  3. 2 systems in same location
location
4 Posts 2 Posters 1.8k Views 1 Watching
  • C Offline
    C Offline
    C.r.a.z.y.
    If i want to use 2 or more systems in the same location; sensors will be mixed? How can i ban other system to see my already working sensor? (For vera gateway)
    • H Offline
      H Offline
      Select a different frequency (MyConfig.h) before compiling/uploading the new sensors/gateway.
      • C Offline
        C Offline
        C.r.a.z.y.
        Thank you Hek.
        #define RF24_CHANNEL 76 //RF channel for the sensor net, 0-127
        If i change** 76 to 77** it will be a different freq?
        #ifndef MyConfig_h
        #define MyConfig_h
        • Configure Sensor Network
          #define RF24_DATARATE RF24_250KBPS //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
          #define RF24_PA_LEVEL RF24_PA_MAX //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
          #define RF24_PA_LEVEL_GW RF24_PA_LOW //Gateway PA Level, defaults to Sensor net PA Level. Tune here if using an amplified nRF2401+ in your gateway.
          #define BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
        // MySensors online examples defaults
        #define DEFAULT_CE_PIN 9
        #define DEFAULT_CS_PIN 10
        • Enable/Disable debug logging
          #define DEBUG
        • H Offline
          H Offline
          yes
          12.2k
