  2. Announcements
  • P pandy
    the result of sudo ./bin/mysgw -d is :
    mysgw: Starting gateway...
    and it blocks..
    sineverba
    @pandy Same my problem.
    @gohan I did try also the DIETPI, how you did suggest to me some days ago. Only to say to @pandy let down the idea to use PI1. Use arduino usb/serial with your PI1.
    I did use several nights.... :(
    P 1 Reply Last reply
    • P
      P
      pandy
      Thanks to everyone for the answers and suggestions...
      At this point I think the problem is the raspberry type..
      I will try the suggested solution above otherwise I will be forced to change raspberry ..
      Thanks to everyone for help
      gohanG 1 Reply Last reply
      • S sineverba
        P
        P
        pandy
        @sineverba thank you for your suggestion..Do you have a link where I can find a tutorial for this system?
        thank you so much
        • P pandy
          @pandy go for a new rpi3 that works very well.
          • Velo17V
            Velo17V
            Velo17
            Hello everyone!
            I am trying to use a NRF24 module on the SPI1 of a Raspberry2 (so that I can also use a touch tft on SPI0).
            I enabled it in the config.txt so that is lists under /dev/spidev1.0 - for conveniency I configured the CS0 to be at GPIO16=Pin36 (by using dtoverlay=spi1-1cs,cs0_pin=16).
            I use the dev branch of MySensors.git as the master branch does not recognize my Pi. I used this configure line:
            ./configure --my-rf24-channel=124 --my-rf24-irq-pin=29 --my-rf24-ce-pin=31 --my-rf24-cs-pin=36 --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev1.0
            successful make
            but when I run the gateway in the shell with sudo ./bin/mysgw -d, I get the following:
             __  __       ____
                    |___/                      2.2.0-beta
            mysgw: MCO:BGN:INIT CP=RNNG--Q-
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: pinMode: invalid pin: 29
            mysgw: pinMode: invalid pin: 31
            mysgw: pinMode: invalid pin: 36
            mysgw: digitalWrite: invalid pin: 31
            mysgw: digitalWrite: invalid pin: 36
            mysgw: digitalPinToInterrupt: invalid pin: 29
            Any ideas what I can do to make it work?
            Velo17V 1 Reply Last reply
            • Velo17V Velo17
              Hello everyone!
              successful make
               __  __       ____
                      |___/                      2.2.0-beta
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              Velo17V
              Velo17V
              Velo17
              wrote on last edited by Velo17
              #549
              I think I might have found the root of the problem. The ./configure detects my Rpi2 as such (rpi2) but in the RPi.cpp in line 26 there is the pin to GPIO translation array and it is lacking translations for the high pin numbers - which is obviously wrong as on the RPi2 you have the extended GPIO connector with 40 pins...
              const static int pin_to_gpio_rev1[41] = {-1, -1, -1, 0, -1, 1, -1, 4, 14, -1, 15, 17, 18, 21, -1, 22, 23, -1, 24, 10, -1, 9, 25, 11, 8, -1, 7, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1 };
              const static int pin_to_gpio_rev2[41] = {-1, -1, -1, 2, -1, 3, -1, 4, 14, -1, 15, 17, 18, 27, -1, 22, 23, -1, 24, 10, -1, 9, 25, 11, 8, -1, 7, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1 };
              const static int pin_to_gpio_rev3[41] = {-1, -1, -1, 2, -1, 3, -1, 4, 14, -1, 15, 17, 18, 27, -1, 22, 23, -1, 24, 10, -1, 9, 25, 11, 8, -1, 7, -1, -1, 5, -1, 6, 12, 13, -1, 19, 16, 26, 20, -1, 21 };
              I copied the rev3 array to the rev2 array and compiled this and it seems to work in my case!
              W 1 Reply Last reply
              • Velo17V Velo17
                W
                W
                wergeld
                @Velo17 Thank you! I had been pulling my hair out over this issue on installing a new RPi2 setup.
                • mfalkviddM
                  Adding link to the github issue (thanks for creating!) for future reference
                  https://github.com/mysensors/MySensors/issues/895
                  • Velo17V
                    Velo17V
                    Velo17
                    I just noticed that mysgw is constantly consuming 95-100% CPU here. This even happens when I unplug the NRF24 module so that after starting mysgw basically nothing happens. Running development branch. Hmmmm. Any idea what to check?
                    • Velo17V Velo17
                      #553
                      @Velo17 strace might be able to help:
                      sudo strace ./bin/mysgw -d
                      Could you post your configure command? I'd like to try to reproduce the problem. I have a gateway with development from git as of about 2 weeks ago (a9418271) but I'm not using the nrf24. That gateway uses about 2% cpu on my Raspberry Pi 1. There have only been 6 commits since I built my gateway but I can update it and see if it starts acting up.
                      On my gateway, strace outputs loads and loads of these:
                      gettimeofday({1501098316, 668956}, NULL) = 0
                      ioctl(6, FIONREAD, [0])                 = 0
                      gettimeofday({1501098316, 671383}, NULL) = 0
                      gettimeofday({1501098316, 672447}, NULL) = 0
                      gettimeofday({1501098316, 673818}, NULL) = 0
                      nanosleep({0, 10000000}, NULL)          = 0
                      gettimeofday({1501098316, 685602}, NULL) = 0
                      getsockopt(6, SOL_TCP, TCP_INFO, "\1\0\0\0\0\7g\1P4\3\0@\234\0\0\250\5\0\0\30\2\0\0\0\0\0\0\0\0\0\0"..., [104]) = 0
                      gettimeofday({1501098316, 689179}, NULL) = 0
                      Also, which git hash are you using? (git log -1)
                      Another thing to try could be to enable all the debug flags in MyConfig.h and see if they give you something interesting.
                      • mfalkviddM
                        I updated my gateway to 10ef623 (latest from git). Still works ok.
                          Velo17V
                          Velo17V
                          Velo17
                          @mfalkvidd I make / make install a couple of times and maybe did a git pull inbetween as well - now everything is back to normal again. Thank you for giving me some dbug tips for the next issue :-)
                          My strace output looks similiar.
                          My configure line is
                          ./configure --my-rf24-channel=124 --my-rf24-irq-pin=29 --my-rf24-ce-pin=31 --my-rf24-cs-pin=36 --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev1.0 --my-debug=disable
                          • Sergio RiusS
                            Sergio RiusS
                            Sergio Rius
                            Should be possible to connect two radio modules and run two instances at the same time?
                            It could be interesting to have a hat with nrf+rfm, all in one.
                            • Sergio RiusS Sergio Rius
                              #557
                              @Sergio-Rius it would be great if you could contribute to making that a reality.
                              An earlier discussion on the same topic: https://forum.mysensors.org/topic/4151/nrf24l01-and-rfm69-on-one-gw/
                              So far, people have found it easier to add a separate gateway for each transport.
                                Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                #558
                                @mfalkvidd thanks for guiding me on the starting point. Perhaps the raspberry can break the doble transport limitation.
                                I'll investigate in how to install two services at once. But it'll would be nice any advice on the device virtualization part.
                                • mfalkviddM
                                  Another thread: https://forum.mysensors.org/topic/2331/gateway-with-both-rfm69-and-nrf24l01/
                                  • mfalkviddM
                                    Maybe it could be as simple as running two instances of mysgw, using different pins for the nrf and the rfm?
                                      Sergio RiusS
                                      Sergio RiusS
                                      Sergio Rius
                                      #561
                                      @mfalkvidd Maybe. I'm programmer, but not for Linux. My concern is the part of the service that creates the virtual device colliding between the instances.
                                      I'll do a test in a virtual machine as soon as I have some time.
                                      It should be something easy to test.
                                        @Sergio-Rius by "virtual device", do you mean the com port? If that's the caee, it can be specified with --my-serial-pty=
                                        Ot let one gateway be serial and the other ethernet.
                                          Sergio RiusS
                                          Sergio RiusS
                                          Sergio Rius
                                          @mfalkvidd yes. Should work. I admit I've not taken a look at the code nor I don't know how to install the service two times.
                                          I'm used to having problems with programs that use static resources allocation. But I don't know if that's the case.
