  3. NodeManager
  4. NodeManager Motion Sensor: how to use the SensorSwitch class?
17 Posts 5 Posters 6.6k Views 6 Watching
    @user2684 is the guy
    • U
      U
      user2684
      Sorry for the delay guys, for some reasons I haven't got the notification of this thread, thanks @gohan for pulling me in! When using SENSOR_MOTION, the default mode is already RISING. To help you reading through the code, the registerSensor() in NodeManager.cpp would create an instance of the SensorMotion class. SensorMotion is derived from SensorSwitch (which has CHANGE has default mode) but in its constructor (SensorMotion::SensorMotion) you will find a setMode(RISING) which is then the default value.
      Whatever parameter you want to change, this requires three steps:
      • registering the sensor
      • retrieving the instance of the class
      • invoking its functions
      SensorSwitch in your example above is a class, you need the instantiated object to invoke its member functions. So something like the following:
      // register the sensor and keep track of its id
      int sensorPIR = nodeManager.registerSensor(SENSOR_MOTION,3);
      // retrieve the instance of the object. Since getSensor() will return a generic Sensor class, you need to cast it accordingly
      SensorMotion* sensorMotion = (SensorMotion*)nodeManager.getSensor(sensorPIR_Id);
      // invoke whatever function you need. Since sensorMotion is a pointer, you need to use the -> notation
      sensorMotion->setMode(CHANGE);
      sensorMotion->setInitial(LOW);
      Does it make sense now?
      • I
        I
        iahim67
        Thank you very much sir, it start making sense to me, I still need to "digest" this :smile: as I am a HW engineer ... but trying to improve my SW skills.
        I am comfortable with the basics of C and Arduino but not really with object oriented programming.
        What literature would you suggest me to start with to understand this kind of coding? Java perhaps?
        gohanG 1 Reply Last reply
        • I iahim67
          @iahim67 c++? 😁
          • I
            I
            iahim67
            I thought you may say that :smile: ... is there a good C++ book for beginners that you would recommend?
            On paper I mean, that I can buy?
            TerrenceT 1 Reply Last reply
              I could sell you mine, it is still brand new but it is in Italian 😁
              • U
                U
                user2684
                Agree starting from c++ would make more sense :-) Just a silly personal advise: pay attention not to get lost into the tons of capabilities c++ can provide, especially if you want to be just focused on arduino to start with since you can easily get lost. Sometimes I personally prefer just an electronic one-pager with a good amount of examples :-)
                • I iahim67
                  TerrenceT
                  TerrenceT
                  Terrence
                  @iahim67 Simon Monk's Programming Arduino: Getting Started... book is pretty good.
                  Look at the table of contents.
                  https://www.amazon.com/Programming-Arduino-Getting-Started-Sketches/dp/1259641635/
                  • I
                    I
                    iahim67
                    Thanks for your help, I'll start with Simon Monk's Programming Arduino :smile: !
                    • JoeyGJ
                      JoeyGJ
                      JoeyG
