  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • ben999B ben999
    Slightly off-topic here... but related to this particular sketch
    If you look close enough (and copy-paste the sketch into your IDE) you'll witness that one curly-bracket is technically missing at the end of loop()...
    But as I added it to the sketch I got error
    Sketch compiles fine "with" the missing curly-bracket... ???
    Any comment to that (in my sense) funny behavior ?
    #72
    @ben999 the simple answer is probably that the backet isn't missing :)
    Can you show why you think it is missing?
    • ben999B
      ben999B
      ben999
      wrote on last edited by ben999
      #73
      @mfalkvidd
      I must have gone mad then :ghost:
      Check the loop()
      The last closing curly--bracket is for
      So which one closes
      void loop()     {
      If i add one more to "make it right" then hell brakes loose...
      sketch_jul31a:110: error: expected declaration before '}' token
      exit status 1
      1-That's the only sketch behaving this way
      2-Even the "IDE-automatic-opening-bracket-finder" (shows which bracket is open when placing cursor on closing bracket) can NOT find the right bracket for loop()...
      :scream:
      • mfalkviddM
        Interesting observation @ben999
        This is caused by the preprocessing directives.
        #if COMPARE_TEMP == 1
        Only one of these if statements will be active. The Arduino IDE probably doesn't evaluate preprocessing directives, so it sees two if statements and therefore thinks it should see two end braces. A way to "fix" this could be to move the starting curly brace to after the preprocessing directives:
        This allows the Arduino IDE to parse the code correctly, and correctly match the braces.
        ben999B 1 Reply Last reply
          It's time to move to a better IDE 😁
            ben999B
            ben999B
            ben999
            @mfalkvidd
            Gosh you're a genius ! And you share your knowledge with style and simple explanation ! But i can only upvote you once :D
            @gohan
            No way :D IDE is nice and simple for nice and simple people like me :rabbit:
            • C
              C
              chaeron
              I just upgraded to the MYS 2.1.1 version.
              My OneWire temperature sensors were not detected!
              I moved the sensors.begin() from setup() to before(), and that seems to have fixed things, and my temp sensors are being detected and read now.
              Anyone know why the OneWire library has to be initialized before MySensors setup?
              rejoe2R 1 Reply Last reply
              • C chaeron
                rejoe2R
                rejoe2R
                rejoe2
                @chaeron I assume, you used an old version of the sketch.
                Your question most likely is related to a change in the order of the initialisation. This has changed in Version 2.2: from
                setup()=>presentation()
                to
                before()=>presentation()=>setup().
                So also the initialisation of sensors had to be reviewed accordingly (eg. to get the number of devices).
                C 1 Reply Last reply
                • rejoe2R rejoe2
                  to
                  C
                  C
                  chaeron
                  @rejoe2 said in 💬 Temperature Sensor:
                  That is correct....the original code was written over a year ago. Trying to run it under 2.1.1 caused it to fail.
                  to
                  So where was this rather major change documented? It would probably have broken any 1-Wire examples, including the temperature one.
                  So I figured out....I went looking for documentation on this rather significant change and was not able to find it noted anywhere.
                  • C chaeron
                    to
                    rejoe2R
                    rejoe2R
                    rejoe2
                    There was a rather small note in the 2.0.0 changelog about the introduction of before().
                    Btw: Another functional routine (preHwInit() (?)) may have been introduced also with 2.1.1 (?). But until now, all of my sketches and tests got along without this preHwInit() functionality. But imo the new structure is pretty good: before() is helpfull to initialise SPI devices on same bus as nRF24 and to collect relevant info like the number of DS18x20, setup() is now also good to send info you only need once (e.g. the Dallas-Chip-ID).
                    The rest is - at least afaik - not really documented well, but most examples (if you use the updated ones) will work (apart from the DS18x20 example, where other - external - code changes made some parts tricky to use.
                    I made some working sketches for the Dallas Sensors some time ago based on some ideas I found here in the MySensors forum; they mostly should still work (exept for the change of getConfig() to getControllerConfig()). If you are interested: here .
                    Kind regards
                    • rejoe2R
                      rejoe2R
                      rejoe2
                      wrote on last edited by rejoe2
                      #81
                      If anyone is interested:
                      The sketches in my repo have been updated yesterday for complete compability with the new structure and syntax. They compile fine and should work, but I didn't have the time to make functional tests also.
                      If anyone is interested, I could also add a multibus example with several Sensors at each bus and different timings for each bus. One of my nodes is working on this concept for several days now (Heizung, RS485 version), so I'm pretty confident this will reliably work for longer periods. But it's rather special:grinning: .
                      • skywatchS
                        skywatchS
                        skywatch
                        @rejoe2
                        Where do we find your repo then?
                        • rejoe2R rejoe2
                          Kind regards
                          rejoe2R
                          rejoe2R
                          rejoe2
                          @chaeron
                          Thx for asking.
                          Repo-link was mentioned above, @rejoe2 said in 💬 Temperature Sensor:
                          Btw: the sketches have been updated and compile now also with MySensors 2.2.0-beta. But to be honest, I didn't test them with hardware until now. So feedback is appreciated :simple_smile:.
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            Additionally: There is also a multibus version included that uses different timings for reading each of the buses.
                            For using this sketch, I'm not sure wheter some changes in the DallasTemperature-lib also is required (it is based on an very recent example of the maintainer's guthub version; should be linked in the Arduino Library Manager; I myself applied some changes wrt. this in my local libs).
                            I may aslo post this in case anyone's interested (and these mods are necessary).
                            DickD 1 Reply Last reply
                            • rejoe2R rejoe2
                              DickD
                              DickD
                              Dick
                              wrote on last edited by Dick
                              #85
                              @rejoe2 Any idea why the DallasTemperatureSimple from your GitHub not presenting in Domoticz?
                                 DESCRIPTION
                                 Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                                 http://www.mysensors.org/build/temp
                                 Enhanced Version also sending the Dallas-ROM-ID, MySensors Version >=2.1.0
                              #include <OneWire.h>
                              uint8_t DS_First_Child_ID = 7; //First Child-ID to be used by Dallas Bus; set this to be higher than other Child-ID's who need EEPROM storage to avoid conflicts
                              int numSensors = 0;
                              bool receivedConfig = false;
                              bool metric = true;
                              DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
                              int resolution = 12; // precision: 12 bits = 0.0625°C, 11 bits = 0.125°C, 10 bits = 0.25°C, 9 bits = 0.5°C
                              int conversionTime = 0;
                              MyMessage msgTemp(0, V_TEMP);
                              MyMessage msgId(0, V_ID);
                              char* charAddr = "Check for faults";
                              #define SEND_ID
                              void before()
                                // 12 bits = 750 ms, 11 bits = 375ms, 10 bits = 187.5ms, 9 bits = 93.75ms
                                conversionTime = 750 / (1 << (12 - resolution));
                                sensors.begin();
                                sendSketchInfo("Temperature Sensor", "1.2");
                                for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                                  sensors.getAddress(tempDeviceAddress, i);
                                  charAddr = addrToChar(tempDeviceAddress);
                                  present(i + DS_First_Child_ID, S_TEMP, charAddr);
                              #ifdef MY_DEBUG
                                  Serial.println(charAddr);
                              #ifdef SEND_ID
                                  // 8 will assure a length of 16 of the sent ROM-ID
                                  send(msgId.setSensor(i + DS_First_Child_ID).set(tempDeviceAddress, 8));
                                  sensors.setResolution(tempDeviceAddress, resolution);
                                sleep(conversionTime);
                                  float temperature = static_cast<float>(static_cast<int>((metric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                    send(msgTemp.setSensor(i + DS_First_Child_ID).set(temperature, 1));
                                    wait(20);
                                    lastTemperature[i] = temperature;
                                sleep(SLEEP_TIME);
                              char* addrToChar(uint8_t* data) {
                                String strAddr = String(data[0], HEX); //Chip Version; should be higher than 16
                                byte first ;
                                int j = 0;
                                for (uint8_t i = 1; i < 8; i++) {
                                  if (data[i] < 16) strAddr = strAddr + 0;
                                  strAddr = strAddr + String(data[i], HEX);
                                  strAddr.toUpperCase();
                                for (int j = 0; j < 16; j++) {
                                  charAddr[j] = strAddr[j];
                                return charAddr;
                              gohanG 1 Reply Last reply
                              • DickD Dick
                                   DESCRIPTION
                                int numSensors = 0;
                                bool metric = true;
                                #define SEND_ID
                                void before()
                                  sensors.begin();
                                #ifdef MY_DEBUG
                                #ifdef SEND_ID
                                      wait(20);
                                  sleep(SLEEP_TIME);
                                  byte first ;
                                  int j = 0;
                                  return charAddr;
                                @Dick you are missing
                                #define MY_NODE_ID x
                                where x is the unique sensor ID you want to assign to node. If look in the gateway or node log you will see the node asking for an ID
                                  #87
                                  @gohan Domticz is capable of handing out node ids so using the default auto setting is perfectly fine.
                                  But yes, the debug log from node and gateway will help a lot in determining what the problem is.
                                    DickD
                                    DickD
                                    Dick
                                    @mfalkvidd I already tried a fixed node ID but that was not the solution so I checked the log of domoticz and this is the result:
                                    2017-08-19 11:59:30.260 MySensors: Node: 48, Sketch Name: Temperature Sensor
                                    2017-08-19 11:59:30.261 MySensors: Node: 48, Sketch Version: 1.2
                                    2017-08-19 11:59:38.480 MySensors: Node: 48, Sketch Name: Temperature Sensor
                                    2017-08-19 11:59:38.481 MySensors: Node: 48, Sketch Version: 1.2
                                    So it see the node but it does not pop up as a new device.
                                    The Arduino log shows this:
                                    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                                    3 MCO:BGN:BFR
                                    6 TSM:INIT
                                    7 TSF:WUR:MS=0
                                    14 TSM:INIT:TSP OK
                                    16 TSF:SID:OK,ID=48
                                    17 TSM:FPAR
                                    59 TSF:MSG:SEND,48-48-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    360 TSF:MSG:READ,0-0-48,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    365 TSF:MSG:FPAR OK,ID=0,D=1
                                    408 TSF:MSG:READ,20-20-48,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                    2066 TSM:FPAR:OK
                                    2067 TSM:ID
                                    2068 TSM:ID:OK
                                    2070 TSM:UPL
                                    2074 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    2086 TSF:MSG:READ,0-0-48,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    2092 TSF:MSG:PONG RECV,HP=1
                                    2094 TSM:UPL:OK
                                    2096 TSM:READY:ID=48,PAR=0,DIS=1
                                    2101 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    2110 TSF:MSG:READ,0-0-48,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    2118 TSF:MSG:SEND,48-48-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                    2127 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    2143 TSF:MSG:READ,0-0-48,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    2152 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                                    2162 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                                    2169 MCO:REG:REQ
                                    2173 TSF:MSG:SEND,48-48-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                    2183 TSF:MSG:READ,0-0-48,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    2188 MCO:PIM:NODE REG=1
                                    2190 MCO:BGN:STP
                                    2191 MCO:BGN:INIT OK,TSP=1
                                    2196 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    2201 !MCO:SLP:REP
                                    2952 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    2957 !MCO:SLP:REP
                                    32960 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    mfalkviddM rejoe2R 2 Replies Last reply
                                    • DickD Dick
                                      3 MCO:BGN:BFR
                                      6 TSM:INIT
                                      7 TSF:WUR:MS=0
                                      14 TSM:INIT:TSP OK
                                      16 TSF:SID:OK,ID=48
                                      17 TSM:FPAR
                                      2066 TSM:FPAR:OK
                                      2067 TSM:ID
                                      2068 TSM:ID:OK
                                      2070 TSM:UPL
                                      2094 TSM:UPL:OK
                                      2169 MCO:REG:REQ
                                      2190 MCO:BGN:STP
                                      2201 !MCO:SLP:REP
                                      2957 !MCO:SLP:REP
                                      @Dick that output doesn't seem to match the sketch you posted. The output says the node is a repeater, but I don't see any repeater activation in the sketch.
                                      • DickD Dick
                                        3 MCO:BGN:BFR
                                        6 TSM:INIT
                                        7 TSF:WUR:MS=0
                                        14 TSM:INIT:TSP OK
                                        16 TSF:SID:OK,ID=48
                                        17 TSM:FPAR
                                        2066 TSM:FPAR:OK
                                        2067 TSM:ID
                                        2068 TSM:ID:OK
                                        2070 TSM:UPL
                                        2094 TSM:UPL:OK
                                        2169 MCO:REG:REQ
                                        2190 MCO:BGN:STP
                                        2201 !MCO:SLP:REP
                                        2957 !MCO:SLP:REP
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @mfalkvidd Thx for your observation, I didn't realise that. Did you try to use this sketch also?
                                        As FHEM is the controller sw I use, I am not able to really test this kind of behaviour, that more seemed to be related to domoticz (or other trouble wrt. to this individual MySensors-installation).
                                        @Dick Imo, the node at least when trying to register behaves as necessary: it presents itself to the controller (but the chosen ID seems to be already bound to a different node). In FHEM - not for the node itself but for individual readings - it is necessary to reload the page to see updated readings, if it's the very first time they are sent from node's side (hope, you can follow my thoughts). Maybe domoticz shows a similar behaviour?
                                        • rejoe2R rejoe2
                                          @rejoe2 could you clarify which observation you are referring to?
