  3. Omron SSR with 3.3V node
5 Posts 2 Posters 3.5k Views 3 Watching
  • ben999B
    ben999B
    ben999
    Guys,
    I like the Omron G3MB-202 SSR
    So far I have used these on 5V arduinos
    I am now moving on towards my next project (touch wall switch) and would like to go for 3.3V nodes
    Any of you using these SSRs with 3.3V trigger ?
    Thanks a lot for your return ;)
    Nca78N 1 Reply Last reply
    • ben999B ben999
      Guys,
      Hello @ben999,
      I have not had any problem with those relays (at least the cheap clones from aliexpress) when running the full board at 3.3V (using HLK-PM03).
      ben999B 1 Reply Last reply
      • Nca78N Nca78
        Hello @ben999,
        ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        @Nca78
        Thank you for sharing your experience
        There are resistors and transistors on the relay board... I guess the relay is triggered via a transistor then...
        Do you run the relay itself (black bloc only) straight from the arduino output?
        • ben999B ben999
          @Nca78
          @ben999 yes, directly connected. I suppose transistor is here for the case when your board signal voltage is too low compared to the voltage of the SSR as the necessary current for SSR is low.
          • Nca78N Nca78
            ben999B
            ben999B
            ben999
            @Nca78
            Great!
            Orders on the way then!!
