  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • R
    R
    Rene046
    here is my serial result.
    45651 MCO:SLP:WUP=-1
    Temp C: 17.87 Temp F: 64.18
    Battery Voltage2: 931
    Battery Voltage1: 926
    Battery Voltage: 927
    Solar Voltage: 393
    DS1820 Temperature: 50.50 C
    49545 TSF:MSG:SEND,2-2-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:50.50
    Battery Voltage: 3.95 V
    49557 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.95
    Solar Voltage: 4.03 V
    49569 TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:4.03
    Battery percent: 92 %
    49577 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    49584 MCO:SLP:TPD
    • R
      R
      Rene046
      i dont know how but i got it now running perfect, and cleaned up a bid.
      for if anyone could use ....
      #include <BH1750.h>
      #include <OneWire.h>
      // Data wire is plugged into port 3 on the Arduino
      #define ONE_WIRE_BUS 3
      // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
      // Pass our oneWire reference to Dallas Temperature.
      // arrays to hold device address
      DeviceAddress insideThermometer;
      int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
      #define CHILD_ID_BATTERY 4
      #define CHILD_ID_SOLAR 6
      #define CHILD_ID_LIGHT 1
      #define CHILD_ID_TEMP1 2
      BH1750 lightSensor;
      float TempC = 50.5;
      int oldBatteryPcnt = 0;
      MyMessage msgTempC(CHILD_ID_TEMP1,V_TEMP);
      MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
      MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
      uint16_t lastlux;  //lux
      void setup(void)
        analogReference(INTERNAL1V1);
        analogReference(INTERNAL);
        sendSketchInfo("Battery Meter", "2.0");
        sensors.begin(); // start reading sensor
        // search for devices on the bus and assign based on an index.  ideally,
        if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
        // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
        //sensors.setResolution(insideThermometer, 9);
      void loop(void)
       // get the battery Voltage
        int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
        delay(1000);
        int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
        delay(100);
        delay(1000);
        int sensorValueS = analogRead(SOLAR_SENSE_PIN);
        delay(1000);
      #ifdef MY_DEBUG
        Serial.print("Battery Voltage2: ");
        Serial.println(sensorValue2);
        Serial.print("Battery Voltage1: ");
        Serial.println(sensorValue1);
        Serial.println(sensorValue);
        Serial.print("Solar Voltage: ");
        Serial.println(sensorValueS);
        const float vRef = 4.200/ 1.05/ 1023 ;
        float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
        float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
        float TempC = sensors.getTempC(insideThermometer);
      #ifdef MY_DEBUG
        Serial.print("DS1820 Temperature: ");
        Serial.print(TempC);
        Serial.println(" C");
      send(msgTempC.set(TempC ,2));
        Serial.print(batteryV);
        Serial.println(" V");
      send(msgbatt.set(batteryV ,2));
        Serial.print(batteryS);
      send(msgsolar.set(batteryS ,2));
        Serial.print(batteryPcnt);
        Serial.println(" %");
          // Power up radio after sleep
          oldBatteryPcnt = batteryPcnt;
        Serial.println(lux);
        if (lux != lastlux) {
            send(msg.set(lux));
            lastlux = lux;
        sleep(SLEEP_TIME);
      • CptSlowC
        CptSlowC
        CptSlow
        Can someone push me into the right direction.
        I followed the "tutorial" and setup a Serial Gateway. This seems to be running just fine.
        Now i want to add a node with a temperature sensor.
        Both are using the NRF24L radio.
        On my node i get an errors in the serial monitor.
        What did i do wrong?
        3 MCO:BGN:BFR
        63 TSM:INIT
        64 TSF:WUR:MS=0
        71 !TSM:INIT:TSP FAIL
        72 TSM:FAIL:CNT=1
        74 TSM:FAIL:PDT
        10077 TSM:FAIL:RE-INIT
        10079 TSM:INIT
        10085 !TSM:INIT:TSP FAIL
        10088 TSM:FAIL:CNT=2
        10089 TSM:FAIL:PDT
          have you checked https://www.mysensors.org/build/debug ?
          • CptSlowC
            CptSlowC
            CptSlow
            Hi Gohan,
            I did not know that page. Thanks for the push :+1:
            I think i have crappy radio tho, because i switched it with anotherone i have and it started working....
              don't tell me about crappy nrf24... I got a bunch of really bad ones that work but only for 5 meters max.
              • skywatchS
                skywatchS
                skywatch
                I just tried this today but get an error. Here's the output.....
                Arduino: 1.8.3 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
                In file included from C:\Users\captain\Documents\Arduino\MYS-HW-CH\MYS-HW-CH.ino:37:0:
                C:\Users\captain\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
                C:\Users\captain\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                 int16_t millisToWaitForConversion(uint8_t);
                MYS-HW-CH:85: error: within this context
                exit status 1
                within this context
                THis is MYS 2.1.1 installed so a bit baffled as to what is causing the problem, it should just work, right?
                Anyone with any insight please let me know! :)
                • skywatchS skywatch
                  exit status 1
                  within this context
                  #62
                  @skywatch just follow the instructions on the build page:
                  This example uses a modified version of the external DTH library, which is included in the MySensors external examples. Please install it and restart the Arduino IDE before trying to compile.
                  • skywatchS
                    skywatchS
                    skywatch
                    Thank you - that did it.
                    But it would be good to have that info in the file header too, just to call attention to it. Either that or a structured step-by-step tutorial so that things like this don't get left out.
                    At least it works now though, kul!
                    • markjgabbM
                      markjgabbM
                      markjgabb
                      really silly question.....so does create multiple sensors? so i would have temp1 temp2 or does it combine the value of both for an averaged temprature?
                      the way i read it it would present mutiple sensors i think?
                        It creates the sensors that you present during the presentation.
                        • markjgabbM
                          markjgabbM
                          markjgabb
                          appologies for the badly worded questions...the code in its example format....
                          am i reading it correctly that it presents sensors based on the variable for number of temp sensors?
                            It will present different sensros according to the #define MAX_ATTACHED_DS18B20 16
                            • DigdoggerD
                              DigdoggerD
                              Digdogger
                              I have only one sensor on the mini pro and I have this in the logs:
                              2017-07-30 14:41:28.492 (Mysensor) Temp (Congélateur)
                              2017-07-30 14:41:28.497 (Mysensor) Temp (Congélateur)
                              2017-07-30 14:41:28.501 (Mysensor) Temp (Congélateur)
                              2017-07-30 14:41:28.506 (Mysensor) Temp (Congélateur)
                              2017-07-30 14:41:28.510 (Mysensor) Temp (Congélateur)
                              2017-07-30 14:41:28.515 (Mysensor) Temp (Congélateur)
                              2017-07-30 14:41:28.521 (Mysensor) Temp (Congélateur)
                              2017-07-30 14:41:28.526 (Mysensor) Temp (Congélateur)
                              Sleep time is set to 60000ms, why the time between 2 messages is around 5ms???
                              • DigdoggerD Digdogger
                                #69
                                @Digdogger it can depend on a lot of things. The best way to know is to look at the debug logs from the node and the gateway from the time when it happened. There could be a problem with the communication, with the radios, with the power supply, with the sketch, etc.
                                It could also be that you're using a microcontroller that doesn't support MySensors sleep, such as the esp8266. But it is just a guess. The information that's usually needed to troubleshoot is listed in https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/
                                • DigdoggerD
                                  DigdoggerD
                                  Digdogger
                                  OK thanks mfalkvidd
                                  • ben999B
                                    ben999B
                                    ben999
                                    Slightly off-topic here... but related to this particular sketch
                                    If you look close enough (and copy-paste the sketch into your IDE) you'll witness that one curly-bracket is technically missing at the end of loop()...
                                    But as I added it to the sketch I got error
                                    Sketch compiles fine "with" the missing curly-bracket... ???
                                    Any comment to that (in my sense) funny behavior ?
                                    • ben999B ben999
                                      #72
                                      @ben999 the simple answer is probably that the backet isn't missing :)
                                      Can you show why you think it is missing?
                                      • ben999B
                                        ben999B
                                        ben999
                                        wrote on last edited by ben999
                                        #73
                                        @mfalkvidd
                                        I must have gone mad then :ghost:
                                        Check the loop()
                                        The last closing curly--bracket is for
                                        So which one closes
                                        void loop()     {
                                        If i add one more to "make it right" then hell brakes loose...
                                        sketch_jul31a:110: error: expected declaration before '}' token
                                        exit status 1
                                        1-That's the only sketch behaving this way
                                        2-Even the "IDE-automatic-opening-bracket-finder" (shows which bracket is open when placing cursor on closing bracket) can NOT find the right bracket for loop()...
                                        :scream:
                                        • mfalkviddM
                                          Interesting observation @ben999
                                          This is caused by the preprocessing directives.
                                          #if COMPARE_TEMP == 1
                                          Only one of these if statements will be active. The Arduino IDE probably doesn't evaluate preprocessing directives, so it sees two if statements and therefore thinks it should see two end braces. A way to "fix" this could be to move the starting curly brace to after the preprocessing directives:
                                          This allows the Arduino IDE to parse the code correctly, and correctly match the braces.
                                          ben999B 1 Reply Last reply
