  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • WoekaW
    WoekaW
    Woeka
    I had some problems with Domoticz triggering an event based on a certain temperature. When using multiple DS18B20 it is a good idea to use the ID of the sensors to always get the same order of sensors. If one is not read, for example B of A, B, C then C becomes B. See: https://forum.mysensors.org/topic/4143/about-ds18b20-onewire for more info. You maybe need to adjust the sketch a bit for your number of sensors.
    • R
      R
      Rene046
      @CurtisMack
      could you explain how to solve this ?
      I'm no pro, and wanted to use 1 single DS1820 in a sketch and also got same message about :
      Mysensors is hard hard nut to learn, specially because of a lot of changes in the newer version 2.1.0 ...(and im still learning to work with arduino software , i keep running often against old sketches i like to try as sample to use them in other sketches , (my way of learning) but than they dont work with latest version. because something changed.
      but i love the mysensors functions.
      p.s sorry for my bad english....
      K 1 Reply Last reply
      • R Rene046
        @CurtisMack
        K
        K
        kontrollable
        @Rene046 The solution is here:https://forum.mysensors.org/topic/4828/temperature-sensor/46
        • R
          R
          Rene046
          I sofar got the sketch running and giving good data on serial and into domoticz
          i only could use some help with how to sent my Temperature in Celsius to domoticz to
          i tried to use:
          send(msgTemp.set(insideThermometer ,2));
          and
          send(msgTemp.set(tempC,2));
          both without luck, the first did transmit some data but wrong numbers
          second did nothing think because with this i done i does not know what address the DS1820 is on.
          Im learning every day something new....
          Maybe someone could help,
          G 1 Reply Last reply
          • R
            R
            Rene046
            forgot the sketch
            #include <BH1750.h>
            #include <OneWire.h>
            // Data wire is plugged into port 3 on the Arduino
            #define ONE_WIRE_BUS 3
            // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
            // Pass our oneWire reference to Dallas Temperature.
            // arrays to hold device address
            DeviceAddress insideThermometer;
            unsigned long SLEEP_TIME = 180000; // Sleep time between reads (in milliseconds)
            int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
            #define CHILD_ID_BATTERY 4
            #define CHILD_ID_SOLAR 6
            #define CHILD_ID_LIGHT 1
            #define CHILD_ID_TEMP1 2
            BH1750 lightSensor;
            int oldBatteryPcnt = 0;
            MyMessage msgTemp(CHILD_ID_TEMP1,V_TEMP);
            MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
            MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
            uint16_t lastlux;  //lux
            void setup(void)
              analogReference(INTERNAL1V1);
              analogReference(INTERNAL);
              sendSketchInfo("Battery Meter", "2.0");
              //Serial.begin(9600); // start serial port
              Serial.print("Locating devices..."); // locate devices on the bus
              sensors.begin(); // start reading sensor
              Serial.print("Found ");
              Serial.print(sensors.getDeviceCount(), DEC);
              Serial.println(" devices.");
              Serial.print("Parasite power is: "); // report parasite power requirements
              if (sensors.isParasitePowerMode()) Serial.println("ON");
              else Serial.println("OFF");
            // assign address manually.  the addresses below will beed to be changed
              // to valid device addresses on your bus.  device address can be retrieved
              // by using either oneWire.search(deviceAddress) or individually via
              // sensors.getAddress(deviceAddress, index)
              //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
              // Method 1:
              // search for devices on the bus and assign based on an index.  ideally,
              // you would do this to initially discover addresses on the bus and then
              // use those addresses and manually assign them (see above) once you know
              // the devices on your bus (and assuming they don't change).
              if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
              // method 2: search()
              // search() looks for the next device. Returns 1 if a new address has been
              // returned. A zero might mean that the bus is shorted, there are no devices,
              // or you have already retrieved all of them.  It might be a good idea to
              // check the CRC to make sure you didn't get garbage.  The order is
              // deterministic. You will always get the same devices in the same order
              // Must be called before search()
              //oneWire.reset_search();
              // assigns the first address found to insideThermometer
              //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
              // show the addresses we found on the bus
              Serial.print("Device 0 Address: ");
              printAddress(insideThermometer);
              Serial.println();
              // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
              sensors.setResolution(insideThermometer, 9);
              Serial.print("Device 0 Resolution: ");
              Serial.print(sensors.getResolution(insideThermometer), DEC);
              Serial.println();
            // function to print the temperature for a device
            void printTemperature(DeviceAddress deviceAddress)
              // method 1 - slower
              //Serial.print("Temp C: ");
              //Serial.print(sensors.getTempC(deviceAddress));
              //Serial.print(" Temp F: ");
              //Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
              // method 2 - faster
              float tempC = sensors.getTempC(deviceAddress);
              Serial.print(tempC);
              Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
            void loop(void)
              // call sensors.requestTemperatures() to issue a global temperature
              // request to all devices on the bus
              Serial.print("Requesting temperatures...");
              sensors.requestTemperatures(); // Send the command to get temperatures
              Serial.println("DONE");
              // It responds almost immediately. Let's print out the data
              printTemperature(insideThermometer); // Use a simple function to print out the data
             // get the battery Voltage
              int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
              delay(1000);
              int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
              delay(100);
              delay(1000);
              int sensorValueS = analogRead(SOLAR_SENSE_PIN);
              delay(1000);
            #ifdef MY_DEBUG
              Serial.print("Battery Voltage2: ");
              Serial.println(sensorValue2);
              Serial.print("Battery Voltage1: ");
              Serial.println(sensorValue1);
              Serial.println(sensorValue);
              Serial.print("Solar Voltage: ");
              Serial.println(sensorValueS);
              const float vRef = 4.200/ 1.05/ 1023 ;
              float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
              float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
            #ifdef MY_DEBUG
              Serial.print(batteryV);
              Serial.println(" V");
            send(msgbatt.set(batteryV ,2));
              Serial.print(batteryS);
            send(msgsolar.set(batteryS ,2));
              Serial.print(batteryPcnt);
              Serial.println(" %");
                // Power up radio after sleep
                oldBatteryPcnt = batteryPcnt;
              Serial.println(lux);
              if (lux != lastlux) {
                  send(msg.set(lux));
                  lastlux = lux;
              sleep(SLEEP_TIME);
            // function to print a device address
            void printAddress(DeviceAddress deviceAddress)
              for (uint8_t i = 0; i < 8; i++)
                if (deviceAddress[i] < 16) Serial.print("0");
                Serial.print(deviceAddress[i], HEX);
            C 1 Reply Last reply
            • R Rene046
              forgot the sketch
              #include <BH1750.h>
              BH1750 lightSensor;
              void setup(void)
                // Method 1:
                Serial.println();
                Serial.println();
              void loop(void)
                delay(1000);
                delay(100);
                delay(1000);
                delay(1000);
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
                    send(msg.set(lux));
                    lastlux = lux;
                sleep(SLEEP_TIME);
              C
              C
              CurtisMack
              @Rene046 Your sketch doesn't show either of the send commands you say you are attempting. This makes it difficult to determine why it wouldn't be working. I am relative new to all of this as well, and use Vera not a Domoticz. On the first version that is sending a message, what data is getting through? I would try putting the "send" command someplace in the code where msgTemp has already been set. Then just call send(msgTemp).
              • R
                R
                Rene046
                hi
                Then i would have placed this in the loop>
                The error i get then is :'TempC' was not declared in this scope
                #ifdef MY_DEBUG
                Serial.print("DS1820 Temperature: ");
                  Serial.println(" C");
                send(msgTemp.set(tempC ,2));
                send(msgbatt.set(batteryV ,2));```
                • R
                  R
                  Rene046
                  so far my result.
                  had to use float TempC = 50.5 at the start
                  but in my serial i get the right temperature,
                  but using it in the loop gives me still wrong number 50.5 so gets not updated.
                  #include <BH1750.h>
                  BH1750 lightSensor;
                  float TempC = 50.5;
                  void setup(void)
                    //insideThermometer = { 0x10, 0x9C, 0x04, 0x26, 0x01, 0x08, 0x0, 0x8C };
                    // Method 1:
                    Serial.println();
                    Serial.println();
                    float TempC = sensors.getTempC(deviceAddress);
                    Serial.print(TempC);
                    Serial.println(DallasTemperature::toFahrenheit(TempC)); // Converts tempC to Fahrenheit
                  void loop(void)
                    delay(1000);
                    delay(100);
                    delay(1000);
                    delay(1000);
                  #ifdef MY_DEBUG
                  #ifdef MY_DEBUG
                  send(msgTemp.set(TempC ,2));
                        send(msg.set(lux));
                        lastlux = lux;
                    sleep(SLEEP_TIME);
                  • R
                    R
                    Rene046
                    here is my serial result.
                    45651 MCO:SLP:WUP=-1
                    Temp C: 17.87 Temp F: 64.18
                    Battery Voltage2: 931
                    Battery Voltage1: 926
                    Battery Voltage: 927
                    Solar Voltage: 393
                    DS1820 Temperature: 50.50 C
                    49545 TSF:MSG:SEND,2-2-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:50.50
                    Battery Voltage: 3.95 V
                    49557 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.95
                    Solar Voltage: 4.03 V
                    49569 TSF:MSG:SEND,2-2-0-0,s=6,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:4.03
                    Battery percent: 92 %
                    49577 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                    49584 MCO:SLP:TPD
                    • R
                      R
                      Rene046
                      i dont know how but i got it now running perfect, and cleaned up a bid.
                      for if anyone could use ....
                      #include <BH1750.h>
                      BH1750 lightSensor;
                      float TempC = 50.5;
                      MyMessage msgTempC(CHILD_ID_TEMP1,V_TEMP);
                      void setup(void)
                        //sensors.setResolution(insideThermometer, 9);
                      void loop(void)
                        delay(1000);
                        delay(100);
                        delay(1000);
                        delay(1000);
                      #ifdef MY_DEBUG
                        float TempC = sensors.getTempC(insideThermometer);
                      #ifdef MY_DEBUG
                      send(msgTempC.set(TempC ,2));
                            send(msg.set(lux));
                            lastlux = lux;
                        sleep(SLEEP_TIME);
                      • CptSlowC
                        CptSlowC
                        CptSlow
                        Can someone push me into the right direction.
                        I followed the "tutorial" and setup a Serial Gateway. This seems to be running just fine.
                        Now i want to add a node with a temperature sensor.
                        Both are using the NRF24L radio.
                        On my node i get an errors in the serial monitor.
                        What did i do wrong?
                        3 MCO:BGN:BFR
                        63 TSM:INIT
                        64 TSF:WUR:MS=0
                        71 !TSM:INIT:TSP FAIL
                        72 TSM:FAIL:CNT=1
                        74 TSM:FAIL:PDT
                        10077 TSM:FAIL:RE-INIT
                        10079 TSM:INIT
                        10085 !TSM:INIT:TSP FAIL
                        10088 TSM:FAIL:CNT=2
                        10089 TSM:FAIL:PDT
                          have you checked https://www.mysensors.org/build/debug ?
                          • CptSlowC
                            CptSlowC
                            CptSlow
                            Hi Gohan,
                            I did not know that page. Thanks for the push :+1:
                            I think i have crappy radio tho, because i switched it with anotherone i have and it started working....
                              don't tell me about crappy nrf24... I got a bunch of really bad ones that work but only for 5 meters max.
                              • skywatchS
                                skywatchS
                                skywatch
                                I just tried this today but get an error. Here's the output.....
                                Arduino: 1.8.3 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
                                In file included from C:\Users\captain\Documents\Arduino\MYS-HW-CH\MYS-HW-CH.ino:37:0:
                                C:\Users\captain\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
                                C:\Users\captain\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                                 int16_t millisToWaitForConversion(uint8_t);
                                MYS-HW-CH:85: error: within this context
                                exit status 1
                                within this context
                                THis is MYS 2.1.1 installed so a bit baffled as to what is causing the problem, it should just work, right?
                                Anyone with any insight please let me know! :)
                                • skywatchS skywatch
                                  exit status 1
                                  within this context
                                  #62
                                  @skywatch just follow the instructions on the build page:
                                  This example uses a modified version of the external DTH library, which is included in the MySensors external examples. Please install it and restart the Arduino IDE before trying to compile.
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    Thank you - that did it.
                                    But it would be good to have that info in the file header too, just to call attention to it. Either that or a structured step-by-step tutorial so that things like this don't get left out.
                                    At least it works now though, kul!
                                    • markjgabbM
                                      markjgabbM
                                      markjgabb
                                      really silly question.....so does create multiple sensors? so i would have temp1 temp2 or does it combine the value of both for an averaged temprature?
                                      the way i read it it would present mutiple sensors i think?
                                        It creates the sensors that you present during the presentation.
                                        • markjgabbM
                                          markjgabbM
                                          markjgabb
                                          appologies for the badly worded questions...the code in its example format....
                                          am i reading it correctly that it presents sensors based on the variable for number of temp sensors?
