  3. nRF5 action!
nRF5 action!
    #274
    Seems as though we're somewhat shooting in the dark, though, without a schematic of what Ebyte actually did on the module. For instance, I had assumed that all this (plus whatever else is needed) had already been implemented on the Ebyte module. Relative to the Nordic nRF52832 chip size, the Ebyte moduile is already a pretty big module!
      Mike_Lemo
      I'm tring to blink an led on a PCB I made not realy knowing how to program the IC before other than connection the SWD pins.
      I've followed the startup guide at github flashed the soft device probably successful using the ST link V2(while flashing the soft device it blinked the on board st link V2 led and at the end the blue led on my PCB stopped being on.)
      So I've got an RGB led connected to my PCB to pins:
      #define RGBL_RED_PIN P0.16
      #define RGBL_GREEN_PIN P0.15
      #define RGBL_BLUE_PIN P0.17
      now for a test to see if I got it right I want to blink each of them how would I do it?
      What is the arduino pin mapping?
        #276
        On the other hand, I suppose if Ebyte had already decoupled DEC1 and DEC2 with caps on their module, there'd be no point in exposing those pins. So, I guess by inference, they must not already be decoupled. Is that the idea?
        • M Mike_Lemo
          #277
          Isn't the arduino mapping generally handled by the boards.txt file? Which board that you're using are you telling the compiler that it is? i.e. which board under the board manager in the Arduino IDE are you selecting?
          M 2 Replies Last reply
            Mike_Lemo
            Actually never mind I got it just removed the P0. and put the number for example if I want to flash P0.16 I do 16 and it works!!
            Feels so good to understand that I can now finish my big project now all I have to figure out it how to use NFC and connect it to another NRF52832 device!
            Here's a demo:
            https://www.youtube.com/watch?v=hCMKsORq2sM&feature=youtu.be
              Mike_Lemo
              Oh yeah and forgot to mention I used the generic NRF52 settings.
              d00616D 1 Reply Last reply
                #280
                Aha! I just now noticed that on the silk screen for the actual module itself, it does indeed say DEC1, not DEC5, in what would otherwise be the DEC5 location. So, that settles it. "DEC5" really is DEC1, and "DEC5" is just a typo in the datasheet. :)
                  Mike_Lemo
                  you should follow this schematic design if you want to get this module working.
                  • M Mike_Lemo
                    d00616D
                    d00616D
                    d00616
                    The "generic" settings haven't a good pin assignment. Pins P0.00 and P0.01 are reserved for the 32KHz crystal and defined as TX/RX pins. That's an conflict.
                    • d00616D d00616
                      What should we use instead?
                      • d00616D
                        d00616D
                        d00616
                        @NeverDie The "Taida Century nRF52 minidev" has a lot of pins mapped out:
                        https://github.com/RIOT-OS/RIOT/wiki/Board%3A-nRF52-minidev you can select the programmer like your needs. The RedBear BLE Blend 2 has also a lot of pins mapped out, but the CMSIS-DAP is preselected.
                        • d00616D d00616
                          Mike_Lemo
                          @d00616 It says there NFC is not useable but what if my board is NFC hardware ready? how would I use that?
                          • d00616D
                            d00616D
                            d00616
                            It's simple. Use that. NFC isn't enabled or disabled by the board definition. Without SoftDevice, you have to enable the NFC functionality by flashing into the UICR.
                            You can define your own Board. Look into the "boards.txt" file and the "variants" folder in ~/.arduino15/packages/sandeepmistry/hardware/nRF5/0.3.0/ Most pins can be assigned to roles like SPI, I2C, UART.... Pins like NFC, RESET are fixed and analog Pins an be ordered like your needs.
                              Mike_Lemo
                              @NeverDie where can that boards.txt file of the NRF52 thing be found?
                              • d00616D d00616
                                Mike_Lemo
                                @d00616 I meant is there a library or something for that? how do I approach it I'm relatively new for this 3rd party arduino programming thing and I'ts necessary for me sins I already made a PCB for a micro controller I want to use.
                                • M Mike_Lemo
                                  On the Windows platform it's located in this directory: Program Files/Arduino/hardware/arduino/avr
                                    Mike_Lemo
                                    @NeverDie I can't see the Generic nrf52 board setting
                                      #291
                                      I added the two caps that Scalz suggested for DEC1 and DEC2, but I'm still getting the same error message as before when I try to program it using the DK. Unless someone has further ideas, I may have to wait two weeks for my breakout board to arrive before I do more, as right now I'm just deadbugging this by soldering wires directly to the module.
                                      • M Mike_Lemo
                                        #292
                                        That's all I know, so hopefully someone who knows more can chime in and offer you guidance.
                                          BTW, here's a picture of how the silkscreen looks and which shows DEC1 in the "DEC5" location:
