  3. Liion batteries
Liion batteries
19 Posts 6 Posters 12.2k Views 2 Watching
  • axillentA axillent
    @Dvbit to use CR2032 with promini you do not need a stepup, you can connect it directly to 3.3V pin
    also you can source directly nrf24L01
    CR2032 is lithium none rechargeable battery and its nominal voltage is about 3V
    any li-po are rechargeable and their fully charged voltage is about 4.2V
    you still can power promini directly but you will need an LDO to power nf24L01
    BSoftB
    BSoftB
    BSoft
    Could we avoid the LDO by using a pro mini digital/analog output set to High/duty cycle=100%? Maybe with a capacitor for ripple suppression!?
    Because i think the máx 40mA per output pin could be ok to power source the nRF24L01+.
    And whats the inconvenient if we want to use sleep modes?
    axillentA 1 Reply Last reply
    • BSoftB BSoft
      axillentA
      axillentA
      axillent
      @BSoft at you own risk you can do whatever you want))
      the risk is to lost NRF24L01 which will stop working after supplying a voltage above 3.6
      nobody knows how module will be working using PWM output with uncontrolled voltage
      I will recommend to use LDO, promini has LDO on board
      sense and drive
      BSoftB 1 Reply Last reply
        BSoftB
        BSoftB
        BSoft
        Thanks for the reply @axillent
        What i want is to minimize power consume removing LDO from equation (and neither adding a more efficient one).
        From my understand digital output or analog output (PWM) never gets above 3.3V for an ATMega328p 3.3V, please correct me if i'm wrong.
        I'm waiting for the material to run some tests.
        My real concern is if ATMega could maintain an output while at sleep, i doubt it.
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @BSoft , @axillent
          If you are powering with 3.3 volts or higher, It seems to me that you use the on-board voltage regulator on the 3.3V ProMini by simply wiring the power supply in to the RAW pin.
          This will give radio power at 3.3V, the problem is if your sensor(s) are 5V. Well, in that case it seems that you simply need to keep the input voltage at 5V+ but no higher than 12V.
          No?
          I am using the 3.3V ProMini exclusively on my wall-wort powered devices that require 5V in this fashion. I find it much easier than stepping down the voltage for the radio. So far, it is working brilliantly, however I wouldn't know the dynamics of how this would affect a battery power supply.
          I am (ignorantly) powering my MailBox sensor this way... FYI.
          • BSoftB BSoft
            axillentA
            axillentA
            axillent
            @BSoft PWM is a digital output, not analogue. You can transform it to analogue by applying filter but still it is a bad idea to use this instead of voltage regulator
            What is your goal? What do you plan to use as a power source?
            sense and drive
              BSoftB
              BSoftB
              BSoft
              @axillent I want to use a Lipo between 3.35 and 4.2V. For the atmega i could bypass the regulator, but nRF24L01 does not accept above 3.6V, so i have a problem.
              So i'm trying to use atmega output that gives me 3.3V.
              My primary goal is minor power consume avoiding all types of regulators.
                @BSoft , @axillent
                No?
                BSoftB
                BSoftB
                BSoft
                wrote on last edited by BSoft
                @BulldogLowell said:
                @BSoft , @axillent
                No?
                Yes, if you use the pro mini on-board regulator you have 3.3V to atmega and nRF24L01 but at the cost of regulator power consume. If i remind that regulator have an efficiency of 20 or 30%, it's pretty bad.
                And yes, you could at the same time use your battery to power 5V devices (bypassing regulator), but since it's unregulated you have to be careful with the drop voltage of your battery (check if that sensor could work between that voltage range).
                Yes, using on-board regulator permits battery voltage between 3.35V and 12V... if you bypass regulator, you could supply even lower voltage, but you will have a max frequency limitation.
                Please be careful with one thing you said, if a secondary sensor needs 5V you maybe could not connect a battery of 12V to it, you have to check that sensor datasheet.
                It is ok if you connect a 12V battery to pro mini RAW pin because there is a regulator on-board that allows you to do that, but could not be the case with a secondary board.
                • BSoftB BSoft
                  axillentA
                  axillentA
                  axillent
                  @BSoft OK, I see
                  Again and again I'm recommending you to use LDO for NRF24
                  There are modern LDO's who consume just a few uA
                  Alternatively you can use 2 x 1N4148 in serious, each will hold about 0.5-0.6V, this will save you NRF24
                  sense and drive
                    DvbitD
                    DvbitD
                    Dvbit
                    @axillent thanks a lot for your answer and patience with a newbie like me...
                    The Ldo is needed just with rechargeable cr2032?
                    • DvbitD Dvbit
                      axillentA
                      axillentA
                      axillent
                      @Dvbit YAW
                      CR2032 is not rechargeable and it's nominal voltage is 3V.
                      while you using CR2032 you do not need LDO
                      rechargeable version of CR2032 is called LIR2032. For LIR2032 you do need LDO
                      sense and drive
                      • DvbitD
                        DvbitD
                        Dvbit
                        Great. Tx
                        • DvbitD
                          DvbitD
                          Dvbit
                          Li like lithium ion in my post... Doh
                          • A
                            allanvbcrew
                            @axillent "There are modern LDO's who consume just a few uA"
                            Do you have any reference in mind?
                            • A allanvbcrew
                              axillentA
                              axillentA
                              axillent
                              @allanvbcrew will recommend XC6206P332MR
                              you will need just 2 x 1uF ceramic capacitors
                              it is stated that quiescent current is about 1uA
                              maximum input voltage is 6V
                              sense and drive
