  2. Announcements
  3. 💬 Building an Ethernet Gateway
133 Posts 42 Posters 104.4k Views 35 Watching
    Maybe I could make a check if there is no client connected I could reset the board, but I was wondering if there is any was to know if the system has a valid ip
    • Mitja BlazinsekM
      Mitja BlazinsekM
      Mitja Blazinsek
      hi after long time i finaly get new w5100 module now the test sketch from arduino ide for ethernet like web server are working fine bur still don't work as a gateway in domoticz or mycontroler. i just open example gatewayw5100 from my sensor libary and upload to mega bard bit status in my controler is always down af course i set the gateway in my controler :Enabled
      Enabled
      Type
      Ethernet
      Network type
      MySensors
      Connection details
      Host:192.168.178.66, Port:5003
      Status
      Down
      Status since
      7 minutes ago
      Status message
      ERROR: connect timed out
        Can you ping that ip? There are some faulty w5100 modules around and I did repair one by adding a couple of 100 ohms resistors on the ethernet pins.
        • Mitja BlazinsekM Mitja Blazinsek
          Enabled
          Type
          Ethernet
          Network type
          MySensors
          Connection details
          Status
          Down
          Status since
          7 minutes ago
          Status message
          @Mitja-Blazinsek is your local network using the same subnet (192.168.178)? What is the ip and netmask of your controller?
          • Mitja BlazinsekM
            Mitja BlazinsekM
            Mitja Blazinsek
            my network is using 192.168.0 but i try to change the MY_IP_ADDRESS to 192.168.0.66 but still no responese. i dont know what is the ip of mycontroler it works only when ia write localhost:8443 i of domoticz was 127.0.0.1
            • Mitja BlazinsekM
              Mitja BlazinsekM
              Mitja Blazinsek
              ok ip of mycontroler is 192.168.0.100
              • Mitja BlazinsekM
                Mitja BlazinsekM
                Mitja Blazinsek
                is it maybe problem because i'm using mega board an i wired 50 51 52 pins but if i wired 11 12 13 like on the diagram here it not working the shield if i try dhcp address printer for test
                  You probably have faulty network shield
                  • jopebeJ
                    jopebeJ
                    jopebe
                    wrote on last edited by gohan
                    #86
                    Sorry, but can't find any information about my problem about the gateaway.
                    For connecting a lot of binary switches etc. i took a mega and loaded a gateaway sketch from Mihai . Normally it runs very good, when i change the status flags from ON/Off to 1/0 (Don't know why?)
                    But now i had the idea, to disable the radio, because I don't need it for this mega.
                    Now the relais-switches do no longer work as before. They only work from time to time and rather randomly.
                    I want to switch and contol the switches with iOBroker, but without the radion connected and activated, it doesn't run.
                    Any idea?
                    • jopebeJ jopebe
                      Any idea?
                      #87
                      @jopebe did you remove the define for the radio from your sketch?
                      What does the debug output say?
                      • jopebeJ
                        jopebeJ
                        jopebe
                        Thank You for Your quick respons!
                        Yes, i made two slashes before the define-line of the radio .
                        I have no debug-output because I didnt engage myself in debugging until now. I will try it this evening. During the day Im engaged in other things.
                        • jopebeJ
                          jopebeJ
                          jopebe
                          Here thr output of the seriel monitor:
                          0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
                          IP: 192.168.178.134
                          0;255;3;0;9;Eth: connect
                          0;255;3;0;9;MCO:BGN:STP
                          0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
                          0;255;3;0;9;Eth: 0;101;1;0;2;1
                          0;255;3;0;9;Eth: 0;101;1;0;2;0
                          When I push the button in IoBroker-Vis, it takes often a lot of time until the LED is on; sometimes I have to push the button twice or more times; sometimes nothing happens at all.
                          When I define and connect the radio with the same sketch, it runs as expected.
                          korttomaK 1 Reply Last reply
                          • jopebeJ jopebe
                            IP: 192.168.178.134
                            korttomaK
                            korttomaK
                            korttoma
                            #90
                            @jopebe are the relays and switches locally attached to the GW? Please post your sketch
                            • Tomas
                            • scalzS scalz
                              @gvorster
                              hello, i'm working on rfm69 (refactorization and adding features), which will support softspi and w5100, and uses a lot less memory. might be available soon.
                              E
                              E
                              Ed1500
                              @scalz A very late reply, but someone else might be helped with it.
                              Hardware SPI is working.
                              The onnly thing is that on W5100 shield it will work without any problem but with most 5100 modules you need a small modification fixing w5100 problems
                              • fifoF fifo
                                My WizNET (W5100) Ethernet module had to be connected to 5v pin on arduino as the 3.3v would only allow ping but not function properly.
                                E
                                E
                                Ed1500
                                @fifo Most W5100 modules have a 5-3.3V regulator so if you connect the Vcc to 3V3 the chip just doesnt get enough juice
                                • jopebeJ
                                  jopebeJ
                                  jopebe
                                  I dont know, how to send my sketch as a file. Copy and past doesnt run.
                                  I use an ethernet-shield and as I mentioned, when I connect and switch on the radio, everything is alrigth.
                                  • jopebeJ
                                    jopebeJ
                                    jopebe
                                    Thank You to all, who tried to help.
                                    I think, I found the solution:
                                    There was this line in the sketch: "const unsigned long tUpdate=60000; //update interval"
                                    When I changed the time to 6000, it runs as when as the radio was connected.
                                    So it was probably missing some kind of "interrupt", which usually comes from the radio , when it listens to the nodes or so?
                                    • N
                                      N
                                      Newzwaver
                                      hi everyone,
                                      has the pin setup changed? it looks like it has from the sketch. I used a0, a1 and a2 for the radio.
                                      • N Newzwaver
                                        hi everyone,
                                        @Newzwaver Which sketch do you mean? The build page is still using a0, a1, a2 for W5100.
                                        • N
                                          N
                                          Newzwaver
                                          Ok, I screwed up and downloaded the latest arduino software 1.8.3 and can't get my libraries to work correctly. I am trying to upgrade my sensors to 2.1.1 and rebuild my gateway using a new nano I put together. I am using the5100 connection with the radio wired to a0..... It the 1.8.3 not to be used for the overseas board?
