  3. My Ethernet Gateway Board (W5500)
21 Posts 10 Posters 23.4k Views 11 Watching
  • J jpaulin
    Hello everyone!
    Just wanted to share my Ethernet Gateway build. It became pretty neat, I think.
    Connected to my WIFI extender.
    I'm using a Vero PCB Prototyping Board with copper strips. It makes it easier to solder and less cables.
    To cut the copper strips on the Vero board I'm using a 5mm drill bit and my finger tips:
    Example from a Vero Board Project:
    You can buy them for example from here: Ebay
    I'm using a W5500 Ethernet Module instead of W5100.
    A W5500 Ethernet module is more compact, but a little bit more expensive.
    If you'll use a W5500 Module as I do, you need to replace the Arduino Ethernet library first.
    I'm using the following GitHub library from WizNet:
    https://github.com/Wiznet/WIZ_Ethernet_Library
    Use the Arduino IDE 1.5.X branch.
    Replace everything in the original Ethernet Library (Ethernet\src\ directory). If you're using Windows they should be in following directory:
    C:\Program Files (x86)\Arduino\libraries\Ethernet\src
    In the file W5100.h located in \Ethernet\src\utility\ it's preset as a W5500 WizNet chip:
    //#define W5100_ETHERNET_SHIELD // Arduino Ethenret Shield and Compatibles ...
    //#define W5200_ETHERNET_SHIELD // WIZ820io, W5200 Ethernet Shield
    #define W5500_ETHERNET_SHIELD   // WIZ550io, ioShield series of WIZnet
    For my Vero board design I made the drawing in Excel. It works pretty well for me. :smiley:
    Have a look at my Excel file attached here:
    0_1453581415262_MySensor Ethernet GW Circuit Board.xlsx
    I'm using an Arduino Pro Mini 3.3V 8MHz.
    The Voltage Regulator used in this design (D24V3F3 3.3V) is from Pololu.
    Please note that the internal Voltage Regulator in the Arduino Pro Mini isn't powerful enough to run the W5500 Ethernet Module.
    treborjm87T
    treborjm87T
    treborjm87
    @jpaulin I see that you are using the W5500 chipset on your Ethernet module... According to the specs of the W5500 chip, it looks like it has a MAC address. Have you tried to get a DHCP address using the native MAC Address of the W5500?
    I'm considering going with that USR-ES1 as well. I like the small form factor, but I won't waste my time if it doesn't already have a MAC address. Backup plan is the W550io, which supposedly has MAC address embedded. Same chipset.
    Treborjm87
    Rob
    J 1 Reply Last reply
    • treborjm87T treborjm87
      Treborjm87
      Rob
      J
      J
      jpaulin
      @treborjm87
      I made some tests with the MAC address. As far as I can see there's no MAC address being generated from my W5500 module. With no pre-set MAC address sent the WiFi Router stops working with the gw (Ethernet.begin()). It does work with one of my older routers. My guess is the older router ignores the missing MAC address.
      treborjm87T 1 Reply Last reply
      • J jpaulin
        @treborjm87
        treborjm87T
        treborjm87T
        treborjm87
        wrote on last edited by treborjm87
        @jpaulin
        I am struggling to get the USR-ES1 to work. I am using IDE 1.6.11. (At this point, I am only trying to get the WebServer to work) It looks like all of the libraries are set up correctly, by default, i.e. the #define (#define W5500_ETHERNET_SHIELD) that you mention above is already uncommented. There must be something else that I am missing??? All that I see from the debug window is "server is at 0.0.0.0"
        Any chance you would allow me to see your code for your gateway?
        Thanks again!
        Rob
        • CrankyCoderC
          CrankyCoderC
          CrankyCoder
          Bravo!! that is a great looking gateway.
          Home Automation Tinkerer
          www.CrankyCoder.net
          Gateway: MQTTClientGateway
          MySensors: 2.3
          • J jpaulin
            Hello everyone!
            mtiutiuM
            mtiutiuM
            mtiutiu
            @jpaulin
            Nice work. I was thinking to try out the W5500 chip before stumbling across this topic. Were you able to share the SPI port between W5500 and radio module?
            • J
              J
              jpaulin
              wrote on last edited by jpaulin
              @mtiutiu
              I'm using MY_SOFTSPI to separate the SPI ports. I've never tried to share the SPI-bus with an NRF24 radio and W5500.
              I've seen Adafruit has released a library named "Ethernet2.h" for the W5500 module. It's a nice alternative, no need to replace the library when switching between a W5100 and W5500 Ethernet module. Haven't tested it, though.
              For an RFM69 gateway that I've built with a W5500 Ethernet module I'm sharing the SPI bus. No SOFTSPI setup is available yet for the RFM69, as far as I know. In the following thread you can see my setup sharing the SPI port between an RFM69 radio and W5500 Ethernet module.
              I saw a major transport rework was released Mar 28 in the development branch with a lot of new stuff. Maybe some solution has been included to share the SPI port Out of the Box?
                @jpaulin
                Thanks again!
                Rob
                J
                J
                jpaulin
                @treborjm87
                Sorry. I missed your chat.
                Here's the code. I'm using the standard W5100 example with mqtt.
                 * Version 1.0 - Henrik Ekblad
                 * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                 * LED purposes:
                 * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                 * nRF24L01+  ESP8266
                 * VCC        VCC
                 * CE         GPIO4
                 * CSN/CS     GPIO15
                 * SCK        GPIO14
                 * MISO       GPIO12
                 * MOSI       GPIO13
                  * Inclusion mode button:
                // Set MQTT client id
                //#define MY_W5100_SPI_EN 4
                // radio on the same spi bus.
                  #define MY_SOFTSPI
                #ifndef MY_RF24_CE_PIN
                  #define MY_RF24_CE_PIN 5
                #ifndef MY_RF24_CS_PIN
                  #define MY_RF24_CS_PIN 6
                #define MY_IP_ADDRESS 192,168,1,72
                #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 70
                #define MY_PORT 1883
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                #include <Ethernet.h>
                • treborjm87T
                  treborjm87T
                  treborjm87
                  @jpaulin
                  Thanks for posting the code!
                  I had to take a break from the home automation world for a bit. So, it was great timing that you posted. I'm building my MQTT gateway with the w5500. I'm not completely ready to try the rfm69 yet!!!
                  Thanks again!!!
                  Rob
                  • J jpaulin
                    Hello everyone!
                    E
                    E
                    Ed1500
                    @jpaulin Looking good. And I mean GOOD
                    • E Ed1500
                      J
                      J
                      jpaulin
                      @Ed1500
                      Appreciate your feedback!
                      Here's another of my GW I'm using today, with an RFM69 radio, and with an Anarduino as Arduino CPU. I have both GWs up and running for quite a while without issues. The RFM69 GW has a better RF range, hence my preferred gw for most of my sensors. If you need more details, pls let me know.
                      E 1 Reply Last reply
                      • J jpaulin
                        @Ed1500
                        E
                        E
                        Ed1500
                        wrote on last edited by Ed1500
                        @jpaulin Thanks, that is good to know. I have the RFM69 HW running with a W5100/Promini. W5100 module needed a bit of a hardware tweak for SPI, but works well. Now I probably would have opted for the 5500 as well.
                        I just use it to communicate between two properties at some 500 meter distance, most sensors I use are attached to ESP8266 :-)
                        Seems like a rather long Antenna on yr module. What frequency are you on?
                        • E Ed1500
                          J
                          J
                          jpaulin
                          @Ed1500
                          I'm using 433MHz on the RFM69 network.
                          • J jpaulin
                            @Ed1500
                            E
                            E
                            Ed1500
                            @jpaulin OK, thanks. Just seemed like a rather long antenna in the picture.
                            I am using this antenna, with very good results. Better than the 1/4 wavelength whip
                              So basically you replaced the w5100 library and that was pretty much it, right? I have a W5500 and want to make a nrf24 gateway + some sensors
                              • G
                                G
                                Gad Ofir
                                Hi i have the W5500 with pins and board
                                this one
                                and Arduino Uno R3
                                anything i need to change?
                                1. i guess i don't need that 3.3 converter right?
                                2. i did the change of \Ethernet\src flashed the board
                                3. now i will connect the NRF24 just like you did ? same pins?
                                anything else I should change?
