  3. NodeManager
  4. NodeManager v1.6-dev: comments and issues
14 Posts 3 Posters 5.6k Views 4 Watching
  • U Offline
    U Offline
    user2684
    This thread is intended to host any discussion related to the beta version of NodeManager v1.6 available at https://github.com/mysensors/NodeManager/tree/development
    • B Offline
      B Offline
      betonmoewe
      I just try to get the TSL2561 Sensor (i2C) working, but without success! The nomal Arduino example scetch works perfect, but it seems, that the sensor would not be not initialized within nodemanager or something like that ...
      Here my code:
      int myTSL2561 = nodeManager.registerSensor(SENSOR_TSL2561);
      ((SensorTSL2561*)nodeManager.getSensor(myTSL2561))->setAddress(TSL2561_ADDR_FLOAT);
      ((SensorTSL2561*)nodeManager.getSensor(myTSL2561))->setGain(TSL2561_GAIN_16X);
      ((SensorTSL2561*)nodeManager.getSensor(myTSL2561))->setTiming(TSL2561_INTEGRATIONTIME_101MS);
      ((SensorTSL2561*)nodeManager.getSensor(myTSL2561))->setSpectrum(TSL2561_VISIBLE);
      //nodeManager.registerSensor(SENSOR_BME280);
      I also tried with only theregister line (nodeManager.registerSensor(SENSOR_TSL2561);), but the same. The BME280 works fine (if enabled).
      what confuses me:
      why is the constructor like that -> SensorTSL2561::SensorTSL2561(NodeManager* node_manager, int child_id): Sensor(node_manager, child_id,A2) ???
      The TSL2561 is connected at A4,A5 because of i2c, but the constructor uses A2 ???
      serial output:
      REG I=1 P=16 P=16 T=37
      LIB V=2.1.1 R=N T=N A=A S=- B=-
      INT P=3 M=255
      INT P=2 M=255
      RADIO OK
      PRES I=200, T=23
      PRES I=201, T=30
      BATT V=3.45 P=100
      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.45
      PRES I=1 T=16
      READY
      MY I=113 M=1
      TSL I=1 L=19
      SEND D=0 I=1 C=0 T=37 S= I=19 F=0.00
      SLEEP 600s
      Does anybody have a solution?
      Best regards
      Frank (Betonmoewe)
      U 1 Reply Last reply
      • B betonmoewe
        Here my code:
        what confuses me:
        serial output:
        INT P=3 M=255
        INT P=2 M=255
        RADIO OK
        PRES I=200, T=23
        PRES I=201, T=30
        BATT V=3.45 P=100
        PRES I=1 T=16
        READY
        MY I=113 M=1
        TSL I=1 L=19
        SLEEP 600s
        Best regards
        Frank (Betonmoewe)
        U Offline
        U Offline
        user2684
        @betonmoewe thanks for reporting this issue. The A2 used is irrelevant since for i2c sensors, the pin provided is not used at all but has to be a valid pin. I may be wrong but I see a "19" reported. Is the issue about the wrong value or something different? Thanks
        • B Offline
          B Offline
          betonmoewe
          hi,
          yes, there is a value, but there is no output (presentation) of the value ... the bme sensor works perfect. Wy is this an "I" value and not a "F" like the other values?
          AWAKE
          TSL I=1 L=2521
          SEND D=0 I=1 C=1 T=37 S= I=2521 F=0.00
          BME I=2 T=24.76
          SEND D=0 I=2 C=1 T=0 S= I=0 F=24.76
          BME I=3 H=52.88
          SEND D=0 I=3 C=1 T=1 S= I=0 F=52.88
          BME I=4 P=1007.86
          SEND D=0 I=4 C=1 T=4 S= I=0 F=1007.86
          SLEEP 60s
          Best regards
          Frank (Betonmoewe)
          • B betonmoewe
            hi,
            AWAKE
            TSL I=1 L=2521
            BME I=2 T=24.76
            BME I=3 H=52.88
            BME I=4 P=1007.86
            SLEEP 60s
            Best regards
            Frank (Betonmoewe)
            U Offline
            U Offline
            user2684
            wrote on last edited by user2684
            @betonmoewe the way I read it is a message of type 37 (V_LEVEL) whose value is 2521 has been sent to the controller. S, I and F correspond to string, integer and float and depending on the sensor a value is set to only one of those. So your reported light level is 2521. The BME sensor reports float values so 24.76 is under F. Does it make sense? Thanks
            • B Offline
              B Offline
              betonmoewe
              okok ... my fault ... you are right LUX is int not float ...
              but no reading is send (I use fhem as reciever):
              2017-08-13 18:57:18 Global global ATTR MYSENSOR_113 mode node
              2017-08-13 18:57:18 Global global ATTR MYSENSOR_113 version 2.1.1
              2017-08-13 18:57:18 MYSENSORS_DEVICE MYSENSOR_113 parentId: 110
              2017-08-13 18:57:18 MYSENSORS_DEVICE MYSENSOR_113 SKETCH_NAME: MultiSensor_NM
              2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 batterylevel: 100
              2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 temperature2: 24.84
              2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 humidity3: 50.85
              2017-08-13 18:57:19 MYSENSORS_DEVICE MYSENSOR_113 pressure4: 1007.90
              no brightness1 and I have no idea ...
              Best regards
              Betonmoewe
              • B betonmoewe
                Best regards
                Betonmoewe
                U Offline
                U Offline
                user2684
                @betonmoewe mmm this is weird, as far as there is a:
                should imply send() has been called successfully. Any chance to check debug output in the gateway to ensure messages are actually delivered? Thanks
                • B Offline
                  B Offline
                  betonmoewe
                  I will try tomorrow ...
                  thanks for your help !
                  • B Offline
                    B Offline
                    betonmoewe
                    wrote on last edited by betonmoewe
                    ok ... if I change V_LEVEL to V_LIGHT_LEVEL in NodeManager.cpp, I got a reading ... strange
                    By the way: I have a small problem with the BME Sensor: pressure and forecast have both the same ID
                    mapReading_forecast4 4 forecast
                    mapReading_pressure4 4 pressure
                    is this correct?
                    I have got a forcast reading only one time :(
                    Betonmoewe
                    • B betonmoewe
                      is this correct?
                      Betonmoewe
                      U Offline
                      U Offline
                      user2684
                      @betonmoewe thanks, but according to https://www.mysensors.org/download/serial_api_20, V_LIGHT_LEVEL is for uncalibrated light level (0-100%) V_LEVEL for light level in lux. Anyway, glad you made it working for your setup.
                      As for the duplicated child ID issue, this shouldn't happen (https://github.com/mysensors/NodeManager/blob/development/NodeManager.cpp#L3277). I wonder if you have reached the maximum number of child IDs, try increasing MAX_SENSORS (e.g. #define MAX_SENSORS 15) in your config.h. Thanks
                      • A Offline
                        A Offline
                        ArduiSens
                        FYI
                        I already had report this in "https://forum.mysensors.org/topic/6534/nodemanager/100", but in that case I was already using V1.6-dev version.
                        *ArduiSens 4 days ago
                        @user2684, why does NodeManager take so many sketch memory?
                        e.g.
                        (#define BATTERY_MANAGER 1; #define DEBUG 1; #define MODULE_DS18B20 1)
                        sketch NodeManager RS485 config for DS18B20 --> 28730 bytes (93%) of program storage space. Maximum is 30720 bytes.
                        own sketch for RS485 SR04T --> 17078 bytes (55%) of program storage space. Maximum is 30720 bytes.
                        OK, DS18B20 and SR04T are not the same but DS18B20 is less complex, so 38% more memory is pretty much.*
                        MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
                        • A Offline
                          A Offline
                          ArduiSens
                          I see a problem when using setSleepSeconds / setPowerPins in combination with the serial RS485 option.
                          void before() {
                          Serial.begin(MY_BAUD_RATE);
                          nodeManager.setSleepSeconds(30);
                          nodeManager.setPowerPins(11,12,1000);
                          • Register below your sensors
                            nodeManager.registerSensor(SENSOR_DS18B20,3);
                          gives a temperature value of 7368:
                          0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=22,pt=5,l=4,sg=0:7368
                          3;255;3;0;22;7368
                          RECV S=3 I=255 C=3 T=22 P=
                          void before() {
                          nodeManager.setReportIntervalSeconds(50);
                          gives a correct value:
                          0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:19.75
                          3;1;1;0;0;19.75
                          RECV S=3 I=1 C=1 T=0 P=
                          • A ArduiSens
                            FYI
                            e.g.
                            U Offline
                            U Offline
                            user2684
                            @ArduiSens thanks, I'll keep track about this issue issue with this https://github.com/mysensors/NodeManager/issues/210
                            • A ArduiSens
                              void before() {
                              3;255;3;0;22;7368
                              void before() {
                              3;1;1;0;0;19.75
                              U Offline
                              U Offline
                              user2684
                              @ArduiSens do you have the full logs to share for the setSleepSeconds / setPowerPins issue? because from what you have posted, that 3;255;3;0;22;7368 should be a heartbeat response not the value of the temperature. Thanks!
