  2. Announcements
  • Velo17V Velo17
    I just noticed that mysgw is constantly consuming 95-100% CPU here. This even happens when I unplug the NRF24 module so that after starting mysgw basically nothing happens. Running development branch. Hmmmm. Any idea what to check?
    #553
    @Velo17 strace might be able to help:
    sudo strace ./bin/mysgw -d
    Could you post your configure command? I'd like to try to reproduce the problem. I have a gateway with development from git as of about 2 weeks ago (a9418271) but I'm not using the nrf24. That gateway uses about 2% cpu on my Raspberry Pi 1. There have only been 6 commits since I built my gateway but I can update it and see if it starts acting up.
    On my gateway, strace outputs loads and loads of these:
    gettimeofday({1501098316, 668956}, NULL) = 0
    ioctl(6, FIONREAD, [0])                 = 0
    gettimeofday({1501098316, 671383}, NULL) = 0
    gettimeofday({1501098316, 672447}, NULL) = 0
    gettimeofday({1501098316, 673818}, NULL) = 0
    nanosleep({0, 10000000}, NULL)          = 0
    gettimeofday({1501098316, 685602}, NULL) = 0
    getsockopt(6, SOL_TCP, TCP_INFO, "\1\0\0\0\0\7g\1P4\3\0@\234\0\0\250\5\0\0\30\2\0\0\0\0\0\0\0\0\0\0"..., [104]) = 0
    gettimeofday({1501098316, 689179}, NULL) = 0
    Also, which git hash are you using? (git log -1)
    Another thing to try could be to enable all the debug flags in MyConfig.h and see if they give you something interesting.
    • mfalkviddM
      I updated my gateway to 10ef623 (latest from git). Still works ok.
      Velo17V 1 Reply Last reply
        Velo17V
        Velo17V
        Velo17
        @mfalkvidd I make / make install a couple of times and maybe did a git pull inbetween as well - now everything is back to normal again. Thank you for giving me some dbug tips for the next issue :-)
        My strace output looks similiar.
        My configure line is
        ./configure --my-rf24-channel=124 --my-rf24-irq-pin=29 --my-rf24-ce-pin=31 --my-rf24-cs-pin=36 --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev1.0 --my-debug=disable
        • Sergio RiusS
          Sergio RiusS
          Sergio Rius
          Should be possible to connect two radio modules and run two instances at the same time?
          It could be interesting to have a hat with nrf+rfm, all in one.
          • Sergio RiusS Sergio Rius
            #557
            @Sergio-Rius it would be great if you could contribute to making that a reality.
            An earlier discussion on the same topic: https://forum.mysensors.org/topic/4151/nrf24l01-and-rfm69-on-one-gw/
            So far, people have found it easier to add a separate gateway for each transport.
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              #558
              @mfalkvidd thanks for guiding me on the starting point. Perhaps the raspberry can break the doble transport limitation.
              I'll investigate in how to install two services at once. But it'll would be nice any advice on the device virtualization part.
              • mfalkviddM
                Another thread: https://forum.mysensors.org/topic/2331/gateway-with-both-rfm69-and-nrf24l01/
                • mfalkviddM
                  Maybe it could be as simple as running two instances of mysgw, using different pins for the nrf and the rfm?
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    #561
                    @mfalkvidd Maybe. I'm programmer, but not for Linux. My concern is the part of the service that creates the virtual device colliding between the instances.
                    I'll do a test in a virtual machine as soon as I have some time.
                    It should be something easy to test.
                      @Sergio-Rius by "virtual device", do you mean the com port? If that's the caee, it can be specified with --my-serial-pty=
                      Ot let one gateway be serial and the other ethernet.
                        Sergio RiusS
                        Sergio RiusS
                        Sergio Rius
                        @mfalkvidd yes. Should work. I admit I've not taken a look at the code nor I don't know how to install the service two times.
                        I'm used to having problems with programs that use static resources allocation. But I don't know if that's the case.
                          maybe you could also consider making 2 ethernet gateway one on port 5003 and the other on port 5004 so that you can use myscontroller to debug from remote.
                            Matt
                            Hi guys couple of questions, apologies if they have been covered elsewhere.
                            I am running latest dev branches of domoticz and MYS on a pi2.
                            At random times it seems the NRF24L01+ LNA/PA goes down, or MYS goes down and domotics stops receiving signals from all of the nodes at the same time. I have the interrupt feature enabled.
                            I have set the option under domoticz/hardware/data timeout to restart if no data received in five minutes but I dont think this is an ideal solution, and have yet to find out if this domoticz feature actually works in my scenario.
                            Any idea what causes this? I found an old thread over on the domoticz/mysensors forum but no answers there. I am using a new sd card class 10.
                            What I want to do is try out the different MYS builds on domoticz ie MQTT and SERIAL as well as ethernet which I am currently running. However I'm not sure how to stop the current MYS service and completely clean up the current build to start from scratch... I have tried just re entering the ./configure commands then 'make' but this does not seem to work.
                            Many thanks,
                            Matt
                            • M Matt
                              Many thanks,
                              Matt
                              #566
                              @Matt log files for the time where the problem occurred will be essential for troubleshooting.
                              make uninstall will stop the service and uninstall
                              make cleanconfig will remove previous ./configure settings
                              make clean will remove compiled code
                              M 2 Replies Last reply
                              • C ccy
                                @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
                                [root@alarmpi bin]# ./mysgw -d
                                mysgw: Starting gateway...
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: !TSM:INIT:TSP FAIL
                                mysgw: TSM:FAIL:CNT=1
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:FAIL:RE-INIT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:CNT=2
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:CNT=3
                                mysgw: TSM:FAIL:PDT
                                mysgw: Received SIGINT
                                Here is my /boot/config.txt:
                                gpu_mem=64
                                initramfs initramfs-linux.img followkernel
                                dtparam=spi=on
                                and the spi dev:
                                # ls /dev/spidev0.*
                                I am using ArchLinuxARM:
                                # uname -a
                                Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
                                I only wiring 7 pins (1-7) on NRF24l01+.
                                Raspberry Pi 2 hardware information:
                                # cat /proc/cpuinfo
                                processor       : 0
                                model name      : ARMv7 Processor rev 5 (v7l)
                                BogoMIPS        : 38.40
                                Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
                                CPU implementer : 0x41
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 1
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 2
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                processor       : 3
                                BogoMIPS        : 38.40
                                CPU architecture: 7
                                CPU variant     : 0x0
                                CPU part        : 0xc07
                                CPU revision    : 5
                                Hardware        : BCM2835
                                Revision        : a21041
                                Serial          : 00000000475d18a4
                                # cat /sys/firmware/devicetree/base/model
                                Raspberry Pi 2 Model B Rev 1.1
                                Output from MySensors configure:
                                # ./configure
                                ./configure: line 111: warning: command substitution: ignored null byte in input
                                [OK] Finished.
                                I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
                                function detect_machine {
                                    case $hardware in
                                    BCM2835)
                                        soc="BCM2835"
                                        if [[ $machine == "Raspberry"* ]]; then
                                            local rev=($(detect_rpi_revision))
                                            if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                                                tp="RPi3"
                                                tp="Rpi2"
                                            fi
                                        fi
                                make mysgw again, and I get this finally:
                                # ./mysgw -d
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: TSM:INIT:TSP OK
                                mysgw: TSM:INIT:GW MODE
                                mysgw: MCO:REG:NOT NEEDED
                                mysgw: MCO:BGN:STP
                                mysgw: MCO:BGN:INIT OK,TSP=1
                                enloE
                                enloE
                                enlo
                                @ccy that correction to the detect_machine function was necessary on my Rpi 3 too (I took the latest version from master). I got it working with that addition.
                                Soooo I guess that would be worth adding to the code / opening an issue on github, wouldn't it?
                                • Sergio RiusS
                                  Sergio RiusS
                                  Sergio Rius
                                  I'm just now testing the two instances installation. I was going to just alter the flag --prefix but now I see in options that there's also the install dir:
                                  Installation options:
                                      --prefix=<PREFIX>           Installation prefix path. [/usr/local]
                                      --gateway-dir=<DIR>         Gateway files installation directory. [PREFIX/bin]
                                  What do you think should be the preferred way for installing two instances, only changing --gateway-dir?
                                    Matt
                                    @mfalkvidd OK thanks for your reply.
                                    Have set up the -d parameter in mysgw.servie and am waiting for it to fall over again.
                                    If I catch it I will post syslog.
                                    Matt
                                    • Sergio RiusS
                                      Sergio RiusS
                                      Sergio Rius
                                      #570
                                      Seems that I'll need some help for getting this properly done.
                                      I can't launch two instances of the service.
                                      What I've done is following the guide instructions with the following configuration:
                                      ./configure \
                                       --my-transport=nrf24 \
                                       --my-rf24-irq-pin=18 \
                                       --my-gateway=ethernet --my-port=5003 \
                                       --prefix=/opt/mysgw-nrf
                                      Then manually executed it, and it run ok and get one test node connected and Domoticz saw it all.
                                      Then I duplicated the MySensors folder and in there made the build with the following configuration:
                                      ./configure \
                                       --my-rf24-channel=82 \
                                       --my-rf24-ce-pin=37 \
                                       --my-rf24-cs-pin=36 \
                                       --my-rf24-irq-pin=33 \
                                       --my-gateway=ethernet --my-port=5004 \
                                       --prefix=/opt/mysgw-rfm
                                      Even when it says rfm, i connected a second NRF with the following pinout (blue=first NRF, green=second):
                                      *IRQ on pin 33 as config says, and power from 1.
                                      Then I tried to make and run and I get this output:
                                      pi@domo_testing:~/MySGW_RFM $ sudo ./bin/mysgw -d
                                       __  __       ____
                                              |___/                      2.2.0-beta
                                      mysgw: MCO:BGN:INIT CP=RNNG--Q-
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: pinMode: invalid pin: 33
                                      mysgw: pinMode: invalid pin: 37
                                      mysgw: pinMode: invalid pin: 36
                                      mysgw: digitalWrite: invalid pin: 37
                                      mysgw: digitalWrite: invalid pin: 36
                                      mysgw: You need root privilege to use SPI.
                                      Is that I have to connect MOSI and MISO to the same pins that the first NRF?
                                        ./configure \
                                        ./configure \
                                         __  __       ____
                                                |___/                      2.2.0-beta
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        @Sergio-Rius see https://forum.mysensors.org/post/72145 and https://github.com/mysensors/MySensors/issues/895
                                          Sergio RiusS
                                          Sergio RiusS
                                          Sergio Rius
                                          #572
                                          @mfalkvidd That was the culprit. Thanks.
                                          But now... seems that the radio that is using channel 76 also get connections from nodes on channel 83, and the second radio, the 83 one doesn't pick anything.
                                          Is there a way to confirm that gw and nodes are using one channel or other during the bootup?
                                          gohanG 1 Reply Last reply
