  3. nrf24L01+ 1715AH versus 1452AB problem
9 Posts 4 Posters 4.8k Views 4 Watching
  • H
    H
    Heizelmann
    wrote on last edited by Heizelmann
    I have two sets of nearly the same modules. The only visible difference is this number above. The modules with chip NRF M, 24L01, 1452AB work without problem. The modules with chip NRF M, 24L01, 1715AH did not. I tested 5 new modules from each series with the same node hardware and software.
    Here the protocol of the not working 1715AH:
    3 MCO:BGN:BFR
    BEFORE...
    5 TSM:INIT
    6 TSF:WUR:MS=0
    13 TSM:INIT:TSP OK
    15 TSM:INIT:STATID=50
    17 TSF:SID:OK,ID=50
    19 TSM:FPAR
    55 TSF:MSG:SEND,50-50-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2062 !TSM:FPAR:NO REPLY
    2064 TSM:FPAR
    2100 TSF:MSG:SEND,50-50-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4108 !TSM:FPAR:NO REPLY
    4110 TSM:FPAR
    4146 TSF:MSG:SEND,50-50-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6154 !TSM:FPAR:NO REPLY
    6156 TSM:FPAR
    6192 TSF:MSG:SEND,50-50-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8200 !TSM:FPAR:FAIL
    8201 TSM:FAIL:CNT=1
    8203 TSM:FAIL:PDT
    Hope someone can help. I saw a lot of topics concerning those modules on this forum but as a non-expert it is difficult to find the right answer.
    My non working module
      Usually it is most likely a bad Chinese clone. You can't do much about it, just get the genuine ones.
      • H
        H
        Heizelmann
        @gohan said in nrf24L01+ 1715AH versus 1452AB problem:
        But how can I be sure to get the genuine ones?
          There are a couple of open topics. Search for "genuine" and "counterfeit"
          • H
            H
            Heizelmann
            Thanks, but that is too much discussion for me. Can't someone simply answer with some links where to buy genuine modules for sure or where someone recently bought some which works?
            • H Heizelmann
              @Heizelmann no. That's why the discussions are so long.
                That is also a reason why I am moving to RFM69 as at the moment it looks there are no fake modules around.
                • D
                  division
                  I'm sorry to reply to an old thread, I just wanted to let people know I have been able to get these 1715AH chips working using one of the cheap regulator boards designed for using with the NRF24L01+ and the RF24 Library from TMRH20.
                  I ran into this thread and almost returned the modules disappointed, but I decided to give it a try anyway and they worked for me. It's one of the only hits on google when searching for the model number so hopefully this post helps others.
                  H 1 Reply Last reply
                  • D division
                    H
                    H
                    Heizelmann
                    @division can you please describe which concrete RF24 Library you took , which version of MySensors library you use, and how you integrate the RF24 library into MySensors?
                    12.5k
