  2. Announcements
  • mfalkviddM
    Maybe it could be as simple as running two instances of mysgw, using different pins for the nrf and the rfm?
      Sergio RiusS
      Sergio RiusS
      Sergio Rius
      #561
      @mfalkvidd Maybe. I'm programmer, but not for Linux. My concern is the part of the service that creates the virtual device colliding between the instances.
      I'll do a test in a virtual machine as soon as I have some time.
      It should be something easy to test.
      • Sergio RiusS Sergio Rius
        @Sergio-Rius by "virtual device", do you mean the com port? If that's the caee, it can be specified with --my-serial-pty=
        Ot let one gateway be serial and the other ethernet.
          Sergio RiusS
          Sergio RiusS
          Sergio Rius
          @mfalkvidd yes. Should work. I admit I've not taken a look at the code nor I don't know how to install the service two times.
          I'm used to having problems with programs that use static resources allocation. But I don't know if that's the case.
            maybe you could also consider making 2 ethernet gateway one on port 5003 and the other on port 5004 so that you can use myscontroller to debug from remote.
              Matt
              Hi guys couple of questions, apologies if they have been covered elsewhere.
              I am running latest dev branches of domoticz and MYS on a pi2.
              At random times it seems the NRF24L01+ LNA/PA goes down, or MYS goes down and domotics stops receiving signals from all of the nodes at the same time. I have the interrupt feature enabled.
              I have set the option under domoticz/hardware/data timeout to restart if no data received in five minutes but I dont think this is an ideal solution, and have yet to find out if this domoticz feature actually works in my scenario.
              Any idea what causes this? I found an old thread over on the domoticz/mysensors forum but no answers there. I am using a new sd card class 10.
              What I want to do is try out the different MYS builds on domoticz ie MQTT and SERIAL as well as ethernet which I am currently running. However I'm not sure how to stop the current MYS service and completely clean up the current build to start from scratch... I have tried just re entering the ./configure commands then 'make' but this does not seem to work.
              Many thanks,
              Matt
              • M Matt
                Many thanks,
                Matt
                #566
                @Matt log files for the time where the problem occurred will be essential for troubleshooting.
                make uninstall will stop the service and uninstall
                make cleanconfig will remove previous ./configure settings
                make clean will remove compiled code
                M 2 Replies Last reply
                • C ccy
                  @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
                  [root@alarmpi bin]# ./mysgw -d
                  mysgw: Starting gateway...
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: !TSM:INIT:TSP FAIL
                  mysgw: TSM:FAIL:CNT=1
                  mysgw: TSM:FAIL:PDT
                  mysgw: TSM:FAIL:RE-INIT
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:CNT=2
                  mysgw: TSM:FAIL:PDT
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:CNT=3
                  mysgw: TSM:FAIL:PDT
                  mysgw: Received SIGINT
                  Here is my /boot/config.txt:
                  gpu_mem=64
                  initramfs initramfs-linux.img followkernel
                  dtparam=spi=on
                  and the spi dev:
                  # ls /dev/spidev0.*
                  I am using ArchLinuxARM:
                  # uname -a
                  Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
                  I only wiring 7 pins (1-7) on NRF24l01+.
                  Raspberry Pi 2 hardware information:
                  # cat /proc/cpuinfo
                  processor       : 0
                  model name      : ARMv7 Processor rev 5 (v7l)
                  BogoMIPS        : 38.40
                  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
                  CPU implementer : 0x41
                  CPU architecture: 7
                  CPU variant     : 0x0
                  CPU part        : 0xc07
                  CPU revision    : 5
                  processor       : 1
                  BogoMIPS        : 38.40
                  CPU architecture: 7
                  CPU variant     : 0x0
                  CPU part        : 0xc07
                  CPU revision    : 5
                  processor       : 2
                  BogoMIPS        : 38.40
                  CPU architecture: 7
                  CPU variant     : 0x0
                  CPU part        : 0xc07
                  CPU revision    : 5
                  processor       : 3
                  BogoMIPS        : 38.40
                  CPU architecture: 7
                  CPU variant     : 0x0
                  CPU part        : 0xc07
                  CPU revision    : 5
                  Hardware        : BCM2835
                  Revision        : a21041
                  Serial          : 00000000475d18a4
                  # cat /sys/firmware/devicetree/base/model
                  Raspberry Pi 2 Model B Rev 1.1
                  Output from MySensors configure:
                  # ./configure
                  ./configure: line 111: warning: command substitution: ignored null byte in input
                  [OK] Finished.
                  I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
                  function detect_machine {
                      case $hardware in
                      BCM2835)
                          soc="BCM2835"
                          if [[ $machine == "Raspberry"* ]]; then
                              local rev=($(detect_rpi_revision))
                              if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                                  tp="RPi3"
                                  tp="Rpi2"
                              fi
                          fi
                  make mysgw again, and I get this finally:
                  # ./mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:INIT:TSP OK
                  mysgw: TSM:INIT:GW MODE
                  mysgw: MCO:REG:NOT NEEDED
                  mysgw: MCO:BGN:STP
                  mysgw: MCO:BGN:INIT OK,TSP=1
                  enloE
                  enloE
                  enlo
                  @ccy that correction to the detect_machine function was necessary on my Rpi 3 too (I took the latest version from master). I got it working with that addition.
                  Soooo I guess that would be worth adding to the code / opening an issue on github, wouldn't it?
                  • Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    I'm just now testing the two instances installation. I was going to just alter the flag --prefix but now I see in options that there's also the install dir:
                    Installation options:
                        --prefix=<PREFIX>           Installation prefix path. [/usr/local]
                        --gateway-dir=<DIR>         Gateway files installation directory. [PREFIX/bin]
                    What do you think should be the preferred way for installing two instances, only changing --gateway-dir?
                      Matt
                      @mfalkvidd OK thanks for your reply.
                      Have set up the -d parameter in mysgw.servie and am waiting for it to fall over again.
                      If I catch it I will post syslog.
                      Matt
                      • Sergio RiusS
                        Sergio RiusS
                        Sergio Rius
                        #570
                        Seems that I'll need some help for getting this properly done.
                        I can't launch two instances of the service.
                        What I've done is following the guide instructions with the following configuration:
                        ./configure \
                         --my-transport=nrf24 \
                         --my-rf24-irq-pin=18 \
                         --my-gateway=ethernet --my-port=5003 \
                         --prefix=/opt/mysgw-nrf
                        Then manually executed it, and it run ok and get one test node connected and Domoticz saw it all.
                        Then I duplicated the MySensors folder and in there made the build with the following configuration:
                        ./configure \
                         --my-rf24-channel=82 \
                         --my-rf24-ce-pin=37 \
                         --my-rf24-cs-pin=36 \
                         --my-rf24-irq-pin=33 \
                         --my-gateway=ethernet --my-port=5004 \
                         --prefix=/opt/mysgw-rfm
                        Even when it says rfm, i connected a second NRF with the following pinout (blue=first NRF, green=second):
                        *IRQ on pin 33 as config says, and power from 1.
                        Then I tried to make and run and I get this output:
                        pi@domo_testing:~/MySGW_RFM $ sudo ./bin/mysgw -d
                         __  __       ____
                                |___/                      2.2.0-beta
                        mysgw: MCO:BGN:INIT CP=RNNG--Q-
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: pinMode: invalid pin: 33
                        mysgw: pinMode: invalid pin: 37
                        mysgw: pinMode: invalid pin: 36
                        mysgw: digitalWrite: invalid pin: 37
                        mysgw: digitalWrite: invalid pin: 36
                        mysgw: You need root privilege to use SPI.
                        Is that I have to connect MOSI and MISO to the same pins that the first NRF?
                          ./configure \
                          ./configure \
                           __  __       ____
                                  |___/                      2.2.0-beta
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          @Sergio-Rius see https://forum.mysensors.org/post/72145 and https://github.com/mysensors/MySensors/issues/895
                            Sergio RiusS
                            Sergio RiusS
                            Sergio Rius
                            #572
                            @mfalkvidd That was the culprit. Thanks.
                            But now... seems that the radio that is using channel 76 also get connections from nodes on channel 83, and the second radio, the 83 one doesn't pick anything.
                            Is there a way to confirm that gw and nodes are using one channel or other during the bootup?
                            gohanG 1 Reply Last reply
                              @Sergio-Rius try increasing the distance between channels to at least 10 or more
                                Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                @gohan Done. I've just burnt the node with channel 125 and it seems to have no effect. It registers on the 76 radio.
                                Does the #define MY_RF24_CHANNEL 125 has to be before or after the include of mysensors.h? I have it before.
                                  Sergio RiusS
                                  Sergio RiusS
                                  Sergio Rius
                                  #575
                                  Well, I've changed the channel for the 1st radio to 83 and left the second at 125.
                                  If I burn the testing node for ch125 it doesn't receives reply from the gw. If I then burn it on ch83, it registers and comunicates with the first radio.
                                  So I think the second radio does not work on the Raspberry Pi. The service communicates with the controller but does nothing for the network side.
                                  Also on the second radio:
                                  mysgw: !TSF:SAN:FAIL
                                  mysgw: TSM:FAIL:DIS
                                  mysgw: TSF:TDI:TSL
                                  mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:DIS
                                    mysgw: TSF:TDI:TSL
                                    mysgw: TSM:INIT
                                    @Sergio-Rius if you shut down mysgw for the first radio and restart mysgw for the second radio, does the second radio start to work?
                                    And do you get the same debug output? The SPI message looks bad. Maybe the two gateways are conflicting.
                                      Sergio RiusS
                                      Sergio RiusS
                                      Sergio Rius
                                      #577
                                      @mfalkvidd Nope, the service seems to have stopped the SAN errors but still no communication:
                                       __  __       ____
                                              |___/                      2.2.0-beta
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: Listening for connections on 0.0.0.0:5004
                                      mysgw: MCO:BGN:STP
                                      mysgw: Client 0 connected
                                      mysgw: Client 0: 0;0;3;0;2;
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      12 TSM:INIT:TSP OK
                                      14 TSF:SID:OK,ID=1
                                      16 TSM:FPAR
                                      51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2060 !TSM:FPAR:NO REPLY
                                      2062 TSM:FPAR
                                      2099 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4106 !TSM:FPAR:NO REPLY
                                      4108 TSM:FPAR
                                      4145 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6152 !TSM:FPAR:NO REPLY
                                      6154 TSM:FPAR
                                      6191 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      8198 !TSM:FPAR:FAIL
                                      8200 TSM:FAIL:CNT=1
                                      8202 TSM:FAIL:PDT
                                      18206 TSM:FAIL:RE-INIT
                                      18208 TSM:INIT
                                      18214 TSM:INIT:TSP OK
                                      18219 TSF:SID:OK,ID=1
                                      18221 TSM:FPAR
                                      18257 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      20267 !TSM:FPAR:NO REPLY
                                      20269 TSM:FPAR
                                      20305 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      22315 !TSM:FPAR:NO REPLY
                                      22317 TSM:FPAR
                                      22353 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      24363 !TSM:FPAR:NO REPLY
                                      24365 TSM:FPAR
                                      24401 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      26411 !TSM:FPAR:FAIL
                                      26413 TSM:FAIL:CNT=2
                                      26415 TSM:FAIL:PDT
                                      36419 TSM:FAIL:RE-INIT
                                      36421 TSM:INIT
                                      36427 TSM:INIT:TSP OK
                                      36431 TSF:SID:OK,ID=1
                                      36433 TSM:FPAR
                                      36470 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      38479 !TSM:FPAR:NO REPLY
                                      38481 TSM:FPAR
                                      38518 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      40527 !TSM:FPAR:NO REPLY
                                      40529 TSM:FPAR
                                      40566 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      42575 !TSM:FPAR:NO REPLY
                                      42577 TSM:FPAR
                                      42614 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      44623 !TSM:FPAR:FAIL
                                      44625 TSM:FAIL:CNT=3
                                      You find the pinouts I send before are right to you?
                                      • mfalkviddM
                                        MY_* defines need to be before #include MySensors.h so you're doing the right thing.
                                        I don't know about the pins, have never used anything but the default wiring myself. But if the pins were wrong you should get TSM:INIT:TSP FAIL instead of TSM:INIT:TSP OK.
                                        If you reconfigure the first mysgw (the one with the default pins) to use channel 83, does communication with the node on channel 83 work?
                                          Sergio RiusS
                                          Sergio RiusS
                                          Sergio Rius
                                          @mfalkvidd yeah, look three posts before.
                                          I'll try to get mosi and miso from the default pin out sharing with the first radio. Now I'm using the ones marked as 1, when the default ones are marked 0.
