  3. Repeatrer level limit (NRF24L01 transport)
25 Posts 3 Posters 6.6k Views 4 Watching
    @bilbolodz first question: it might be possible using the method suggested here: https://forum.mysensors.org/topic/5410/changing-node-id-at-run-time/
    If you try it, please report back with the results. If it works we should document it somewhere where it is easier to find.
    Second question: it might be possible using the same technique as above, but I think you would need to reset the node or trigger re-initialization of the radio. Maybe sleep is enough, I'm not sure if the radio is re-initialized after sleep.
    Adding reference for the second question: https://github.com/mysensors/MySensors/issues/900
    B
    B
    bilbolodz
    @mfalkvidd said in Repeatrer level limit (NRF24L01 transport):
    For sure there is possibility to change ID of node "on the fly" set:
    #define MY_NODE_ID AUTO
    and send message C_INTERNAL I_ID_RESPONSE with new ID node. Working even without node reboot
    I will check your method with parent ID. I will try to check also these method with power level but I don't know how to check in programming way current NRF power.
    • B bilbolodz
      @bilbolodz the level is RF24_PA_HIGH unless you have an override in your sketch. See https://github.com/mysensors/MySensors/blob/10ef62307b914c88295977d58b9601d994e89117/MyConfig.h#L640
      B 1 Reply Last reply
        The radio object can be accessed through the global variable _radio (see here). Maybe you can just call the appropriate function?
        B
        B
        bilbolodz
        I've made a quick grep. It looks that _radio is avaliable for RFM69 transport. For NFR there is a function RF24_setRFSetup but as parameter i takes MY_RF24_RF_SETUP defined as:
        #define MY_RF24_RF_SETUP (uint8_t)( ((MY_RF24_DATARATE & 0b10 ) << 4) | ((MY_RF24_DATARATE & 0b01 ) << 3) | (MY_RF24_PA_LEVEL << 1) ) + 1 // +1 for Si24R1
        It's problematic using it for power level without messing other things!
        • mfalkviddM
          See if you can change the value and call
          _radio.RF24_initialize();
          But I am not familiar with the inner workings of the radio code. Maybe running RF24_initialize() will have unintended side effects.
            B
            B
            bilbolodz
            That's obvious, I'm using it. Problem is that its "#define'ed" so value of these "variable" is set during compilation and it's not possible to change it in program!
            • B bilbolodz
              @bilbolodz sorry, I must have misunderstood your question. You asked how to get the current power setting. I said that the current power setting will be the default value, unless you set it to something else. If you set it to something else, it will be set to the value you set it to. So just use the value you set it to? No need to get it from the radio?
              • mfalkviddM
                Enabling MY_DEBUG_VERBOSE_RF24 would print the registers though. Maybe that's what you are asking for?
                  B
                  B
                  bilbolodz
                  @mfalkvidd
                  The problem is:
                  My sensors network is over 30 nodes a few repeaters and so on, majority of nodes are the same hardware devices.
                  I want to "tune" my network changing NRF power level and MY_PARENT_NODE_ID "on th fly" (now it's "hard defined").
                  You've suggested to use method:
                  int8_t myNodeId;
                  #define MY_NODE_ID myNodeId
                  void before () {
                      // read I/O pins and set myNodeId
                      myNodeId = 32;
                      Serial.println( myNodeId );
                  but with MY_PARENT_NODE_ID and MY_RF24_PA_LEVEL. Good idea I will check if it working BUT:
                  there MUST be a way to check remotely IF it's working. There is no problem with MY_PARENT_NODE_ID because it affect network topology and it could be easily checked. I don't know how to check "from program" current power level.
                  Ideal solution would that sketch will detect current power level and suffix sketch name with _MIN, _LOW, _HIGH, _MAX.
                  It would allow me to have only two version of "HEX firmware" for OTA: with or without repeater mode. Other things (parent level and ID) I could change "on the fly" sending command" (and maybe rebooting) to sensor.
                  Is it clear now?
                  mfalkviddM 2 Replies Last reply
                  • B bilbolodz
                    @mfalkvidd
                    The problem is:
                    int8_t myNodeId;
                    void before () {
                        myNodeId = 32;
                    Is it clear now?
                    @bilbolodz yup. Thanks for clarifying.
                    And thanks for noticing that _radio is only available for rfm69. Seems a bit inconsistent to me, but there are probably reasons for it.
                    It looks like transportGetTxPowerLevel() / RF24_getTxPowerLevel() will return some sort of mapping of the current power level. But these functions are internal/private, so I don't know how to access them.
                    • mfalkviddM
                      Verifying the parent node id should be possible by calling transportGetParentNodeId() or simply getParentNodeId();
                      • B bilbolodz
                        @mfalkvidd
                        The problem is:
                        int8_t myNodeId;
                        void before () {
                            myNodeId = 32;
                        Is it clear now?
                        @bilbolodz how about this? https://github.com/mysensors/MySensors/blob/726a20dad9696ed86408106061a9e0be31995b5c/core/MyTransport.h#L524
                        Sending a I_SIGNAL_REPORT_REQUEST message with the command "T" could be what you need?
                        B 2 Replies Last reply
                          B
                          B
                          bilbolodz
                          wrote on last edited by bilbolodz
                          Unfortunately MYSController in current version doesn't support I_SIGNAL_REPORT_REQUEST message. I will try it in code, thanks
                          • B bilbolodz
                            B
                            B
                            bilbolodz
                              B
                              B
                              bilbolodz
                              #22
                              @mfalkvidd
                              * @brief Get transport signal report
                              * @param command:
                              * R = RSSI (if available) of incoming @ref I_SIGNAL_REPORT_REQUEST message (from last hop)
                              * R! = RSSI (if available) of ACK to @ref I_SIGNAL_REPORT_REVERSE message received from last hop
                              * S = SNR (if available) of incoming @ref I_SIGNAL_REPORT_REQUEST message (from last hop)
                              * S! = SNR (if available) of ACK to @ref I_SIGNAL_REPORT_REVERSE message received from last hop
                              * P = TX powerlevel in %
                              * T = TX powerlevel in dBm
                              * U = Uplink quality (via ACK from parent node), avg. RSSI
                              * @return Signal report (if report is not available, INVALID_RSSI, INVALID_SNR, INVALID_PERCENT, or INVALID_LEVEL is sent instead)
                              int16_t transportSignalReport(const char command);
                              * @param signalReport
                              * @return report
                              int16_t transportGetSignalReport(const signalReport_t signalReport);
                              These functions are available only in devlopment branch. Not implemented into stable code :-(
                              • B bilbolodz
                                @mfalkvidd
                                * @param command:
                                * @return report
                                #23
                                @bilbolodz yes. Everything in MySensors started off in the development branch :) It takes time and effort to code and test. What you're asking for is interesting, but historically it has not been interesting enough for anyone to "man up" and spend the time needed.
                                • B
                                  B
                                  bilbolodz
                                  It looks that I've achieved my goal. I'm able dynamically change parent id node (proved in lab) and power level (don't have idea how to check it). You can send V_VAR1 message with number of preferred parent or V_VAR2 with requested power (values: 0 - RF24_PA_MIN, 1 - RF24_PA_LOW, 2 - RF24_PA_HIGH, RF24_PA_MAX) and then REBOOT node (required to changes take effect). Version of sketch reported to controller is changed dynamically depends of set power level.
                                  My "repeater: code bellow:
                                  #define SKETCH_NAME "Repeater Node L1"
                                  #define SV "1.0.1"
                                  #define MY_REPEATER_FEATURE
                                  int8_t myParrentNodeId;
                                  int8_t myRF24PALevel;
                                  #define MY_PARENT_NODE_ID myParrentNodeId
                                  #define MY_RF24_PA_LEVEL myRF24PALevel
                                  #ifndef MY_REPEATER_FEATURE
                                  #define SKETCH_VERSION1 SV
                                  #define SKETCH_VERSION1 SV "R"
                                  #define SKETCH_VERSION SKETCH_VERSION1 "   "
                                  uint8_t SketchVersion[sizeof(SKETCH_VERSION)];
                                  #define EEPROM_PARENT 0
                                  #define EEPROM_PA_LEVEL 1
                                  void before() {
                                    int8_t tmpui = loadState(EEPROM_PARENT);
                                    if (tmpui == 0xFF)
                                      myParrentNodeId = 0;
                                    else {
                                      myParrentNodeId = tmpui;
                                    memcpy(SketchVersion, SKETCH_VERSION, sizeof(SKETCH_VERSION));
                                    tmpui = loadState(EEPROM_PA_LEVEL);
                                    switch (tmpui)
                                      case 0:
                                        myRF24PALevel = RF24_PA_MIN;
                                        memcpy(SketchVersion + sizeof(SKETCH_VERSION) - 4, "MIN", 3);
                                      case 1:
                                        myRF24PALevel = RF24_PA_LOW;
                                        memcpy(SketchVersion + sizeof(SKETCH_VERSION) - 4, "LOW", 3);
                                      case 2:
                                        myRF24PALevel = RF24_PA_HIGH;
                                        memcpy(SketchVersion + sizeof(SKETCH_VERSION) - 4, "HIG", 3);
                                      case 3:
                                        myRF24PALevel = RF24_PA_MAX;
                                        memcpy(SketchVersion + sizeof(SKETCH_VERSION) - 4, "MAX", 3);
                                      default:
                                    //Send the sensor node sketch version information to the gateway
                                    //sendSketchInfo("Repeater Node L1 MAX", "1.0");
                                    sendSketchInfo(SKETCH_NAME, SketchVersion);
                                    if (!message.isAck()) {
                                      if (message.type == V_VAR1) {
                                        uint8_t tmpui = message.getByte();
                                        uint8_t tmpui1 = loadState(EEPROM_PARENT);
                                        if (tmpui != tmpui1)
                                          saveState(EEPROM_PARENT, tmpui);
                                        uint8_t tmpui1 = loadState(EEPROM_PA_LEVEL);
                                        if (tmpui >= 0 && tmpui <= 3)
                                            saveState(EEPROM_PA_LEVEL, tmpui);
                                    B
                                    B
                                    bilbolodz
                                    If you are using dev branch please test my sketch and check changing power mode with I_SIGNAL_REPORT_REQUEST message or transportGetSignalReport(const signalReport_t signalReport) function.
