  3. TMT6000
TMT6000
6 Posts 2 Posters 1.9k Views 1 Watching
    stress nero
    @stress-nero said in TEMT6000:
    Hello first time user here, I have been trying to build a 4in1 light, motion, tem/hum using a nano, temt6000, dht22, and sr501 using the examples and already made sketches i can combine everything, but i am not sure if i am entering the info for the temt6000 correctly. Can someone take a look please```
    Insert Code Here
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOTION 2
    #define CHILD_ID_LIGHT 3
    int lastLightLevel;
    #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = false;
    unsigned long interval= 3000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
    unsigned long previousMillis=0; // millis() returns an unsigned long.
    MyMessage msgMot(CHILD_ID_MOTION, V_TRIPPED);
    uint16_t lastlux;
     // metric = getConfig().isMetric;
      sendSketchInfo("4-1 Sensor", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_MOTION, V_TRIPPED);
      // Read digital motion value
    // only run loop if time has passed.
    unsigned long currentMillis = millis(); // grab current time
     // check if "interval" time has passed
     if ((unsigned long)(currentMillis - previousMillis) >= interval) {
           send(msgMot.set(tripped?"1":"0"));
          #ifdef MY_DEBUG
           Serial.print("Motion: ");
           Serial.println(tripped);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        #ifdef MY_DEBUG
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
     // Read lux from TEMT6000
      float lightLevel = analogRead(LIGHT_SENSOR_ANALOG_PIN) *  9.;  // 1000/1024
      if (int(lightLevel - lastLightLevel) > 10 || int(lastLightLevel - lightLevel) > 10) {
          send(msg.setSensor(CHILD_ID_LIGHT).set(lightLevel,1));
          lastLightLevel = lightLevel;
       // save the "current" time
       previousMillis = millis();
      //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    0_1499978821740_upload-a3bebffe-d25d-49db-8ffb-1a043392c708
    sorry for the double post.
    • S stress nero
      Insert Code Here
      int lastLightLevel;
      DHT dht;
      float lastTemp;
      float lastHum;
      uint16_t lastlux;
            #ifdef MY_DEBUG
          if (!metric) {
          #ifdef MY_DEBUG
            lastHum = humidity;
            #ifdef MY_DEBUG
      @stress-nero what is the purpose of the double post? Which one should I delete?
      S 1 Reply Last reply
        stress nero
        @mfalkvidd the one in development when i posted i did not realize that it was under development, and can you help me sorting the tmt6000 sersor out for the sketch.
        • S stress nero
          @stress-nero sorry I don't even know what a tmt6000 is.
            stress nero
            @mfalkvidd it's a ambient light sensor. I was going to use a esp8266 with these to make a 5in1 node inspired by a video i saw with just header wires , but decided to use arduino nano instead. What i posted seems to work ok but being brand new i figure i would let someone else take a look and see if everything was ok with what i have so far or if i could make it better.
            https://www.sparkfun.com/products/8348
            • S stress nero
              stress nero
              @stress-nero the light values was fixed bad jump wire position,
              ![alt text](0_1500037741362_upload-bc52de37-cdbc-47f8-aed4-288746977651 image url)
