  2. Announcements
  3. 💬 Building an Ethernet Gateway
133 Posts 42 Posters 102.5k Views 35 Watching
  • Toni RamosT
    Toni RamosT
    Toni Ramos
    hello @Ed1500, i have the same problem as @Mitja-Blazinsek. i have a w5100 module (funduino), arduino pro mini and nrf24 radio. i try to use your tip, including a delay in setup() but it doen't work yet, the gateway isn't reached using ping. is necesary another change? did you move the setup() function in the program? thanks!!
    E 1 Reply Last reply
    • Toni RamosT Toni Ramos
      E
      E
      Ed1500
      wrote on last edited by Ed1500
      #72
      @Toni-Ramos Sorry to hear that. Are you using Soft SPI or hardware SPI for both?
      Can you get any connection if you just use it as webserver without the NRF24?
      • Toni RamosT
        Toni RamosT
        Toni Ramos
        @Ed1500 i'm using softSPI as the example. I can see ping works correctly if i comment "#define MY_RADIO_NRF24". If not, the gateway shows the following messages continuosly:
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;TSM:FAIL:CNT=1
        0;255;3;0;9;TSM:FAIL:PDT
        0;255;3;0;9;TSM:FAIL:RE-INIT
        • Toni RamosT
          Toni RamosT
          Toni Ramos
          @Ed1500 after tests with different versions of the library i discovered a bad welded pin in the nrf24. It seens to work fine now,i'll conect a node to the gateway and check all
            E
            E
            Ed1500
            @Toni-Ramos Glad you got it solved. apologies I had not seen yr earlier reply yet, but thats no longer relevant.
            Always good to check the joints :-)
              What is the best way to make the gateway wait for ip address (it's set to use dhcp) when power goes down? I noticed that the gateway starts faster than the router and doesn't get the ip address so I had to push the reset button to get it to work.
                @gohan maybe add a wait call in before()? Not sure if before() is run early enough, but it might be worth a try.
                Maybe the library can be modified to try for a longer time before giving up.
                  Maybe I could make a check if there is no client connected I could reset the board, but I was wondering if there is any was to know if the system has a valid ip
                  • Mitja BlazinsekM
                    Mitja BlazinsekM
                    Mitja Blazinsek
                    hi after long time i finaly get new w5100 module now the test sketch from arduino ide for ethernet like web server are working fine bur still don't work as a gateway in domoticz or mycontroler. i just open example gatewayw5100 from my sensor libary and upload to mega bard bit status in my controler is always down af course i set the gateway in my controler :Enabled
                    Enabled
                    Type
                    Ethernet
                    Network type
                    MySensors
                    Connection details
                    Host:192.168.178.66, Port:5003
                    Status
                    Down
                    Status since
                    7 minutes ago
                    Status message
                    ERROR: connect timed out
                      Can you ping that ip? There are some faulty w5100 modules around and I did repair one by adding a couple of 100 ohms resistors on the ethernet pins.
                      • Mitja BlazinsekM Mitja Blazinsek
                        Enabled
                        Type
                        Ethernet
                        Network type
                        MySensors
                        Connection details
                        Status
                        Down
                        Status since
                        7 minutes ago
                        Status message
                        @Mitja-Blazinsek is your local network using the same subnet (192.168.178)? What is the ip and netmask of your controller?
                        • Mitja BlazinsekM
                          Mitja BlazinsekM
                          Mitja Blazinsek
                          my network is using 192.168.0 but i try to change the MY_IP_ADDRESS to 192.168.0.66 but still no responese. i dont know what is the ip of mycontroler it works only when ia write localhost:8443 i of domoticz was 127.0.0.1
                          • Mitja BlazinsekM
                            Mitja BlazinsekM
                            Mitja Blazinsek
                            ok ip of mycontroler is 192.168.0.100
                            • Mitja BlazinsekM
                              Mitja BlazinsekM
                              Mitja Blazinsek
                              is it maybe problem because i'm using mega board an i wired 50 51 52 pins but if i wired 11 12 13 like on the diagram here it not working the shield if i try dhcp address printer for test
                                You probably have faulty network shield
                                • jopebeJ
                                  jopebeJ
                                  jopebe
                                  wrote on last edited by gohan
                                  #86
                                  Sorry, but can't find any information about my problem about the gateaway.
                                  For connecting a lot of binary switches etc. i took a mega and loaded a gateaway sketch from Mihai . Normally it runs very good, when i change the status flags from ON/Off to 1/0 (Don't know why?)
                                  But now i had the idea, to disable the radio, because I don't need it for this mega.
                                  Now the relais-switches do no longer work as before. They only work from time to time and rather randomly.
                                  I want to switch and contol the switches with iOBroker, but without the radion connected and activated, it doesn't run.
                                  Any idea?
                                  • jopebeJ jopebe
                                    Any idea?
                                    #87
                                    @jopebe did you remove the define for the radio from your sketch?
                                    What does the debug output say?
                                    • jopebeJ
                                      jopebeJ
                                      jopebe
                                      Thank You for Your quick respons!
                                      Yes, i made two slashes before the define-line of the radio .
                                      I have no debug-output because I didnt engage myself in debugging until now. I will try it this evening. During the day Im engaged in other things.
                                      • jopebeJ
                                        jopebeJ
                                        jopebe
                                        Here thr output of the seriel monitor:
                                        0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
                                        IP: 192.168.178.134
                                        0;255;3;0;9;Eth: connect
                                        0;255;3;0;9;MCO:BGN:STP
                                        0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
                                        0;255;3;0;9;Eth: 0;101;1;0;2;1
                                        0;255;3;0;9;Eth: 0;101;1;0;2;0
                                        When I push the button in IoBroker-Vis, it takes often a lot of time until the LED is on; sometimes I have to push the button twice or more times; sometimes nothing happens at all.
                                        When I define and connect the radio with the same sketch, it runs as expected.
                                        korttomaK 1 Reply Last reply
                                        • jopebeJ jopebe
                                          IP: 192.168.178.134
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          #90
                                          @jopebe are the relays and switches locally attached to the GW? Please post your sketch
                                          • Tomas
