  3. Sesnsor Door and Relay
3 Posts 3 Posters 1.4k Views 3 Watching
  • A
    arduino_89_89
    Hi I combined the sketch of a door sensor to adapt it to a photoresist and added a relay. The relay in question only works once and then freezes everything.
    #define MY_NODE_ID 2
    #define MY_PARENT_NODE_ID 0
    #define MY_RF24_CHANNEL 1
    //#define MY_REPEATER_FEATURE
    #define RELAY_3 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    #define CHILD_ID_2 1
    #define BUTTON_PIN_2 2 // Arduino Digital I/O pin for button/reed switch
    MyMessage msg1(CHILD_ID_2, V_LIGHT_LEVEL);
    void before()
    for (int sensor=1, pin=RELAY_3; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
    pinMode(pin, OUTPUT);
    pinMode(BUTTON_PIN_2, INPUT);
    sendSketchInfo("Relay", "1.0");
        present(sensor, S_BINARY);
        present(CHILD_ID_2, S_LIGHT_LEVEL);
    int value = digitalRead(BUTTON_PIN_2);
    send(msg1.set(value == HIGH ? 0 : 1));
    if (message.type==V_STATUS) {
    // Change relay state
    digitalWrite(message.sensor-1+RELAY_3, message.getBool()?RELAY_ON:RELAY_OFF);
    // Store state in eeprom
    Can someone help me?
    Boots33B 1 Reply Last reply
    • A arduino_89_89
      void before()
      Boots33B
      Boots33B
      Boots33
      @arduino_89_89 can you give more details of how this node is meant to work. There seems to be some uneeded code in there and I am not sure exactly what you need it to do.
      • dbemowskD
        dbemowskD
        Not sure if this will help, but some time back I built a motion sensor setup to control a flood light for my driveway. The node has a lux/LDR sensor for light/dark, relay and a motion sensor. The idea with that node was that the light would turn on if motion was detected and if it was dark enough. You mat be able to go through the code and take out the motion sensor parts and just use the light sensor and relay code.
        Here was my writeup on the project.
        https://forum.mysensors.org/topic/5243/driveway-motion-light
