  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • R
    R
    Rene046
    i dont know how but i got it now running perfect, and cleaned up a bid.
    for if anyone could use ....
    #include <BH1750.h>
    #include <OneWire.h>
    // Data wire is plugged into port 3 on the Arduino
    #define ONE_WIRE_BUS 3
    // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    // Pass our oneWire reference to Dallas Temperature.
    // arrays to hold device address
    DeviceAddress insideThermometer;
    int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
    #define CHILD_ID_BATTERY 4
    #define CHILD_ID_SOLAR 6
    #define CHILD_ID_LIGHT 1
    #define CHILD_ID_TEMP1 2
    BH1750 lightSensor;
    float TempC = 50.5;
    int oldBatteryPcnt = 0;
    MyMessage msgTempC(CHILD_ID_TEMP1,V_TEMP);
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
    uint16_t lastlux;  //lux
    void setup(void)
      analogReference(INTERNAL1V1);
      analogReference(INTERNAL);
      sendSketchInfo("Battery Meter", "2.0");
      sensors.begin(); // start reading sensor
      // search for devices on the bus and assign based on an index.  ideally,
      if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
      // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
      //sensors.setResolution(insideThermometer, 9);
    void loop(void)
     // get the battery Voltage
      int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
      delay(1000);
      int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
      delay(100);
      delay(1000);
      int sensorValueS = analogRead(SOLAR_SENSE_PIN);
      delay(1000);
    #ifdef MY_DEBUG
      Serial.print("Battery Voltage2: ");
      Serial.println(sensorValue2);
      Serial.print("Battery Voltage1: ");
      Serial.println(sensorValue1);
      Serial.println(sensorValue);
      Serial.print("Solar Voltage: ");
      Serial.println(sensorValueS);
      const float vRef = 4.200/ 1.05/ 1023 ;
      float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
      float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
      float TempC = sensors.getTempC(insideThermometer);
    #ifdef MY_DEBUG
      Serial.print("DS1820 Temperature: ");
      Serial.print(TempC);
      Serial.println(" C");
    send(msgTempC.set(TempC ,2));
      Serial.print(batteryV);
      Serial.println(" V");
    send(msgbatt.set(batteryV ,2));
      Serial.print(batteryS);
    send(msgsolar.set(batteryS ,2));
      Serial.print(batteryPcnt);
      Serial.println(" %");
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
      Serial.println(lux);
      if (lux != lastlux) {
          send(msg.set(lux));
          lastlux = lux;
      sleep(SLEEP_TIME);
    • CptSlowC
      CptSlowC
      CptSlow
      Can someone push me into the right direction.
      I followed the "tutorial" and setup a Serial Gateway. This seems to be running just fine.
      Now i want to add a node with a temperature sensor.
      Both are using the NRF24L radio.
      On my node i get an errors in the serial monitor.
      What did i do wrong?
      3 MCO:BGN:BFR
      63 TSM:INIT
      64 TSF:WUR:MS=0
      71 !TSM:INIT:TSP FAIL
      72 TSM:FAIL:CNT=1
      74 TSM:FAIL:PDT
      10077 TSM:FAIL:RE-INIT
      10079 TSM:INIT
      10085 !TSM:INIT:TSP FAIL
      10088 TSM:FAIL:CNT=2
      10089 TSM:FAIL:PDT
        have you checked https://www.mysensors.org/build/debug ?
        • CptSlowC
          CptSlowC
          CptSlow
          Hi Gohan,
          I did not know that page. Thanks for the push :+1:
          I think i have crappy radio tho, because i switched it with anotherone i have and it started working....
            don't tell me about crappy nrf24... I got a bunch of really bad ones that work but only for 5 meters max.
            • skywatchS
              skywatchS
              skywatch
              I just tried this today but get an error. Here's the output.....
              Arduino: 1.8.3 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
              In file included from C:\Users\captain\Documents\Arduino\MYS-HW-CH\MYS-HW-CH.ino:37:0:
              C:\Users\captain\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
              C:\Users\captain\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
               int16_t millisToWaitForConversion(uint8_t);
              MYS-HW-CH:85: error: within this context
              exit status 1
              within this context
              THis is MYS 2.1.1 installed so a bit baffled as to what is causing the problem, it should just work, right?
              Anyone with any insight please let me know! :)
              • skywatchS skywatch
                exit status 1
                within this context
                #62
                @skywatch just follow the instructions on the build page:
                This example uses a modified version of the external DTH library, which is included in the MySensors external examples. Please install it and restart the Arduino IDE before trying to compile.
                • skywatchS
                  skywatchS
                  skywatch
                  Thank you - that did it.
                  But it would be good to have that info in the file header too, just to call attention to it. Either that or a structured step-by-step tutorial so that things like this don't get left out.
                  At least it works now though, kul!
                  • markjgabbM
                    markjgabbM
                    markjgabb
                    really silly question.....so does create multiple sensors? so i would have temp1 temp2 or does it combine the value of both for an averaged temprature?
                    the way i read it it would present mutiple sensors i think?
                      It creates the sensors that you present during the presentation.
                      • markjgabbM
                        markjgabbM
                        markjgabb
                        appologies for the badly worded questions...the code in its example format....
                        am i reading it correctly that it presents sensors based on the variable for number of temp sensors?
                          It will present different sensros according to the #define MAX_ATTACHED_DS18B20 16
                          • DigdoggerD
                            DigdoggerD
                            Digdogger
                            I have only one sensor on the mini pro and I have this in the logs:
                            2017-07-30 14:41:28.492 (Mysensor) Temp (Congélateur)
                            2017-07-30 14:41:28.497 (Mysensor) Temp (Congélateur)
                            2017-07-30 14:41:28.501 (Mysensor) Temp (Congélateur)
                            2017-07-30 14:41:28.506 (Mysensor) Temp (Congélateur)
                            2017-07-30 14:41:28.510 (Mysensor) Temp (Congélateur)
                            2017-07-30 14:41:28.515 (Mysensor) Temp (Congélateur)
                            2017-07-30 14:41:28.521 (Mysensor) Temp (Congélateur)
                            2017-07-30 14:41:28.526 (Mysensor) Temp (Congélateur)
                            Sleep time is set to 60000ms, why the time between 2 messages is around 5ms???
                            • DigdoggerD Digdogger
                              #69
                              @Digdogger it can depend on a lot of things. The best way to know is to look at the debug logs from the node and the gateway from the time when it happened. There could be a problem with the communication, with the radios, with the power supply, with the sketch, etc.
                              It could also be that you're using a microcontroller that doesn't support MySensors sleep, such as the esp8266. But it is just a guess. The information that's usually needed to troubleshoot is listed in https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/
                              • DigdoggerD
                                DigdoggerD
                                Digdogger
                                OK thanks mfalkvidd
                                • ben999B
                                  ben999B
                                  ben999
                                  Slightly off-topic here... but related to this particular sketch
                                  If you look close enough (and copy-paste the sketch into your IDE) you'll witness that one curly-bracket is technically missing at the end of loop()...
                                  But as I added it to the sketch I got error
                                  Sketch compiles fine "with" the missing curly-bracket... ???
                                  Any comment to that (in my sense) funny behavior ?
                                  • ben999B ben999
                                    #72
                                    @ben999 the simple answer is probably that the backet isn't missing :)
                                    Can you show why you think it is missing?
                                    • ben999B
                                      ben999B
                                      ben999
                                      wrote on last edited by ben999
                                      #73
                                      @mfalkvidd
                                      I must have gone mad then :ghost:
                                      Check the loop()
                                      The last closing curly--bracket is for
                                      So which one closes
                                      void loop()     {
                                      If i add one more to "make it right" then hell brakes loose...
                                      sketch_jul31a:110: error: expected declaration before '}' token
                                      exit status 1
                                      1-That's the only sketch behaving this way
                                      2-Even the "IDE-automatic-opening-bracket-finder" (shows which bracket is open when placing cursor on closing bracket) can NOT find the right bracket for loop()...
                                      :scream:
                                      • mfalkviddM
                                        Interesting observation @ben999
                                        This is caused by the preprocessing directives.
                                        #if COMPARE_TEMP == 1
                                        Only one of these if statements will be active. The Arduino IDE probably doesn't evaluate preprocessing directives, so it sees two if statements and therefore thinks it should see two end braces. A way to "fix" this could be to move the starting curly brace to after the preprocessing directives:
                                        This allows the Arduino IDE to parse the code correctly, and correctly match the braces.
                                        ben999B 1 Reply Last reply
                                          It's time to move to a better IDE 😁
