  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • magpernM magpern
    @alexsh1 Feels like this could be changed, so inclusion also would work for domoticz. A also have a z-wave module hooked up to domoticz and for the z-wave there is inclusion. Just have to find the right person for it :)
    Yes the signing. I have tried. I want everything on the mysensors network to use signing, I have enabled the MY_SIGNING_ATSHA204, all sensors have the same keys in the chip. Is it using the signing if I have done this? I will try and hook up a sensor without the correct keys and see what happens. Just have to solder it first.
    alexsh1A
    alexsh1A
    alexsh1
    #290
    @Magnus-Pernemark said in 💬 Sensebender Gateway:
    z-wave in Domoticz is based on OpenZWave and z-wave protocol does require inclusion / exclusion. MySensors are natively supported by Domoticz and personally I do not see why inclusion/exclusion should be there. If you want security, please use signing.
    • tbowmoT
      tbowmoT
      tbowmo
      @Magnus-Pernemark
      You can disable domoticz automatic inclusion of new devices on the mysensors network, somewhere in the settings..
      magpernM 1 Reply Last reply
      • tbowmoT tbowmo
        @Magnus-Pernemark
        magpernM
        magpernM
        magpern
        @tbowmo Ah, found a setting ""Accept new hardware/sensors" and a button for "allow for 5 minutes" that could be used as a global "include"-button
        @alexsh1 well, maybe, maybe not. Don't know if I agree about not having an inclusion. Almost every device you buy you have to "pair" with something. Anyway, for now disable "allow new hardware/sensors" will do.
        @Anticimex I will re-read everything and test stuff now when I have a GW and two nodes to play with.
        A quick question - Is it possible to have the gateway to allow soft signing for some nodes (those without a ATSHA) and hardware signing for those with and reject everything else?
        I found this sentence:
        It is legal to mix MySigningAtsha204 and MySigningAtsha204Soft backends in a network. They work together.
        The word backend is in plural, does it mean I need one GW with ATSHA and another with soft signing?
        AnticimexA 1 Reply Last reply
        • magpernM magpern
          AnticimexA
          AnticimexA
          Anticimex
          #293
          @Magnus-Pernemark it means literally what it says. You can mix nodes. They are fully compatible. You can have a gw with a atsha204a device using atsha backend communicating securely with a node using soft signing. Or have a node with atsha204a device and atsha backend communicate with a gw with soft signing. You could even have a node or gw with atsha204a device configured for soft signing (although that is a waste since you have hw backed support in that case which is more secure since the hmac key is readout protected). The ONLY compatibility requirement between ANY node or gw in a network is that they MUST share the same HMAC key. That's it.
          • AnticimexA Anticimex
            magpernM
            magpernM
            magpern
            wrote on last edited by magpern
            #294
            @Anticimex Thanks again. So, really, to have hardware and software at the same time exposes the hardware key in the nodes that have soft signing, since all nodes need same HMAC, regardless of HW or SW.
            I enabled MY_SIGNING_ATSHA204 and MY_SIGNING_REQUEST_SIGNATURES in the gateway
            What I understand, this should activate signing (https://www.mysensors.org/about/signing and the "How to use this" part)
            I then took a bender with the same ATSHA keys, but without "MY_SIGNING_ATSHA204". It showed up in MYSController and reported temp. I changed the key in ATSHA to something other then the GW, it still shows up and reports the temp. So, clearly there must be something else to change as well?
            I read this in the documentation: "If this [MY_SIGNING_REQUEST_SIGNATURES] is set in a gateway, it will NOT force all nodes to sign messages to it. It will only require signatures from nodes that in turn require signatures."
            I intemperate this as, the gateway will require signatures, if the node says so, but it will talk to nodes that don't require signing too.
            All sketches are the default example sketches, except for the setting of the MY_SIGNING...
            Maybe I am over-shooting the target? What I'm after is: my devices are mine alone and they should only report to me. My receiver (GW) should only listen to my devices and ignore the neighbor's devices. The neighbor should not be able to talk to my devices.
            AnticimexA alexsh1A 2 Replies Last reply
            • magpernM magpern
              AnticimexA
              AnticimexA
              Anticimex
              #295
              @Magnus-Pernemark if you are on master, yes, then a node has to require signing to make the GW require it. On development (beta) gw will require signatures from everyone if it is set to require signatures (unless a specific flag is set).
              Doxygen holds the the current documentation for master and development.
              • magpernM magpern
                alexsh1A
                alexsh1A
                alexsh1
                @Magnus-Pernemark I would suggest you move the signing discussion into a corresponding thread. Other people may benefit reading what you have gone through 😁
                  AnticimexA
                  AnticimexA
                  Anticimex
                  And yes, if you have nodes "exposed" you should make sure those are using atsha204a backed signing if you are afraid they might get physically abused.
                  • alexsh1A alexsh1
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @alexsh1 @Magnus-Pernemark indeed. There is a long running one here: https://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors/
                      magpernM
                      magpernM
                      magpern
                      @Anticimex @alexsh1 yes should be in other thread. It started with a gateway question and migrated to a signing question. This will be the last one here, since I give up now. I will focus on building a network, and secure it later.
                      I'm on development branch, so I guess I just need that "specific flag". Couldn't find it in the documentation. I have it set up as the document in doxygen says, and GW should reject unsigned messages or wrong signing, documentation says, but it doesn't... Even nodes that have a different key and MY_SIGNING_ATSHA204 set, talks to the GW and reports temp.
                      I'll wait until beta is released
                      alexsh1A AnticimexA 2 Replies Last reply
                      • magpernM magpern
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Magnus-Pernemark
                        This is very simple. On the dev version:
                        GW (assuming you have atsha204 or use soft signing?)
                        MY_SIGNING_ATSHA204
                        On a node (assuming you have hardware atsha204?):
                        MY_SIGNING_ATSHA204
                        This is it.
                        • magpernM magpern
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @Magnus-Pernemark why do you need the special flag? I just wrote that you only need that if you DON'T want your gw to require signatures from everyone. It works just like @alexsh1 wrote. And it will work like that on both bets and release after release so if you can't get it to work on beta now, it won't work on release later either.
                          I suggest you start posting some logs so I can see if you really have signing enabled and that all required handshaking takes place. But don't post it in this thread please.
                            magpernM
                            magpernM
                            magpern
                            @Anticimex @alexsh1 It's working now! In one of you replies (@Anticimex ), you misspelled the flag name, and I copy / pasted what you wrote. So all this time, signing was never activated. Now it is and gateway works as expected!
                            • magpernM magpern
                              AnticimexA
                              AnticimexA
                              Anticimex
                              #303
                              @Magnus-Pernemark oh, sorry about that. But I do hope the ones in the docs are correct. Good that it works now :+1:
                                2rDK
                                wrote on last edited by 2rDK
                                #304
                                This may be a beginner-misunderstanding, but i hope you can assist me.
                                I had to move one of my repeaters to improve the WAF of my sensor installation.
                                In this process i may have messed a bit too much with the routing as i think the nodes responds directly to the gateway, but the gateway answers through the repeater. The repeater is moved, and the signal does no longer reach the node, resulting in a head ache (FPAR fails).
                                I read the debug-section and I think i need to clear my eeprom to allow for a new routing to happen.
                                This proved more difficult than I had anticipated. below is my software stack/process:
                                • Downloaded Arduino 1.8.3 for non admin install
                                • Downloaded Mysensors Library v2.1.1 using Library manager
                                • Downloaded Arduino SAMD Boards (32-bits ARM cortex-M0+) version 1.6.11 using Boards manager
                                • Downloaded Mysensors SAMD Boards version 1.0.4 using Boards manager
                                I then rebooted my machine for good measure and uploaded the ClearEepromConfig-example to the gateway. No output in the serial monitor.
                                I then searched a bit on the forum and added:
                                    while (!Serial) {}
                                In the setup()-part. This enabled me to get some output from the gateway. Unfortunatly it only returns Started clearing. Please wait...
                                I then did some more digging, and apperantly i2c_eeprom_read_byte() fails. So i searched some more on the forum and found I2C eeprom write fix for SAMD. So i tried the above once again but this time with Mysensors Library v2.2.0-beta (dev branch) just to see if anything changed. It didnt.
                                What did i miss ?
                                • F
                                  F
                                  Fabien
                                  After weeks of tests, it doesn't work well with ethernet and RFM69HW. Every 2 days, I need to power off and on the gateway. Controller can't connect (OH2).
                                  for some reasons, serial doesn't work on my odroid C1 with openhabian.
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    Ever since lightning took out my original RFM69 W5100 GW I have been having trouble with the replacement GW I built so now I want to use my Sensebender GW for this instead. On the GW I have allso 4 buttons and 4 relays so my question to @Anticimex is:
                                    Witch pins on the MYSX connector do you recommend for the buttons and relays?
                                    I was thinkin:
                                    Buttons:
                                    MYSX_D1_DFM
                                    MYSX_D2_DTM
                                    MYSX_D3_INT
                                    MYSX_D4_INT
                                    Relays:
                                    MYSX_D5_PWM
                                    MYSX_D6_PWM
                                    MYSX_D9_A3
                                    MYSX_D10_A4
                                    Can I assign the pins like this in my sketch:
                                    const int relayPin[] = {MYSX_D5_PWM, MYSX_D6_PWM, MYSX_D9_A3, MYSX_D10_A4};       //  switch around pins to your desire
                                    const int buttonPin[] = {MYSX_D1_DFM, MYSX_D2_DTM, MYSX_D3_INT, MYSX_D4_INT};   //  switch around pins to your desire
                                    Here is the complete sketch, please comment if something can be improved:
                                     * Version 1.0 - Henrik EKblad
                                     * LED purposes:
                                    #define SN "EthGW/RFM69 Rele Button"
                                    #define SV "1.5"
                                    //#define MY_RADIO_NRF24
                                    //#define MY_RADIO_NRF5_ESB
                                    #define MY_RADIO_RFM69
                                    #define MY_IS_RFM69HW
                                    //#define MY_RADIO_RFM95
                                    #define MY_GATEWAY_W5100
                                    //#define MY_W5100_SPI_EN 4
                                    // radio on the same spi bus.
                                    #define MY_SOFTSPI
                                    #ifndef MY_RF24_CE_PIN
                                    #define MY_RF24_CE_PIN 5
                                    #ifndef MY_RF24_CS_PIN
                                    #define MY_RF24_CS_PIN 6
                                    // Enable UDP communication
                                    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                                    #define MY_IP_ADDRESS 192,168,1,100
                                    #define MY_PORT 5003
                                    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xED, 0xED
                                    // Enable inclusion mode
                                    // Set blinking period
                                    // Flash leds on rx/tx/err
                                    #if defined(MY_USE_UDP)
                                    #include <EthernetUdp.h>
                                    #include <Ethernet.h>
                                    #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                                    #define RELAY_OFF 1
                                    #define noRelays 4                     //2-4
                                    class Relay             // relay class, store all relevant data (equivalent to struct)
                                      public:
                                        int buttonPin;                   // physical pin number of button
                                        int relayPin;             // physical pin number of relay
                                        boolean relayState;               // relay status (also stored in EEPROM)
                                    Relay Relays[noRelays];
                                    Bounce debouncer[noRelays];
                                    MyMessage msg[noRelays];
                                      wait(100);
                                      for (int i = 0; i < noRelays; i++) {
                                        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                                        msg[i].type = V_LIGHT;
                                        wait(100);
                                        Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                                        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                        send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                                        wait(50);
                                        debouncer[i].interval(30);
                                        wait(50);
                                      sendSketchInfo(SN, SV);
                                      wait(100);
                                        present(i, S_LIGHT);                               // present sensor to gateway
                                      wait(100);
                                      for (byte i = 0; i < noRelays; i++) {
                                        if (debouncer[i].update()) {
                                          if ( value == LOW) {
                                            // save sensor state in EEPROM (location == sensor number)
                                            saveState( i, Relays[i].relayState );
                                      //wait(20);
                                      if (message.sender == 0) {
                                          if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                            digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                            saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                                      wait(20);
                                    • Tomas
                                    • korttomaK korttoma
                                      I was thinkin:
                                      Buttons:
                                      MYSX_D1_DFM
                                      MYSX_D2_DTM
                                      MYSX_D3_INT
                                      MYSX_D4_INT
                                      Relays:
                                      MYSX_D5_PWM
                                      MYSX_D6_PWM
                                      MYSX_D9_A3
                                      MYSX_D10_A4
                                       * LED purposes:
                                      #define SV "1.5"
                                      #define MY_SOFTSPI
                                      #define RELAY_OFF 1
                                        public:
                                        wait(100);
                                          wait(100);
                                          wait(50);
                                          wait(50);
                                        wait(100);
                                        wait(100);
                                        //wait(20);
                                        wait(20);
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @korttoma you can use any pin that can provide the type of functionality you need (for example, don't expect that using an analog pin for digital data to work). Just keep in mind that by using certain pins, you might have to give up features you might like to use later on (like in this case you take the dfm and dtm pins, so you have "taken" the UART pins if you ever plan to use that for your board).
                                      As for the definitions, I am not sure. @tbowmo made the mappings for that port. I believe it looks good.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @korttoma
                                        Like @anticimex said, you will loose possibility of using the serial port if you use the dtm/dfm lines.
                                        But besides that, you are free to use all the ports as digital input/output, except the i2c pins as we have an i2c eeprom that is connected to the same pins.
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          Thanks @Anticimex and @tbowmo I have the GW up and running with one external sensor now. I just need to connect the buttons and relays to test those.
                                          I'm not sure if I will ever need the UART pins but I will make the hardware so that I can easily change the pins used for buttons and relays.
                                          btw, what is the use cases for UART pins?
                                          • Tomas
