  3. Mi-Light controller for Mysensors
69 Posts 15 Posters 52.7k Views 27 Watching
  • n1ck1355N
    n1ck1355N
    n1ck1355
    @Nca78 :
    did you have success with thw NRF boards connecting?
    Nca78N 1 Reply Last reply
    • n1ck1355N n1ck1355
      @Nca78 :
      @n1ck1355 said:
      @Nca78 :
      Hello, unfortunately I had no time to test it, I was busy with my Livolo switch :P
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        I just tried out openhab2, would it be easier controling the bulbs from openhab2 or do I still to do alot of "coding" on my own?
        • Nca78N
          wrote on last edited by Nca78
          #59
          Hello, few months have passed and I finally had a look at the code from @Jason-Brunk
          I made a MiLightBulb class with methods to set on/off, set brightness level, set color and set animation. It still needs improvements as brightness is not working, some colors are a bit off and I didn't test animation yet but it's starting to take shape and I can use it from RGB light control in domoticz.
          I have connected 2 nrf24 also, using pins 7&8 for the one sending MiLight messages instead of 9&10 and it running fine as expected, no use to call begin() all the time: much more reactive.
          I'll publish the code as soon as I have time to finish and clean up.
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            Great news @Nca78
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              any updates? I have a couple milight bulbs ready to test :)
              Home Automation Tinkerer
              www.CrankyCoder.net
              Gateway: MQTTClientGateway
              MySensors: 2.3
              • CrankyCoderC CrankyCoder
                @Jason-Brunk sorry I received my PCBs for Livolo switches so these will have my priority at the moment. And we're still in the lunar new year holidays here, not much time available.
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  Totally understand. That's another project I am interested in :)
                  www.CrankyCoder.net
                  MySensors: 2.3
                  • lozzer65L
                    lozzer65L
                    lozzer65
                    Hi
                    I have read through this thread fully and the concept look great. I am confused as to the hardware that is required thought. I have a mysensors gateway connetcted to wifi and some sensors setup and working on Home Assistant. What do I need to build to implement this solution, and what would I have to install in HA.
                    Thanks for any help
                    Laurie
                    • D
                      Dlay
                      is this thread still alive ?
                      I am on a Raspberry Pi 3 an i have connected an nrf radio.
                      PiGateway or PiGatewaySerial are both working and also openmilight_pi is compiled and ready.
                      My Problem is:
                      In the first post its said to send multiple On commands to the milight to pair it.
                      This shall work even without the original remote controller.
                      But how ?
                      How to use the Gateway or openmilight to send a general on command ?
                      I cannot see it from the hackaday page. Everywhere the ID is needed. Which i dont have when using only Pi, nRF and a milight rgb box to controll a strip.
                      Please can someone light me up ???
                      alexsh1A 1 Reply Last reply
                      • D Dlay
                        My Problem is:
                        But how ?
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Dlay I think there has been little activity on this thread. I had some issues too and I ended up buying Wifi module to control LED strip. It is natively supported by Domoticz so it works fine for me.
                        • Nca78N
                          Hello, I'm testing my MiLight shield for NModule, and so far it's working well, so I'll post some code soon.
                          Even without the NModule and MiLight controller shield it will be possible to use the same wiring to build one.
                          • OliverDogO
                            OliverDogO
                            OliverDog
                            Hi.
                            is this thread still alive?
                            Can I use this to solve my problem?
                            This is the problem:
                            • I want to control my pool lights (controlled by RGB-FUT037 from milight - 2.4ghz) using the original Mi-Light Wall Panel Controller T3 - which sends 2.4ghz... but both are in different floors. Fut037 is inside que pool's machine house and the Wall Panel is on Gourmet's Balcony.
                            What I need:
                            • An arduino node receives the code from Wall Panel using maybe a NRF24L01 module, then send to another arduino node through wifi (NodeMCU / ESP8266), which finally, reproduces the code using another NRF24L01, reaching the FUT037.
                            rejoe2R 1 Reply Last reply
                            • OliverDogO OliverDog
                              Hi.
                              What I need:
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @OliverDog You may have a look at https://github.com/sidoh/esp8266_milight_hub. It uses basically the same hardware as a normal MySensors Wifi-GW and is able to receive and send (most) of the MiLight-Codes. I'm using the MQTT interface offered by the hub not only to translate MiLight-V5-protocol type of remote codes not only to control V4-protocol type of rgbw bulbs (which seems to be close to your request), but also to set shutter levels or even control my mpd... Obviously, this nees some additional coding on controller side (FHEM in my case).
