  3. Mysensors with AT Tiny
6 Posts 3 Posters 2.0k Views 3 Watching
  • D Offline
    This question may have been asked before, but can MySensors work on an AT Tiny with an nRF24?
    • D dbemowsk
      @dbemowsk based on earlier threads it should be possible to make it work, but it will require quite a lot of effort and the options will be severely limited (no possibility for debug for example).
      https://forum.mysensors.org/post/68052
      https://forum.mysensors.org/topic/5043/attiny-13-controller
      https://forum.mysensors.org/topic/333/attiny-supported?page=1
      D 1 Reply Last reply
      • D Offline
        My thought was possibly for something like a door/window sensor where all you have is a single magnetic switch, or maybe a plant moisture sensor which is just a two wire probe sensor. Things where you would want the sensor small.
          @mfalkvidd Looking at the last link, I doubt I will even try. It was a thought of a way to make smaller simple sensors more than anything. Just brainstorming.
          I did some searching before I posted, but did not find those threads. Maybe because I was searching on "at tiny" and not "attiny". Thanks for the links though.
          d00616D 1 Reply Last reply
          • D dbemowsk
            d00616D Offline
            d00616D Offline
            d00616
            @dbemowsk said in Mysensors with AT Tiny:
            @scalz is on the way to create an really tiny sensor. The nRF5 is protocol compatible to nRF24, but have an really powerful CPU inside.
            https://forum.mysensors.org/topic/7167/nrf52-recessed-vibration-contact-sensor-for-door-window/1
            • d00616D d00616
              @d00616 Curious when these might be available for purchase. I like this idea.
