  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • F Floca
    Ok, i delete the eeprom from both, gateway and node and flash the old scripts with additional definiton of Num IRQ for the gateway?
    #47
    @Floca That there should be no need to clear the eeproms, and no need to re-flash the temperature node. Just flash the gateway with the IRQ_NUM set and restart the temperature node.
    • mfalkviddM
      My node and gw have been working throughout the night.
      • F
        F
        Floca
        wrote on last edited by Floca
        #49
        I have No Reply, don't know what i do wrong :(
         * Version 1.0 - Henrik EKblad
         * Contribution by tekka,
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * LED purposes:
         * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #include <ArduinoOTA.h>
        #define MY_BAUD_RATE 9600
        #define MY_RADIO_RFM69
        #define MY_RFM69_IRQ_NUM D2
        #define MY_RFM69_IRQ_PIN D2
        #define MY_RFM69_CS_PIN D8
        #define MY_RFM69_FREQUENCY RFM69_433MHZ
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "N3tw0rk.NET"
        #define MY_ESP8266_PASSWORD "123456"
        #define MY_ESP8266_HOSTNAME "RFM69-Gateway"
        // Enable UDP communication
        //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
        #define MY_PORT 5003
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        // Set blinking period
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        #if defined(MY_USE_UDP)
        #include <WiFiUDP.h>
        #include <ESP8266WiFi.h>
        	ArduinoOTA.onStart([]() {
        		debug("ArduinoOTA start\n");
        	ArduinoOTA.onEnd([]() {
        		debug("\nArduinoOTA end\n");
          ArduinoOTA.setPassword((const char *)"123");
        	ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
        		debug("OTA Progress: %u%%\r", (progress / (total / 100)));
        	ArduinoOTA.onError([](ota_error_t error) {
        		debug("Error[%u]: ", error);
        		if (error == OTA_AUTH_ERROR) {
        			debug("Auth Failed\n");
        		} else if (error == OTA_BEGIN_ERROR) {
        			debug("Begin Failed\n");
        		} else if (error == OTA_CONNECT_ERROR) {
        			debug("Connect Failed\n");
        		} else if (error == OTA_RECEIVE_ERROR) {
        			debug("Receive Failed\n");
        		} else if (error == OTA_END_ERROR) {
        			debug("End Failed\n");
        	ArduinoOTA.begin();
        	ArduinoOTA.handle();
        • F
          F
          Floca
          Wich Arduino IDE Version are you using? (Last Idea)
          • F Floca
            @Floca good idea! I'm using 1.6.8 (haven't gotten around to upgrading in a while)
            • F
              F
              Floca
              dont know, it is not working anyway
              • F
                F
                Floca
                is there a chance to get your library Folder?
                • F Floca
                  @Floca sure. I'm abroad now but I can zip it up when I am back home.
                  F 1 Reply Last reply
                    F
                    F
                    Floca
                    @mfalkvidd That would be great!
                    Your test Module for the Gateway was an Wemos, an NodeMcu or something else?
                    regards
                    • F Floca
                      regards
                      @Floca I verified both nodemcu and wemos d1 mini
                      • archiijsA
                        archiijsA
                        archiijs
                        Hi, not sure if @Floca get his nodes working, but for me, the problem got fixed with this
                        as mentioned by @mfalkvidd Thanks!
