(dht.getHumidity());
      Serial.print("\t");
      Serial.print(dht.getTemperature());
    I don't know the mistake.
    Thank for your Help
    • M marco4711
      //#define MY_RS485
      #include "DHT.h"
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      #include "DHT.h"
      DHT dht;
        Serial.begin(9600);
        Serial.print("\t");
      Thank for your Help
      @marco4711 which numbers do you get?
      One difference I noticed is that your MySensors sketch uses sleep, while the test sketch keeps the mcu running. Maybe try to use wait instead of sleep to see if there is a difference?
      • M Offline
        M Offline
        marco4711
        wrote on last edited by marco4711
        @mfalkvidd do you mean the temp-value?
        MySensors Sketch 75.02°C
        Test-Sketch 23.80°C
        with wait instead of sleep no difference still 75.02°C
        • M marco4711
          Test-Sketch 23.80°C
          23.80 C is 74.84 F so my guess is that you are getting Fahrenheit somehow. Maybe your controller is set to non-metric?
          • D Offline
            Could this be an issue with getControllerConfig not working properly. Try hard coding your metric variable to true and see if it works. If it does, start looking into whether your controller is sending the correct value for getControllerConfig.
            • M Offline
              M Offline
              marco4711
              Sorry for the delay. I have hardcode the sensor for metric and everything is fine.
              Where can i find the option to set the Gateway to metric?
              D 1 Reply Last reply
              • M marco4711
                @marco4711 It is not the gateway that you set. It is an option in whatever controller you are using. On my Vera it is a setting in the MySensors plugin, and in Domoticz go to Setup > Settings and click on the Meters/Counters tab. The controller is supposed to send out the metric setting when this line is called:
                • M Offline
                  M Offline
                  marco4711
                  I'am using IoBroker. i will ask in the iobroker-Forum.
                  12.2k
